Transfer Case Actuator Problems - Poll
Discussion in '2.5 Gen Tundras (2014-2021)' started by mverkaik, Nov 22, 2022.
Actuator Problems? When?
  1. Yes, Never changed my fluid.
    0 vote(s)
    0.0%
  2. Yes, I use gear oil.
    4.0%
  3. Yes, I use non-Toyota 75W
    6.0%
  4. Yes, I used Toyota 75W transmission fluid
    0 vote(s)
    0.0%
  5. Yes, I used Toyota 75W transfer case fluid
    4.0%
  6. No, Never had a problem (please let us know what oil you use)
    86.0%
  1. Nov 22, 2022 at 10:33 AM
    mverkaik
    mverkaik [OP] New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I am creating a poll in an effort to better understand the failure.
    I have read that the Transfer Case manufacturer will not endorse using any fluid except of the Toyota 75W Transfer Case Fluid.
    I have read a lot of posts on Tundras.com as well as other places of people using all kinds of different oil.
    I have read a lot of posts about actuator problems.
    My 2015 suffered from actuator problems at about 100,000 miles. It would not shift out of 4-LO well.
    I changed my T-case fluid every 30,000 miles with Mobil 1 75W90 gear oil.
    I was not very good about using 4x4 monthly.
    I never did get to the bottom of it before the truck was taken from me.
    I loved the truck so I purchased another 2.5 Gen and have about 10,000 miles before I have to change the fluid again.
    Here is my question:
    Year and mileage of your truck?
    Have you had actuator problems?
    When did the issues start?
    What oil have you used and how frequently have you changed it?
  2. Nov 22, 2022 at 11:17 AM
  3. Nov 22, 2022 at 11:23 AM
    mverkaik
    Hamilton, MI
    For 2014 Toyota started using a Borg Warner T-case. This case uses a soft engage clutch similar to the Auto system used by Ford and GM. Nobody really knows what is special about the Toyota fluid but Borg Warner will not certify a different fluid.
    Y0TA PR0 likes this.
  4. Nov 22, 2022 at 11:46 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I voted yes Toyota 75w , but No I don't/didn't have a failure.
    So I voted wrong... OOOPS
  5. Nov 22, 2022 at 12:04 PM
    mverkaik
    Hamilton, MI
    I bet we can fix it. Thank you for letting us know.
  6. Nov 22, 2022 at 12:09 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    No problems here, but I am using Ravenol 75W in my transfer case, just did a change at 95k miles, and it shifts more smoothly into/out of 4-HI (haven't tried 4-LO yet but I should, eh?)
    Terndrerrr likes this.
  7. Nov 22, 2022 at 12:11 PM
    mverkaik
    Hamilton, MI
    I have read a bunch of threads. I would like to see if there are failures with all of the fluid options. I suspect that the Toyota fluid is special……. Let’s see if the data talks.
  8. Nov 22, 2022 at 12:14 PM
    I do believe you’re correct.
  9. Nov 22, 2022 at 12:15 PM
    mverkaik
    Hamilton, MI
    Mine worked great in 4-HI. 4-LO was another story. It would not come out. Eventually I was able to coax it back to HI and then to 2.
  10. Nov 22, 2022 at 12:19 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Are you referring to this?
  11. Nov 22, 2022 at 12:20 PM
    mverkaik
    Hamilton, MI
    You can change your vote now. I fixed that :)
    Bammer[QUOTED] likes this.
  12. Nov 22, 2022 at 12:22 PM
    mverkaik
    Hamilton, MI
    I think so. I assume that is your actuator :)
  13. Nov 22, 2022 at 12:27 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine was replaced around 50k. Was increasingly slower to get out of 4H and it caused a clunk sound to occur when it would transition. My mechanic got warranty to cover it. Was running stock Toyota fluid at the time. I'm now running 75W HPL. No issues.
    Odometer is ~75k
  14. Nov 22, 2022 at 12:57 PM
    timsp8
    NY
    2018 truck. I’ve changed mine twice. Don’t remember the exact mileage when I did it, but I have 54k now. I used ravenol 75w. No issues. I use the 4wd a lot in winter and hardly any all summer.
  15. Nov 22, 2022 at 1:56 PM
    AZBoatHauler
    So.Arizona
    No problems but seeing VOA I’ll only run the Toyota oil. It has a very unique additive pack. I’ll be doing changes every 60-70k miles. At 80k now - lots of 4lo use and some 4hi.
    BlueRibbon4x4 likes this.
  16. Nov 22, 2022 at 4:13 PM
    Bammer
    Monroe, CT
    Revoted.
  17. Nov 23, 2022 at 2:33 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    36k miles on the Tundra. Filled TC w/ Ravenol just before hitting 30k. It shifts into 4Hi and 4Lo quickly and smoothly.
  18. Nov 23, 2022 at 4:40 AM
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    No Problems. Ravenol at 30,000 miles
  19. Nov 23, 2022 at 5:06 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    2020 Platinum, changed at 20k with Ravenol 75W, no problems with engagement
  20. Nov 23, 2022 at 5:34 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    2016 here 83k , changed once, engage it occasionally in summer , always in winter like now, dealer changed all drive line fluids, 4x4 service, at 75K, synth 75W90.. Never had issue with 4 HI or 4 LO..engagement/ disengagement..
  21. Nov 23, 2022 at 5:45 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I replaced all my fluids over the summer with 75-90 synthetic. Dealers will only use 75W if it is a warranty issue. No problem putting it in or out of 4H or 4L.
    Mr Badwrench likes this.
  22. Nov 23, 2022 at 5:50 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The million mile Tundras were serviced at the dealerships, who would have used Toyota's fluids. That's good enough for me.
    McCrapper and Black Wolf like this.
  23. Nov 23, 2022 at 6:00 AM
    Mr Badwrench
    Mr Badwrench New Member
    Never changed the oil or had problems. The oil probably looks like black paint in my xfer case by now lol. I live in Wyoming, I use mine quite a bit too.
  24. Nov 23, 2022 at 6:41 AM
    2mchfun
    Not sure what this "investigation" is going to prove or disprove considering the samples are of different ages, different operating conditions, and the usage or engagement cycles are all over the place. Some probably primarily use 4L, others 4H, etc. Just my .02 folks, have at it.:crapstorm:
  25. Nov 23, 2022 at 7:05 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Hmm, I’m at 29K, I guess I had better look into changing fluids. No lifetime fluids?
    WILLINH likes this.
  26. Nov 23, 2022 at 7:11 AM
    RickPlatinum2020
    Rick
    Eastern PA
    They are lifetime fluids, the lifetime of the component… which would be less than the lifetime if the fluids are changed regularly…
    AZBoatHauler and MedCityMoto like this.
  27. Nov 23, 2022 at 7:51 AM
    MedCityMoto
    I love it when dealerships say "lifetime fluid" - same claim as a single Snickers having a lifetime amount of chocolate (for the bar, of course.).
    texasrho83 likes this.
  28. Nov 23, 2022 at 8:10 AM
    Terndrerrr
    Music City
    6UR-FE
    In that sense, I guess every part is a lifetime part.
    Maybe I’ll have this on my tombstone: “He lived his entire lifetime, right up until he died.” :facepalm::rofl:
  29. Nov 23, 2022 at 8:30 AM
    MedCityMoto
    I didn't realize this was a thing until this thread came up, fortunately I've only had my Tundra since August so it's not been that long. I've used 4HI a few times, but not 4LO yet. I'll just cycle that in the driveway once a month myself from now on too.
    Sierradevil, WAtundra4x4 and WILLINH like this.
  30. Nov 23, 2022 at 8:33 AM
    NyCSnEaK
    NyCSnEaK New Member
    Yaq
    Tundra AG CM TRD
    No dealership I’ve ever asked has said they use oem gear oil. All said the same thing about using a 75w90 synthetic. I even asked the Car Care Nut and he replied back that his dealership uses the aforementioned gear oil as well.
    I don’t believe it’s fluid change interval that causes the malfunction, but the frequency of actually using your 4wd system. The actuator needs to be lubricated, so it’s doesn’t stick or self destruct.
    A lot people I know with on the fly systems only use 4wd in the snow, so a couple months a year maybe? Then nothing for 8-10 months. Sounds like a recipe for eventual failure imo.
