TPMS in spare?
Discussion in '3rd Gen Tundras (2022+)' started by aaronlee, Aug 27, 2023.
  1. Aug 27, 2023 at 9:09 AM
    aaronlee
    aaronlee [OP] 2023 Tundra Limited 4x4
    Los Angeles, CA
    I heard the new Tundras now allow for 8 TPMS sensors to be connected whereas my 2011 only allowed 4.
    Does anyone know whether the 2022+ spares now come with TPMS? I have a 2023 Limited. thanks! -Aaron
  2. Aug 27, 2023 at 9:17 AM
    Tom
    Tom New Member
    Probably not. If there’s a 5th it should show on screen like on the Gx460.
  3. Aug 27, 2023 at 9:38 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I only see 4 sensors on the truck screen and on the app as well. I can run extra sensors on my trailer TPMS system so I can add my spares (truck and trailer) to that screen when travelling with the TST screen running. At least I have a work around for the spare. If I put the spare on the truck in place of one of the "in use" wheels then I will get bugged by the truck's TPMS warning system.
  4. Aug 27, 2023 at 10:55 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    With a sensor in the spare, it picks up all 5.
    TK1979, Toyotoholic, Mike59 and 9 others like this.
  5. Aug 27, 2023 at 11:08 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Yep, this accurate. I had a blow out flat and had to run the spare for a 100 miles and it threw warnings the whole time
  6. Aug 27, 2023 at 11:41 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    That’s so smart of Toyota!
    TK1979 likes this.
  7. Aug 27, 2023 at 11:52 AM
    aaronlee
    Los Angeles, CA
    Thanks gents! Good to know it picks up the spare as well as on trailer mode! Much appreciated.
    iiawah808 likes this.
  8. Aug 29, 2023 at 5:40 PM
    tcap23
    tcap23 New Member
    Patrick
    2023 Capstone
    this is moving this thread a little, but I cannot seem to find the screen that shows the pressures. I did have it on one time, but can never find it now. My Capstone has the full digital screen. I go to the Settings then go down to the TPS, but can never see the screen. I do see the screen to reset and change PSI to kPs. I do this with truck running but in Park. The owners manual tells so little of how to get to this screen.
    Any help or suggestions appreciated.
    thanks
    PT in Tennessee
  9. Aug 29, 2023 at 6:21 PM
    brutalitybob
    brutalitybob New Member
    badass!
  10. Aug 29, 2023 at 6:30 PM
    blenton
    blenton New Member
    I would have been very surprised if it didn't monitor the spare tire TPMS. My '13 monitors the spare even though it isn't shown directly on the head unit (Pioneer Avic7200NEX interfacing via idatalinkMaestro). I just have to toggle through a menu item and it displays the spare tire info. I can't speak to whether or not they allow for 8 saved TMPS ID's, but that would be nice.
  11. Aug 30, 2023 at 5:27 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    I don't know it actually "saves" eight, five or a dozen IDs; instead it just seeks out the TPM frequency at each wheel (including spare) and then registers it for that particular location. System still requires a TPM search and reset (with some driving) with seasonal wheel changes.
  12. Aug 30, 2023 at 5:29 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I wish my 2019 did that. I have a full sized matching spare with TPMS, but have to "relearn" when I rotate that wheel in.
  13. Aug 30, 2023 at 6:32 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    On the left hand side of your steering wheel you'll have left,right up & down buttons,so use the right side button and push it several times as your doing this look at the top left of your speedo cluster you'll see that your toggling to the right from the leaf icon ect move to the one just before the gear icon "Settings icon".
    Once you get there depress the down botton I think 3 X and you'll see the tire pressure on all tires.
  14. Sep 6, 2023 at 2:50 PM
    aaronlee
    Los Angeles, CA
    So picked up a full size oem wheel and tire and new toyota tpms and unfortunately i programmed it with the MaxiTPMS tool but even after loading it in to the ecu the spare isn’t being pickes up by the ecu. I wonder if different markets allow for a spare to be displayed tbh as i showed the picture Dekeman posted to the Toyota dealer and they look confused. hah.
  15. Sep 6, 2023 at 3:30 PM
    coTony
    Tony
    Montrose, CO
    My spare is not being picked up either. I will have to get the Techstream out and see if I can set it up
  16. Sep 12, 2023 at 6:13 AM
    coTony
    Tony
    Montrose, CO
    It does not automatically add a spare tire simply by adding a TPMS sensor, at least it does not on my 2018 Platinum. I have been searching everywhere trying to get this enabled and Techstream cannot do it or I don’t know how to do it. When using the ID Registration utility it shows how many total tires there are. I cannot just “add” a TPMS ID by itself, you have to add all at one time so the number of tires is key. I may very well not be using Techstream correctly since you learn as you go with the software
  17. Dec 25, 2023 at 9:02 AM
    Dtrancrx
    Dtrancrx New Member
    Has anyone else tried this and was successful?
  18. Dec 25, 2023 at 10:54 AM
    40man
    40man New Member
    Worked great for my on my 23 after enabling in Techstream.
    Dtrancrx[QUOTED] likes this.
  19. Dec 25, 2023 at 1:30 PM
    Dtrancrx
    Dtrancrx New Member
    Do you remember what u enabled or have a pic of what u enabled?
  20. Dec 25, 2023 at 1:42 PM
    40man
    40man New Member
    When I went to the TPMS section it had a pop-up that asked if I wanted to change to a 5 tire setup. Was pretty intuitive.
    TK1979, Dtrancrx and Kerbouchard! like this.
  21. Dec 25, 2023 at 2:11 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    This would be pretty awesome idk why it's not standard if the capabilities are there.
  22. Dec 25, 2023 at 2:52 PM
    40man
    40man New Member
    Because they dont put a sensor in the spare. Saves Toyota $. I added because I like to run a 5 tire rotation...
    TK1979 likes this.
  23. Dec 25, 2023 at 3:22 PM
    Hoody
    Hoody Member
    Kommiefornia
    Gotta save that $10 cost on a $70k truck. Should at least come in the premium trims like plat and up. How hard or expensive is it to setup or to buy techstream? I don't have techstream or know much about it. This could be a cool how to...
  24. Dec 25, 2023 at 5:04 PM
    40man
    40man New Member
    Need a windows laptop. I recommend the VXDiag cable that comes with a hacked (key bypass) software. Most of the cheap cables on Amazon won't work for TPMS or other advanced functions. Plenty of Techstream writeups.
  25. Feb 17, 2024 at 6:15 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I have a matching 5th wheel+tire for 5-tire rotations and to ensure I can get out of the deep backcountry if I should puncture a tire. When I purchased the setup I bought an extra OEM TPMS sensor and had it installed in the 5th wheel.
    I recently had the dealer enable the spare tire pressure readout in the instrument cluster in my 2023. It looks exactly like the pic @dekeman posted above. It’s really nice to have a readout on the spare tire pressure and to have all 5 TPMS IDs stored in the ECU as it makes tire rotations a breeze.
    Thanks to @dekeman for the idea!
    Kerbouchard! likes this.
  26. Feb 17, 2024 at 6:22 PM
    Kerbouchard!
    Kerbouchard! New Member
    Denver
    any issues explaining to the dealer what to do, or did they make the update without question?
  27. Feb 17, 2024 at 6:33 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Anyone have the part number for the tire pressure sensor that can go in the spare?
  28. Feb 17, 2024 at 6:34 PM
    Cassidy1866
    Since the truck was due for service and multiple safety recalls and service bulletins, I made them a list. Included on that list was, “Techstream: activate 5-tire setup so truck permanently recognizes TPMS in spare.” Neither my service advisor nor the tech had questions. They didn’t charge me (maybe because I’m a longtime customer) but even if they had I would’ve paid as I believe this change requires Techstream and I’m no software engineer.
    Kerbouchard![QUOTED] likes this.
  29. Feb 17, 2024 at 6:40 PM
    Cassidy1866
    You can find cheaper options aftermarket but if you want OEM the part number I used is 42607-02050.
    Tundrastruck91 likes this.
  30. Feb 17, 2024 at 6:46 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Is that the ones that have a rubber valve stem?
