Toyota Tundra Vated 6" Adjustable Coilovers
Discussion in 'Suspension' started by Mickale, Aug 2, 2019.
  1. Aug 2, 2019 at 5:10 AM
    Mickale
    Mickale [OP] New Member
    2008 Silver Tundra Limited
    A fucking lot.
    Black Wolf and Rica25 like this.
  2. Aug 2, 2019 at 6:02 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Here is another option for you, but they are not adjustable.
    TXRailRoadBandit73 likes this.
  3. Aug 2, 2019 at 6:08 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I didn't have the 6 inch version, but have the 3 inch. They lasted roughly 100k miles before they blew all the shock oil out in my wheel wells. They havent been bad, but not the most comfortable ride. I paid less than 500 dollars for mine and feel like that was a pretty decent price for an adjustable coilover with 700 pound springs.
    Black Wolf likes this.
  4. Aug 2, 2019 at 7:04 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    recently there was a thread on a guy using these on a 6 inch lift. cant find it at the moment but it was with in the last couple month...i was interested as well but iirc he had a bad experience.
  5. Aug 2, 2019 at 7:05 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    i watched bc i too am interested in replacing my pro comp coils 6 inch lift. you can also use radflo ($1200) or pro comp coils ($900) as an fyi..
  6. Aug 2, 2019 at 8:21 AM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    I think @15Yota is running them if I remember correct.
  7. Aug 2, 2019 at 5:36 PM
    Mickale
    A fucking lot.
    Do you happen to know of a part number for those? How do they ride?
  8. Aug 2, 2019 at 5:37 PM
    Mickale
    A fucking lot.
    100k miles seems like a good bang for the buck to me.
  9. Aug 2, 2019 at 5:40 PM
    Mickale
    A fucking lot.
    Are you talking about the Procomp Mx2.75 coilovers? I've tried finding them separate from the stage 2 kit but have had zero luck.
  10. Aug 2, 2019 at 6:56 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
  11. Aug 2, 2019 at 7:02 PM
    Yep, just got mine delivered today. Set at 2.75". The 6 inchers can be problematic depending on wheel offset, back spacing, lift brackets, and whether using stock UCA's or aftermarket.
  12. Aug 2, 2019 at 9:23 PM
    Mickale
    A fucking lot.
  13. Aug 3, 2019 at 3:42 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
  14. Aug 3, 2019 at 4:15 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Yes. You have to call pro comp. They call it thier "black box" $900
    Mickale[QUOTED][OP] likes this.
  15. Aug 3, 2019 at 4:42 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Ok, We (my shop) has installed all different configurations that we're discussing here. Here's our findings...
    1. We installed the FBG 3" coilovers on my shop truck to level the front. Ride was great, similar to OEM, just a tad stiffer. By stiffer, I mean more control, less roll.. Good stiffer LoL
    2. We had installed a 6" lift and tried using these coilovers, along with the 6" lift kit spacers on top (none in the preload as the coilovers were already there) in the build. They worked, but made it ride crazy stiff. I mean, it rode like shit, like chatter your teeth out stiff. The geometry change along with these coilovers would not work. We installed many lifts, including 2 other Tundras with the spacers, and none were as stiff as it was when the spacers and these coilovers were paired up. We loved these coilovers, just not stacked with a full lift.
    3. Rough Country 6" Lifted strut install. We used the OEM coil spring, no preload spacer (per instructions) and no top out spacer. Just the coil and the strut. We couldnt wait to drive it after we put the truck back down on the ground. The ride is awesome to say the least. It is a comfortable, controlled ride. The only thing making it a little on the rough side now, are the 37's... They're heavy. Other than that, we couldnt be happier. For the price, everyone tends to shy away, but we are a RC dealer, so we figured we'd give them a shot. So glad we did. Such an improvement.
  16. Aug 3, 2019 at 6:27 AM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    1BadTundra you wrote:
    "1. We installed the FBG 3" coilovers on my shop truck to level the front. Ride was great, similar to OEM, just a tad stiffer. By stiffer, I mean more control, less roll.. Good stiffer LoL"
    Was that the FB branded shock or the FB Bilstein as you show in your picture?
  17. Aug 3, 2019 at 6:39 AM
    1BadTundra
    Clinton
    Too Much to List
    The one in the pic is an FB shock, with custom internals.
  18. Aug 3, 2019 at 7:52 AM
    Mickale
    A fucking lot.
    Have y'all installed the FBG 6" coilovers? We're they not available when you installed a fbg 3" coilover with the spacer?
  19. Aug 3, 2019 at 8:26 AM
    1BadTundra
    Clinton
    Too Much to List
    We bought the 3" just to level up the truck. Ran them for a little while, then decided to go the full 6" lift. I opted away from the 6" for 2 reasons... One was price vs the 6 RC lifted strut, Two was the fact that we never bothered to adjust the 3", and I doubt we'd ever go under to adjust the 6". Why buy a 6" lifted coilover, just to always be under there messing with the collars. I figured Fukit, just get the 6" and be done.
    jeremyd and Black Wolf like this.
  20. Aug 3, 2019 at 8:27 AM
    RDRunner
    RDRunner New Member
    The first picture of the shock laying on a box clearly says Bilstein on it and your quote about putting FB 3" on your company truck does not say which one you put on the truck--Bilstein or the FB branded. I assume you are saying it was FB branded. I agree that it may not be worth paying for the adjustment collar--I can almost buy the 6112 for what the FB Bilstein costs. Same for the toytec 5100 with the adjustment collar. Too much money for just the ability to adjust IMO.
  21. Aug 3, 2019 at 8:36 AM
    1BadTundra
    Clinton
    Too Much to List
    They are the same shock. Its an FB body with Bilstein internals... They were a custom build. These are not 6112's nor are they 5100's. They are a FB shock body, revalved and tuned.
    I agree about it being too much money to just have the adjustment... Especially considering we never used the adjusters... They came outta the box at 2.5", and that's where we left them.
    Mickale[OP] likes this.
  22. Aug 3, 2019 at 10:36 AM
    RDRunner
    RDRunner New Member
    That explains it the Bilstein sticker then.
    On another note, what strut mounting kit (top-plate and hardware for assembling a strut without using the old ones) is closest to the Toyota original including quality? I see KYB, Monroe, etc. The Toyota parts are pretty pricy. I don't want to buy junk. I am going to buy Bilstein 6112 and assemble a set before I pull off the factory coils.
  23. Aug 5, 2019 at 12:43 AM
    1BadTundra
    Clinton
    Too Much to List
    I dont think you can go wrong with KYB, I thought Bilstein made one too.
    RDRunner likes this.
