Toytec Lifts
Discussion in '2.5 Gen Tundras (2014-2021)' started by WreckedRooster, Dec 30, 2022.
  1. Dec 30, 2022 at 9:22 AM
    WreckedRooster
    WreckedRooster [OP] New Member
    Jake
    Just did a Toytec 2.5 coilover up front, with the Icon RXT pack in the rear and Toytec 2.0’s in the rear. Toytec states these shocks are good for a 1-3” lift but the pic below is what I’m looking at after installing the leafs and then trying to install the shocks.
    I lifted the axle to mount the shock but I’m guessing this isn’t good. Thoughts?
  2. Dec 30, 2022 at 9:34 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
  3. Dec 30, 2022 at 9:59 AM
    WreckedRooster
    Jake
    Kinda what I’m guessing, but I called Toytec and talked to their technical team and they said it was normal and not to worry.
  4. Dec 30, 2022 at 10:04 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Did you already pull the shock to full droop?
  5. Dec 30, 2022 at 10:06 AM
    WreckedRooster
    Jake
    after setting the truck on the ground. I lifted the rear axle to the shock, mounted it and set it back on the ground. Been driving like that for 2 weeks now. What started me guessing this, is I only have about 1/2” of rake from front to rear. Front set at 2.5” and the rear pack setup at 1.75”.
    my measurements after the lift are 25.5” up front and 26” in the rear. Center of hub to fender.
  6. Dec 30, 2022 at 10:24 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That all sounds pretty close to what you should get - what exactly is your question now?
    Edit: did you get an alignment done on the front? I guess that does seem a little high up there, but the rear measurements are pretty close to what you'd expect.
  7. Dec 30, 2022 at 10:28 AM
    WreckedRooster
    Jake
    Just making sure the shocks in the rear are okay as is or do I need to look into longer shocks? Are they a “limiting strap” for the rear suspension?
  8. Dec 30, 2022 at 1:07 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Well your rears are already within the 1-3” of lift range so I highly doubt you’d need to go anywhere crazy as far as adding limit straps to your rear.
    What is the application for your truck? Unless if you’re running washes and bombing through dunes, then limit straps would be something you’d look into.
  9. Dec 30, 2022 at 1:14 PM
    WreckedRooster
    Jake
    nothing crazy at all. I’ve installed other lifts and haven’t had the shock reach the bottom and top mount. I was worried that the rear leafs would extend (down travel) past what the shock could handle. Turning the shock into a limiting strap for the suspension so to speak.
