Toyota Tundra 2.5’’ Shocks from Elka Suspension
Discussion in 'Elka Suspension' started by Elka Suspension, Apr 8, 2019.
  1. Oct 6, 2019 at 10:25 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    :worthless:
    Rica25 and EDDO[QUOTED] like this.
  2. Oct 7, 2019 at 2:08 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Alignment to spec, tires are next. A little less rake than I thought I was going for, but the look is growing on me.
    Rica25 and dcsleeper408[QUOTED] like this.
  3. Oct 7, 2019 at 2:26 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
    needs 37's. and regear. and rear bumps. and sliders. and bumpers. :D
    EDDO[QUOTED] likes this.
  4. Oct 7, 2019 at 2:42 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Slow your roll there van man. :p
    Still have this other (small) mouth to feed.
    dcsleeper408[QUOTED] likes this.
  5. Oct 7, 2019 at 2:46 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :rolleyes:
  6. Oct 15, 2019 at 7:08 AM
    Elka Suspension
    Elka Suspension [OP] Shock Manufacturer
    Boucherville, QC, Canada
    Your calculations sounds right and you should be good to go with such setup. We only develop our shocks for 4WD (4X4) trucks. although they may fit on some and ride decent with lighter springs, the setup is not verified neither tested on those trucks.
  7. Dec 15, 2019 at 6:47 PM
    2chains
    2chains New Member
    Southern Ablerta
    Looks good, I got the 2-3" non Resi set and add a leaf in the back. I've got the similar stance with the rake.
  8. Dec 15, 2019 at 6:58 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Looks great. I finally did something about wheels and tires as well.
    Rica25 likes this.
  9. Dec 15, 2019 at 8:02 PM
    2chains
    2chains New Member
    Southern Ablerta
    ^^Nice choice on the wheels/tires. Trying to decide which route to take to get the rake back. Don't really want to go with a block or lower the front.
    EDDO likes this.
  10. Dec 15, 2019 at 8:22 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Perhaps consider longer shackles. Coachbuilder sells really nice ones.
  11. Dec 16, 2019 at 4:27 AM
    2chains
    2chains New Member
    Southern Ablerta
    I'll check it out, thanks!
  12. Feb 23, 2021 at 11:07 AM
    TFTundra
    TFTundra New Member
    You have any more photos of your truck after you installed the Elkas and TC shackles, but before new wheels/tires? Looking at the same lift heights, 1.5” up front and 3/4” out back, but I’ll probably end up keeping the stock wheel/tire setup for a while. Thanks.
  13. Feb 23, 2021 at 1:03 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Just a couple. Shot with a potato, so please excuse the quality.
    TFTundra[QUOTED] likes this.
  14. Feb 23, 2021 at 1:36 PM
    TFTundra
    TFTundra New Member
    Thank you sir.
  15. Feb 24, 2021 at 4:44 AM
    Gumby
    Gumby New Member
    Taylor
    2021 Tundra SR5 Off Road (4X4)
    Just looking for clarification here.. toytec doesn't offer this in a kit. All you need to install these is a set of upper control arms? Can anyone provide any recommendations of what to run these with?
  16. Feb 24, 2021 at 6:45 AM
    TFTundra
    TFTundra New Member
    If you purchase the 0-2” kit, you don’t need aftermarket UCAs (per Elka). If you get the 2-3” kit, take your pick. I say total chaos for your uniball flavor or SPC for the ball joint type. I’m sure you will get tons of different opinions here. Research is your friend.
  17. Feb 24, 2021 at 7:00 AM
    Gumby
    Gumby New Member
    Taylor
    Preciate ya. Now that I have direction on what I need I can research on my own :thumbsup:
  18. Feb 24, 2021 at 8:24 AM
    TFTundra
    TFTundra New Member
    Also, mcm fab makes a good uniball UCA. According to what others on the forums say, it is of equal quality to total chaos, but the uniball is a 1” diameter instead of 1.5” from the Total Chaos, and I think the price difference reflects that. According to mcm, they use the same high quality materials and uniball, just smaller. It looks like people are running the mcm UCA with zero issues, so if you’re into paying less than the premium for total chaos, but still want uniball, mcm might be your pick.
  19. Feb 24, 2021 at 8:35 AM
    #49
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    TC has a 1" ID uniball. You're thinking of Camburg.
  20. Feb 24, 2021 at 8:44 AM
    #50
    Gumby
    Gumby New Member
    Taylor
    I'm a buy once cry once kinda guy. Thanks for the advice! :thumbsup:
  21. Feb 24, 2021 at 9:24 AM
    #51
    TFTundra
    TFTundra New Member
    Yep, you’re right. Thank you for correcting me. So, in that case, I’d probably hit up mcm over total chaos just for the cost difference!
    GravityGear[QUOTED] likes this.
  22. Feb 24, 2021 at 9:30 AM
    #52
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Note to those thinking about doing the 2.5" on the front: You will very likely need to clearance the lower arm in this area to make sure there is no contact at full droop.
  23. Feb 24, 2021 at 9:42 AM
    #53
    TFTundra
    TFTundra New Member
    Didn’t you do the 0-2” kit?
  24. Feb 24, 2021 at 9:51 AM
    #54
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Yes. 0-2" kit. Elka says "some" trucks will need this, mine did. It isn't bad, but you do need to check it and be prepared to do it right then if it needs doing. Otherwise you could have damage and need to tear it all apart again. Hate doing work twice.
    Link (see step 4): https://elkasuspension.dozuki.com/Guide/TOYOTA+TUNDRA+2007+/133
  25. Feb 24, 2021 at 10:02 AM
    #55
    TFTundra
    TFTundra New Member
    Roger. Good looking out. Honestly I was considering elka just because of the 0-2” kit not needing UCAs, but with that clearance issue potential, I’ll probably stick to kings and some UCAs and call it a day.
  26. Feb 24, 2021 at 10:27 AM
    #56
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Understood. Felt a little odd taking the grinder to my truck at three months old, but the Elka 2.5 DC coilovers + Durobumps in front is a really great combination.
  27. Feb 24, 2021 at 10:39 AM
    #57
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Your pic didn't work... Imma probably be going this route myself as I'm intrigued by the ability of the aluminum to hold up better in the great white north here. Not excited about grinding on a new rig, but it had to happen eventually!
  28. Feb 24, 2021 at 11:35 AM
    #58
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Hey man exactly the look I'm going for. Can you tell us your setup lift and tires please
  29. Feb 24, 2021 at 12:00 PM
    #59
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    Can anyone tell me if there is a difference in ride quality between the 0-2 shocks at 2 inches and the 2-3 shocks at 2 inches?
  30. Feb 24, 2021 at 12:27 PM
    #60
    TFTundra
    TFTundra New Member
    If they’re both the same diameter shock, either 2.0 or 2.5, I would imagine not. I think the spring rate for the 2-3” kit is higher, so if you’re stock front weight, it may ride rougher. If I’m not mistaken, the 0-2” kit uses 16” 700lb springs and the 2-3” kit uses 16” 750lb springs.
    70m4h4wk[QUOTED] likes this.
