TPMS sensors not working with aftermarket rims and tires
Discussion in 'Wheels & Tires' started by Matguy34, Aug 7, 2021.
  1. Aug 7, 2021 at 4:20 PM
    Matguy34
    Matguy34 [OP] New Member
    Hey all. I’m wondering if anybody has been able to program their TPMS sensors. I switched to Goodyear wranglers that require 60-80 psi. My TPMS sensors work fine under 50 PSI but as soon as I go above 50 my sensors stop registering and the yellow light comes on. I can’t run the tires under 50 PSI because the sidewalls damn near touch the pavement. If I do this I’ll get flats while driving dirt roads at work.
  2. Aug 7, 2021 at 4:31 PM
    Kanobi13
    Kanobi13 New Member
    Hmm. I run duratracs 36 front 38 rear must be bumpy ride!
    Edit: when i tow and bump to 80 i do not any warnings.
    Saltyhero13 likes this.
  3. Aug 7, 2021 at 5:17 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There isn’t a half ton truck on the road that requires 60-80 psi in the tires. In fact, the capacity of a half ton truck would never surpass the requirement of 55-60 psi in the rear tires for any LT tire. I run 36/39 in mine. First and foremost, Your tires are aired up way to much.
    Second, you need to push the reset button on the dash.
  4. Aug 7, 2021 at 5:20 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    36 front and 38 rear for my e plys, confirmed with a chalk test.
    landphil likes this.
  5. Aug 7, 2021 at 5:59 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If you air the tires up to 120psi, the lights will probably go out. Your lights, that is. Nice troll thread…
  6. Aug 8, 2021 at 9:23 AM
    Matguy34
    Do they call you landphil because you’re garbage? It’s not a troll. I’ll let my tires down to 35 psi and show you what it looks like. Visibly low. Not good for oilfield roads. I haven’t had them at 80 psi. But at 50-60 WHERE THEY SHOULD BE ACCORDING TO MANUFACTURERS SUGGESTION. My TPMS system does not work
  7. Aug 8, 2021 at 9:30 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
  8. Aug 8, 2021 at 9:56 AM
    Matguy34
    Looking to program the sensors so they read at 60 psi not disable the system
  9. Aug 8, 2021 at 10:14 AM
    Kanobi13
    Kanobi13 New Member
    Let us know how the tires do pumped up so high on the oil roads
  10. Aug 8, 2021 at 10:21 AM
    Danman34
    Danman34 New Member
    Danny
    If your tires are riding the sidewalls at 35 psi, then your tires are defective and shouldn’t be driven on. You would also be the only person who puts more air in the tires to drive off road. More air pressure only increases your chances of puncture or damage.
  11. Aug 8, 2021 at 10:22 AM
    Matguy34
    Are you simple? Go drive on a dirt road with your tires at 35 psi and tell me how your two ply sidewalls do. Also my Toyota has lots of weight in the box. So yes 35-40 psi won’t do
  12. Aug 8, 2021 at 10:25 AM
    Danman34
    Danman34 New Member
    Danny
    Are you simple? You don’t seem to understand physics, that’s for sure. I’m using a Toyo AT2 Xtreme LT295/55/20 tire by the way, which is a hell of a lot more of a heavy duty off road tire than the Goodyear wranglers.
    Rodtheviking likes this.
  13. Aug 8, 2021 at 10:35 AM
    Matguy34
    Deflate them to 35 psi. Throw a tidy tank some tools in the back and drive down some gravel roads. Let me know how it goes
  14. Aug 8, 2021 at 10:42 AM
    Matguy34
    I’ve had flats from uninflated tires on bush roads before. In a lightweight Nissan Frontier. You city folk should educated yourself a bit before talking trash
    ATV25 likes this.
  15. Aug 8, 2021 at 9:18 PM
    Matguy34
  16. Aug 8, 2021 at 9:18 PM
    Matguy34
    Read the part about the 275/70/R18’s then tell me again about the 35 psi thingy
  17. Aug 8, 2021 at 9:20 PM
    Matguy34
    Maybe all 4 of my brand new tires are defective and I should try a new set at 35-40 psi.
  18. Aug 9, 2021 at 9:31 AM
    Danman34
    Danman34 New Member
    Danny
  19. Aug 9, 2021 at 9:32 AM
    Kanobi13
    Kanobi13 New Member
    Nailed it!
    IgotSR5onit and Rodtheviking like this.
  20. Aug 9, 2021 at 11:14 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Maybe the harsh ride will jiggle the OP’s brain cells back together to take some advice and not take people deep that are trying to help…:)
    AZBoatHauler and TG705[QUOTED] like this.
  21. Aug 9, 2021 at 11:17 AM
    Elduder
    Elduder New Member
    Those are max tire pressure ratings, not the intended running pressure ratings. Typical running pressures are between 30-40psi.
    Yours are the E load range correct?
    If they are SL you would see some deformation at lower pressures, especially with extra weight as SL is typically designated for light truck, more so passenger vehicles.
    AZBoatHauler likes this.
  22. Aug 9, 2021 at 11:23 AM
    Matguy34
    They max 80 psi. I run them at 60. TPMS sensors don’t work at 60
  23. Aug 9, 2021 at 11:27 AM
    Kanobi13
    Kanobi13 New Member
    The sensors work just do not give you correct reading as you have changed your truck from stock parameters.
  24. Aug 9, 2021 at 12:03 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    change ur sensors
  25. Aug 9, 2021 at 12:11 PM
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    Just a thought...
    There is the TIRE manufacturer specs that you can fall WITHIN...
    Then there are the TRUCK manufacturer recommendations.
    I grew up on a farm, I run my own farm now, we have everything from 4 wheelers to 8 wheel tractors...and a lot of full size "light duty" trucks ( i.e. Tundras and the like) ..... All of us run 34-36 PSI. In any tire on our trucks.
    For heavy duty trucks it IS higher.
    For what it's worth, I just did buy a set of tires, the whole set was defective...so is it possible? Yup. I'd consider returning to manufacturer. Or, consider another tire. But, as someone who rides farm roads and frequents fields and trails for fun....I only from from 34-36 psi and adjust downward to around 15-20.
    Not sure if any of those thoughts are helpful, but God bless and good luck.
  26. Aug 9, 2021 at 12:15 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Max pressure and operational pressure of tire are two different things, 45psi should be plenty. You don't need 50 or more psi on Tundra. Maybe on heavy duty trucks like f350 or similar but not on tundra. And not being an ass also helps when you look for an answer. If everyone here tells you one thing but you still insist on you being right, maybe it's just you didn't do proper research before asking.
    iHacker likes this.
  27. Aug 9, 2021 at 12:31 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup. Nope. Who knows. But @ColoradoTJ can confirm that I’m a funny ‘tard. :D Maybe @T-Rex266 can too??
    Duhuuhhuuuhuuhhhuh!!
    ColoradoTJ likes this.
  28. Aug 9, 2021 at 12:46 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  29. Aug 9, 2021 at 12:47 PM
    IgotSR5onit
    IgotSR5onit New Member
    80 psi on dirt roads has done rattled something loose in this fellas head.
    AZBoatHauler, Rodtheviking and Oey12 like this.
  30. Aug 9, 2021 at 1:00 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    OP - Maybe you can get different TPMS sensors that would allow you to run without the dash light. As has been stated, your situation seems "unusual". It is likely that most of us who drive with loads on trails and rough roads run E load tires with stiffer sidwall and carcases. I guess my hypothetical question for you is what is the value of running P rated tires if your going to have to run them at such a high PSI that they ride (potentially) worse than an E-load tire that could be run at a more "reasonable" pressure with much less risk of puncture or destruction? Good luck finding whatever works best for your situation. (edit...if you are running
    GOODYEAR WRANGLER TRAILRUNNER AT LT275 /70 R18 125R E1 OWL then disregard my p rated comment...fyi i run 20 psi while offroad without popping driving over sharp rocks at close to payload capacity with my BFG KO2 )
    Others: I'd love to learn something from this...Am i wrong to read the screenshot that the OP posted with a MAX LOAD RATING of 3638 lbs at a MAX pressure of 80 psi that would be needed to support that max load (or if weight was evenly distributed a vehicle weighing 14,552lbs). If this is so far true, could we also use "math" to ball park an appropriate starting pressure for a fully loaded Tundra? For example: (80 * <vehicle weight>) divided by 14,552 would give us a reasonable number to set the tires at before using the chalk test? (FYI 7,500lb returns 41.23 psi in this example and seems reasonable to me)
