Transmission code
Discussion in '2.5 Gen Tundras (2014-2021)' started by AndrewSmith, May 20, 2021.
  1. May 20, 2021 at 11:25 PM
    AndrewSmith
    AndrewSmith [OP] New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    I'm browsing through a Tundra manual, figuring it's mostly the same as my 2021 Sequoia.
    The manual I'm looking at has 4 transmissions: A760E, A760F, AB60E, and AB60F. How do I figure out which one I've got?
    Thanks in advance.
  2. May 20, 2021 at 11:31 PM
    AndrewSmith
    Thornhill, Ontario
    And the cooling system? 1UR-FE, 3UR-FBE, or 3UR-FE?
  3. May 20, 2021 at 11:33 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Look on the door jamb sticker
  4. May 20, 2021 at 11:45 PM
    AndrewSmith
    Thornhill, Ontario
    Thanks!
    I can see that the transmission code is AB60F.
    Is the C/TR the cooling system code? Does that mean it's not one of the Tundra codes in the manual I'm looking at?
  5. May 20, 2021 at 11:53 PM
    AndrewSmith
    Thornhill, Ontario
    Ah, I did a VIN decoder online and it came up with Engine Model 3UR-FE. I guess that's what I was looking for.
  6. May 21, 2021 at 4:13 AM
    timsp8
    NY
  7. Aug 22, 2021 at 9:15 PM
    Manhoorn
    Manhoorn New Member
    Utah
    2012 Regilular Cab 4.6L 4wd
    Bilstein 2in level
    Lookinf for some help...
    The sticker in my door jam says A760H. Wondering if it's a typo? Everything I'm seeing online suggests it should be a A760F.
    Thoughts m
  8. Aug 23, 2021 at 2:48 AM
    timsp8
    NY
  9. Aug 23, 2021 at 10:00 AM
    Manhoorn
    Manhoorn New Member
    Utah
    Bilstein 2in level
    Checking VIN shows my truck... 2012 4.6L 4x4. Tundra grade with tow package. Only thing listed for Transmission is "6 gear auto". So it doesn't specify transmission
  10. Aug 29, 2021 at 9:51 AM
    Manhoorn
    Manhoorn New Member
    Utah
    Bilstein 2in level
    I emailed Toyota USA. They basically said "We don't have any info besides the door jamb sticker."
    I'm assuming the sticker is a typo. Ill see if I can find some identification on the Trans. Itself
  11. Dec 13, 2021 at 11:10 AM
    aruder
    aruder New Member
    I have the same code on my '10. did you ever find an answer?
  12. Dec 13, 2021 at 11:21 AM
    Manhoorn
    Manhoorn New Member
    Utah
    Bilstein 2in level
    No.
    Toyota USA basically said they didn't have a way to verify or check the code. I think the best thing to do is get under the truck and see if you can find anything identifying the transmission. Sticker or something stamped
