Toyo AT3 on 17s vs Pirelli Scorpion ATR on 20s
Discussion in 'Wheels & Tires' started by TheCAPA1, May 27, 2021.
  1. May 27, 2021 at 9:11 PM
    TheCAPA1
    TheCAPA1 [OP] New Member
    Wes
    Southest TN
    2019 Tundra Crewmax
    Icon Six Speeds, King shocks
    So, I wanted to post a quick weight difference between a set of tires that came off my truck, and the set that went on. I know for me, rotational weight means something. I don't necessarily want to sacrifice functionality and MPG for just aesthetics alone.
    When I bought the truck, it had a set of Pirelli Scorpion ATR 275/55 r20 (Platinum wheel) on it. Have these have been a great tire for me, but I was wanting something a little more aggressive, but did not want to add a bunch more rotational weight.
    I ended up settling on a set of Icon Dynamics Six Speed wheels in the 17in. Per Icon Dynamics, the weight of each wheel comes in at 30 lb. The best I could tell from what I could find on my pirelli's including the weight of the wheel came in right around 80 lb. This was my mark to shoot for. I look at a multitude of tires in the size that I wanted, specifically C load rating as I don't do anything heavy duty, light off-roading on our property, trails here in the mountains of TN, and occasionally pulling the boat for the summer.
    I decided on 285/75 r17 from Toyo Open Country AT3 in C load rating. All in all, I think I hit the mark pretty close as the Toyos came in at 85.5 lb per wheel, the Pirelli's at 79.4 lb. The gap would be a little bit closer if these were unused, ~1lb? So for the difference of 6 lb, effectively only raised my overall rotational weight 6.9%!!!
    A lot of this probably doesn't mean much to you anybody else, but for the past several weeks, I have noticed no difference behind the pedal, negligible if any difference in MPG, no difference in road noise, overall handling feels improved (I realize the last one could be a bit subjective).
    Except for anyone else out there on the neurotic hunt for that weight / size /aesthetics spectrum, maybe you can take away something from this. Cheers!
    20200729_103215.jpg 20210527_153203.jpg 20210527_153123.jpg 20210527_153233.jpg 20210527_160140.jpg
  2. May 27, 2021 at 9:12 PM
    TheBeast The Beach
    always liked the six speed. looks great OP !
    TheCAPA1[OP] likes this.
  3. May 28, 2021 at 7:24 AM
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    I went from stock michellins to the ToyoAT3s and very happy with them. :thumbsup:
    SimpleMan likes this.
  4. May 28, 2021 at 7:34 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Look at all that meat with those potatoes. Looks good bub.
  5. May 28, 2021 at 7:50 AM
    Twowheelssoar
    Twowheelssoar New Member
    NC
    2021 Cement SR5 6-Seater
    Looks good!
    I am thinking about a similar setup, looking at the 35x11.5 r17 AT3 in C load.
    dpast88 likes this.
  6. May 28, 2021 at 8:14 AM
    Hanzo
    Hanzo New Member
    I’m waiting on the same size with method 313s. Any lift or rubbing?
  7. May 28, 2021 at 8:17 AM
    tdn
    tdn New Member
    Michigan
    2021 CM 4x4
    I’ve run the AT3s in 285/70/17 and 275/65/18 and have been great!
    Your truck looks way more than 6.9% more awesome!
  8. May 28, 2021 at 8:17 AM
    TheCAPA1
    Wes
    Southest TN
    2019 Tundra Crewmax
    Yeah, so I have Bilstein 6112 up front and 5160s in the back. Overall lift is a a hair under 3 in. No rubbing at all at full lock forward or backward
  9. May 28, 2021 at 8:32 AM
    Hanzo
    Hanzo New Member
    I’m running the TRD Pro Fox setup, so I’m hoping they’ll clear. I’ll post when I get them on.
  10. May 28, 2021 at 3:07 PM
    TheCAPA1
    Wes
    Southest TN
    2019 Tundra Crewmax
    They should. That'll be a sick combo
  11. Jul 8, 2021 at 5:10 PM
    Kurt1011
    Kurt1011 New Member
    Kurt
    2013 rock warrior
    I just ordered some Toyo AT3's in load range C 285/70/17...what PSI are you guys running? getting them installed next week - more than ready to get the ko2 load range e's off.
  12. Jul 8, 2021 at 5:13 PM
    TheCAPA1
    Wes
    Southest TN
    2019 Tundra Crewmax
    I feel like 38 PSI is sticking out, but can't remember offhand.
    Kurt1011[QUOTED] likes this.
  13. Jul 8, 2021 at 5:19 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Looks great I am considering the same tire for my next setup. How does the C load ride compared to the stock setup? I currently have a set of e load tires that ride pretty rough (but they do look and perform awesome).
  14. Jul 8, 2021 at 5:20 PM
    TheCAPA1
    Wes
    Southest TN
    2019 Tundra Crewmax
    I have not noticed any adverse difference over my p rated tires. One advantage going to these that I noticed immediately was how much "grippier" they felt.
  15. Jul 8, 2021 at 5:42 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    I should have gone with the Toyo's, instead I went with the Wildpeaks and they are heavy beasts. Nice looking truck.
  16. Jul 23, 2021 at 2:27 PM
    Hanzo
    Hanzo New Member
    I went with wildpeaks 285/70r17 on 17” method 313s. Wildpeaks are load range c and run 32psi. Have Fox Pro suspension. Loving it so far…for the couple hours I’ve had them on lol.
    Rob's Inferno and WVI like this.
  17. Jul 24, 2021 at 6:58 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    I love the AT3 tires on my truck. They are pretty quite on the highway and they look great. I am currently running 305/55/R20
