Toyota OEM shocks/struts vs Napa
Discussion in 'Suspension' started by chunk, May 4, 2017.
  1. May 4, 2017 at 9:48 AM
    chunk
    chunk [OP] New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My 2001 v-8 tundra needs new shocks on all four corners @ 85K miles. I can get toyota oem shocks / struts and reuse the coils, mounting plates, etc or new Napa ez-struts with new coils and associated hardware for about the same price. Any advice on which is a better way to go. Thanks for any advice and recommendations. Chunk.
  2. May 4, 2017 at 9:54 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toytec
    Bear likes this.
  3. May 4, 2017 at 9:56 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    By the way....I'm sure they'll give you a discount if you do the truffle shuffle!!
  4. May 4, 2017 at 11:01 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    My mechanic once told me that Toyota shocks weren't the best. I'd be a bit leery of EZ struts too, especially since you don't have struts. You've got coil overs, unless I'm mistaken. I'd look for some Bilsteins.
  5. May 4, 2017 at 11:13 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    If you look in the mirror and say "tundras have struts" 3 times, @jberry813 will appear and smack you in the back of the head. True story, bro.
  6. May 4, 2017 at 11:52 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I think your whole truck is toast. You should sell your 85k mile 1st gen... I'm a nice guy and all that, I might even fly to the other coast to take it off your hands.
  7. May 4, 2017 at 12:04 PM
    Mudduc
    Mudduc New Member
    Longview tx
    "Tundras have struts" "tundras have struts" "tundras have...... coilover" got scared. Can't do it man!:sorry:
    Toytec makes a great product. I'm looking at the 2.5 for the front as we speak. I'm running toytec boss and toytec lift shackles in the rear. Best mod I have done so far!
    831Tun, GNTundra and TXMiamiFan like this.
  8. May 4, 2017 at 12:23 PM
    chunk
    Just semantics, struts or coil overs. We all know what we're talking about, Napa calls them ez-struts. A distinction without a difference i say. Just wanted some factual opinions on reusing the coils and mounting hardware. I'll just do a Google search. Cheers.
    trayday and MotoTundra like this.
  9. May 4, 2017 at 12:36 PM
    For OEM ride and better performance, Bilsteins are hard to beat.
    bobeast and 831Tun like this.
  10. May 4, 2017 at 12:51 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Hi, I have a 2004 with bilstein 5100's on all 4 corners and alcan springs on the rear. I have always used Bilstein's once the OEM shocks wore out. They have good warranty as well. I purchased new OEM coils and used the second notch on the bilstein on the fronts for leveling and the ride is still pretty smooth with decent travel and rebound off road. I did buy new spring mounts for the front coils which helped with squeaking, the rubber on the old ones was pretty worn. My truck has 199k on it.
    joonbug, ColoradoTJ and 831Tun like this.
  11. May 4, 2017 at 1:02 PM
    TXMiamiFan
    Jose
    Is that your shotgun in the shadow or just happy to see your truck?
  12. May 4, 2017 at 1:20 PM
    mtntop
    mtntop New Member
    hahaha, my wife would be very impressed if the latter were true :) The old golden is 15 this year and this was very likely his last hunt :(. He was a hunting machine in his day. He was tutoring the young black lab in the pic this day and they did good.
    Backslider and TXMiamiFan like this.
  13. May 4, 2017 at 3:43 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    There are some Shenanigans in here, but all in good fun. Any post keeps your thread up top, and guys will answer if they know.
    I don't have any experience with either so I'm not much of a help. With that said from what I have heard I will probably go with Bilsteins after my OEM's go.
    TXMiamiFan likes this.
  14. May 4, 2017 at 5:06 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I haven't seen him around here for a while. He's probably busy using his newly issued ban-hammer over at Tacoma World.
    831Tun and MotoTundra like this.
