Toyo atx 3 in 34x10.5x17 load range D
Discussion in 'Wheels & Tires' started by Rb123, Nov 19, 2023.
  1. Nov 19, 2023 at 7:02 AM
    Rb123
    Rb123 [OP] New Member
    Washington
    22 trd off-road crewmax mgm
    Bfg at 275/70r18 Lowmax Bumpershellz grill
    Anyone running these. Post some pics if you are, and let us know whether or not you have or need a leveling kit or lift. Also, how’s the ride quality? I’m thinking of pairing these up with some 705’s. Right now I have 275 70 r18 bfg ko2 AT / E rated, With stock trd rims. This would give a bit more height, but keep the total weight down quite a bit.
    equin likes this.
  2. Nov 19, 2023 at 8:34 PM
    jcm1689
    jcm1689 New Member
    JC
    Mesa,Az
    2023 Tundra Platinum Black
    Method 318 17x8.5 25mm Mickey Thompsons Baha Boss 35x12.5r17
    Can't comment on those tires but my brother in law just put Falken AT3W's 35x12.5r18's on stock rims on his SR5 with absolutely no rubbing or any trimming of liner. That tire size should definitely be good to go on a stock truck
  3. Nov 20, 2023 at 4:43 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Interested in that same size Toyo tire. I know 315/70/17s fit with front plastic trim and 2” of lift on my ‘15, so I’m pretty sure the 34x10.5/17s will fit with my setup or something similar for 2-2.5 gen Tundras. I’m more curious to hear of others who run this Toyo tire and size regarding their longevity and performance in the rain.
    I think the only other all terrain tire in that size is the BFG AT/KO2, which is significantly more expensive. I’m running BFG AT/KO2s right now, and while they’re a tough tire with long tread life, they’re not the best in the rain and on slick roads in my experience.
  4. Nov 20, 2023 at 5:51 PM
    Rb123
    Washington
    Its one of the only 34” tire thats not E rated. And affordable. Its D rating should still be adequate for towing and off-roading. I’m not a fan of tire poke. I will run these with method 305’s with +35 offset. I expect to need a 1inch leveling kit, and these should be good.
    equin likes this.
