Transfer case actuator motor replacement
Discussion in '1st Gen Tundras (2000-2006)' started by F-101B, Sep 18, 2021.
  1. Sep 18, 2021 at 6:14 PM
    F-101B
    F-101B [OP] New Member
    2000 Tundra 4.7L SR5 4x4
    My transfer case motor is shot on my 2000 tundra SE5XS cab four-door four-wheel-drive 4.7 V8. Does anyone have a recommendation on a replacement motor source?
  2. Sep 18, 2021 at 6:29 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Sep 18, 2021 at 6:31 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Just a couple options, really. New or used Toyota actuator or a DORMAN aftermarket unit. I went with a used actuator from
    https://www.japanesetruckdismantling.net/
    I highly recommend JTD... good people
    Welcome aboard!
    bmf4069 likes this.
  4. Sep 19, 2021 at 5:35 AM
    F-101B
    THANK YOU for the replies!!!
    The first commentor presents a very, very interesting site end it shows new OEM in Canada... I'll have to check on them because of the import tax issue. I would not mind used, but I have seen where this actuator has gone bad early as well as at the 250,000-mile-mark of my Tundra..... I located the source before posting here that showed parts sitting in Japan- again, the important issue is a mystery
  5. Sep 19, 2021 at 8:10 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    These are usually very robust units, as long as they’re operated on a regular interval. The biggest contributor to failure is usually non-use. My used actuator came off a truck from California, and it really did look new when I received it.
    Considering the tax implications of importing used parts from the states, I can understand your apprehension.
    Buy the best and you only cry once…
  6. Sep 19, 2021 at 5:05 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Have you tried rebuilding the one you have? Usually they just fill up with crud. Unless the motor is burned up you might be able to save it.
