TPMS malfunction message.
Discussion in 'Wheels & Tires' started by emdcksn, Aug 14, 2020.
  1. Aug 14, 2020 at 6:02 PM
    emdcksn
    emdcksn [OP] New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    I swapped over to the stock wheels and Cooper’s for something different for a while. Reset the TPMS system and after a while I got a message “Tire Pressure Warning System Malfunction See Dealer”. Is there a way to get rid of the message and reset the system without going to the Stealership? The sensors are new and have never been on the truck before.
  2. Aug 14, 2020 at 8:24 PM
    emdcksn
    Eugene
    Eugene OR
    Found this on a web search. It fixed everything. Thanks.
    @7.62X51 posted this:
    TPMS Relearn Button on 2018 Toyota Tundra and Sequoia 1. Ensure all tires are inflated to the pressure listed on the tire placard. 2. Start the engine and keep the vehicle in PARK. 3. Press the Tire Pressure Reset button three times. 4. Drive the vehicle for 10-30 minutes at 25mph or faster and the light will turn off once the sensors are registered. Refrain from reversing and driving in heavy traffic during the relearn process. 5. The Tire Pressure Reset button must now be pushed and held down until the TPMS light blinks three times to set the baseline tire pressures. 6. Drive the vehicle for 10-30 minutes, staying above 25mph when possible, and the light will turn off once the current tire pressure values are accepted.
    Found it here. https://www.tundras.com/threads/tpms-sensor-re-calibrating.42293/
    Terndrerrr and 831Tun like this.
  3. Aug 14, 2020 at 8:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I wish this'd work for a '16. I tried but it didn't seem to work. When I get time I'll try techstream
    emdcksn[QUOTED][OP] likes this.
