Trailer harness relocation?
Discussion in 'General Tundra Discussion' started by CaptSpaulding, Apr 3, 2019.
  1. Apr 3, 2019 at 4:10 PM
    CaptSpaulding
    CaptSpaulding [OP] ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    After destroying my 2nd trailer harness connector while running the Mohave Trail, I need a better location for it. I did read up on the DIY relocation thread, but don't want to sacrifice a license plate light for it.
    Does anyone have any ideas to get it out of the way while offroading? What do you other offroading Tundras do?
    For some reason, @2ndgenny came to mind as we think alike on several threads...although with those giant 37s, I doubt that connector will even be an issue for you.
    Thanks in advance
    Jrharvey02 and Mountun Goat like this.
  2. Apr 3, 2019 at 4:22 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Of course I do haha. I relocated mine in one of the plate light holes
  3. Apr 3, 2019 at 4:22 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ll get a picture later today for ya
    CaptSpaulding[OP] likes this.
  4. Apr 3, 2019 at 4:25 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Thank you sir!
    Mountun Goat likes this.
  5. Apr 3, 2019 at 4:50 PM
    taco supreme
    taco supreme New Member
    16 white CM 1794
    I wonder if the relocation bracket for the Tacoma’s will work for tundra?
  6. Apr 3, 2019 at 4:52 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Hmmm, what does it look like? 4 & 7 pin options?
  7. Apr 3, 2019 at 7:47 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Mine doesnt have the 4 pin but all you have to do is cut a bigger hole.
  8. Apr 3, 2019 at 10:26 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I was thinking about the same spot, but worried only 1 license plate light wouldn't be enough?
  9. Apr 4, 2019 at 4:56 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    One led bulb seems plenty bright. I haven’t put an led in and the single halogen does the trick still
  10. Apr 4, 2019 at 6:38 AM
    taco supreme
    16 white CM 1794
  11. Apr 4, 2019 at 8:21 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
  12. Apr 4, 2019 at 8:57 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
  13. Apr 4, 2019 at 9:16 AM
    dumbassdave
    dumbassdave Member
    Dave
    The factory one didn't have holes or a edge to flush mount it as it comes from the factors in that metal bracket. It might be possible to sort something out with the factory one though....
    Jrharvey02 likes this.
  14. Apr 4, 2019 at 9:28 AM
    Jrharvey02
    Ahhh, I see, thanks. What tool did you use to get thru chrome bumper? I’m thinking diamond tip dremmel cutting wheel after drilling a few pilot holes with drill bit...any tips appreciated....
  15. Apr 4, 2019 at 9:40 AM
    dumbassdave
    dumbassdave Member
    Dave
    I used a hole saw as its basically round on the back. There is a little bump on the top of the connector that I used a dremmel to cut out for. Using a dremmel to cut out the whole thing would be a bit tedious I'd think. If I remember correctly, it wasn't all metal behind there... best to take a look. I used a sawsall to trim the original mounting bracket flush with the hitch and put some rust paint on the cut.
    Mountun Goat and Jrharvey02 like this.
  16. Apr 4, 2019 at 10:13 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Thanks guys, great input, I have several ideas floating around now. After my monthly shoulder draining today, I'll dig in and see what I can come up with. Pics to follow
  17. Apr 4, 2019 at 11:39 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Please no monthly shoulder drainage pics.:puke:
