Transmission Cooler Bracket Kit - Hayden 679 / 689
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Jmunk, Jan 12, 2025.
  1. Jan 12, 2025 at 4:32 PM
    Jmunk
    Jmunk [OP] New Member
    2020 Tundra SR5 Crewmax
    I've designed transmission cooler brackets for the following vehicles: 2011 - 2018 Tundra with with 5.7L, 2019 - 2021 Tundra, and 2011 - 2022 Sequoia with the 5.7L. This is a budget friendly way to piece together your own transmission cooler kit. This mourning bracket utilizes already existing holes/threads.
    A PDF below contains the part numbers for the other parts needed as well as installations tips. I ordered my OEM parts from one of the online dealers and was able to get a discounted price and free shipping at the time of my purchase. They are also available and eBay and other places online. I have seen sellers on eBay that have the thermostat, inlet/outlet hoses, and hardliners bundled together in one listing for a good price.
    The bracket had been revised to use either a Hayden 679 or Hayden 689 transmission cooler. The two difference between the two coolers is that the 679 has 3/8" hose barb inlet/outlet fittings and the 689 uses threaded fittings that accept -6AN fittings. Some prefer the cleaner look with the AN fitting and others prefer the cost savings from not have to buy the AN fitting by using the 679 cooler. I've pieced together a stainless steel hardware kit that is included with each bracket.
    2011 - 2018 Tundra with the 5.7L
    Verify that you have the cooler lines behind the grill circled in red (photo below). If so, this means you already have a thermostat and hard lines for the transmission cooler. You just need to remove those lines and cap them off at the AC condenser with 3/8" vacuum port caps (photo below). After mounting the cooler you would just connect a section of 3/8" hose to the OEM hardlines already in-place, reuse the factory hose clamps. The horn will need relocated with the included hardware. You can install this in series with the cooler in the AC condenser if you wanted to.
    2019 - 2021 Tundra and 2011 - 2022 Sequoia with the 5.7L
    See the attached PDF for parts list and install instructions. The install is the same for the Sequoia as the 2019 - 2021 Tundra with the exception of the horn. I have a photo below with two bolts circled in red that show options horn relocation.
    Included:
    -Custom plasma cut mounting bracket made from 12ga steel for a Hayden 679 or Hayden 689 transmission cooler, powder coated black.
    -Stainless Steel hardware kit with necessary hardware to mount the bracket to the truck, the cooler to the bracket, and hardware for horn relocation.
    -(2) Rubber grommets for protecting the hose that connects the cooler to the OEM Toyota hardlines. Requires a 1 ¼" hole to be drilled in the passenger side radiator wind deflector. I used a step drill bit for this, I’m sure a hole saw would work as well.
    Cost:
    $110 for a mounting bracket with a stainless steel hardware kit shipped. If you want to purchase one, send me a PM with your vehicle information to ensure I send the correct bracket.
    If you plan to use a Hayden 689 transmission cooler and would like to have the AN fittings included with the above kit, the cost is $20. If you want to source them on your own I would recommend -6AN fittings: one 90 degree and one 60 or 45 degree fitting with a hose barb end.
    In an effort to make it easier for everyone and more reputable, I’ve listed these in an eBay auction, it’s cheaper to buy direct via a private message on the forum since it saves me the eBay fees:
    https://www.ebay.com/sch/i.html?sid=jmunk01&_pgn=1&isRefine=true
    Hayden 689 Bracket
    Hayden 679 Bracket
    2011 - 2018 Tundra - Verify You Have These Lines
    2011- 2018 Tundra - 3/8" Vacuum Port Caps on Lines
    2011 - 2022 Sequoia Horn Relocation Options
  2. Jan 12, 2025 at 4:50 PM
    Fybbub
    Fybbub New Member
    2014 Tundra dbl cab SR
    I would like the powder coated version please.
  3. Jan 12, 2025 at 5:01 PM
    Jmunk
    I’ll send you a PM in a couple of days when I pick them up from powder coat.
    Thanks
    Fybbub[QUOTED] likes this.
  4. Jan 12, 2025 at 6:06 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    PM me the info, I'll take a raw one.
  5. Jan 14, 2025 at 3:41 PM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    I'll jump on board for a bare one with hardware included when you get the chance. Nice project for the spring. Pls send your payment requirements.
    Btw, his is a great product you're providing us. Thanks. Good night.
  6. Jan 14, 2025 at 4:58 PM
    Jmunk
    PM sent.
    Xcumminsguy[QUOTED] likes this.
  7. Jan 15, 2025 at 8:10 AM
    KruxalR1
    KruxalR1 New Member
    Teddy
    2020 Super White Tundra 1794
    @Jmunk, interested in the powder coated bracket with the hardware. I could go ahead and pay for it now and you could ship it out when you get it in. Please send me your payment requirements. Thank you!
  8. Jan 15, 2025 at 4:11 PM
    Jmunk
    I have a batch of brackets back from the powder coater. The cost to powder coat was less then his initial quote so I reduced the price to reflect that.
  9. Jan 15, 2025 at 4:13 PM
    Just got mine today, definitely a well crafted piece of kit that came well packaged.
  10. Jan 15, 2025 at 4:15 PM
    Jmunk
    Glad to hear it made it there safe.
  11. Jan 15, 2025 at 4:53 PM
    Xcumminsguy
    Funds sent.
  12. Jan 15, 2025 at 7:08 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
  13. Jan 16, 2025 at 12:44 PM
    Jmunk
    Dropped a batch off at UPS this afternoon.
    Xcumminsguy likes this.
  14. Jan 17, 2025 at 4:43 PM
    KruxalR1
    KruxalR1 New Member
    Teddy
    Received the powder coated cooler bracket today. Definitely a high quality item and can't wait to get it installed. Super fast shipment as well. Thank you again Jim!
  15. Jan 17, 2025 at 4:57 PM
    Jmunk
    Glad it made it safe. UPS is the way to go.
  16. Jan 18, 2025 at 8:25 AM
    Jmunk
    I don’t have any more brackets with a blemished finish at this time.
    shmabs likes this.
  17. Jan 22, 2025 at 10:09 AM
    Jmunk
    I found an additional photo and uploaded it to show hose placement. Someone else may experiment and find a better option, this is just one option.
    bulldog93 likes this.
  18. Jan 26, 2025 at 5:09 AM
    Fybbub
    Fybbub New Member
    Received mine also, thank you.
  19. Jan 26, 2025 at 6:25 AM
    Jmunk
    Glad to hear.
    I’m down to a few brackets with some light scuff marks. I had the fab shop cut one more batch, they are currently getting powder coated. Unless the demand is high, this maybe the last batch. Once I get them back and listed I’ll update the thread for those that wanted one.
  20. Jan 26, 2025 at 6:32 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Received mine, very nice part and glad I do not have to go find all the screws, also glad I got the powder coated one.
  21. Jan 27, 2025 at 12:27 PM
    Jmunk
    The powder coat shop did a nice job. Now that I established a good power coat business I can see me getting various things done for better longevity.
    I’m waiting for a Hayden 689 cooler to arrive this week. If the mounting holes are the same as the 679, which I believe they will be given the coolers are the same size then this will give an option to use the 689 cooler and get 90 or 45 degree fittings like below for straighter lines.
    https://www.jegs.com/i/JEGS/555/110...e00PEWskfWzD7BExMUw1aQKBu8oKxWKBoCeOIQAvD_BwE
    I think most would rather stick with the 679 given the 3/8” barbs are on the cooler already and you don’t have to buy the two extra fittings. Just another option is all. Once I verify fitment on the bracket I’ll update the thread.
  22. Feb 1, 2025 at 5:31 AM
    Jmunk
    The Hayden 689 does share the same bolt mounting holes as the 679, it bolts onto the bracket I made. The one caveat is that the 689 uses -6an fittings to thread onto the cooler and the wrench flats on the fittings provided has to be flat and parallel to the bracket for it to fit without making contact. With the variety of fittings manufacturers out there, it’s hard to say if all fittings brands would fit without interference.
    If I made another batch of brackets I can change the CAD file to have the small area of interference cutout. The area of interference is about 1/8”.
    If anyone wants to purchase a raw finished bracket and use a Dremel or like item to clearance the bracket for the fittings let me know.
    Overall, the 689 allows for angled fittings to be used for a straighter run with the hose. It does come with (2) straight fittings from Hayden. If you wanted angled you’d need to buy those separately.
    The 679 already has the correct 3/8” hose barbs and just requires some turns in the 3/8” rubber hose. Both work fine, just personal preference.
  23. Feb 1, 2025 at 6:44 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    What did you do to the tab next to the upper bolt that fixes the horn? I blew a hole with plasma in my DIY bracket, otherwise the bracket does not sit flush.
    Anyways, looks good!
  24. Feb 1, 2025 at 7:58 AM
    Jmunk
    If you asking about the top mounting bolt, I use a spacer between the bracket and the truck so it’s straight.
    vtl[QUOTED] likes this.
  25. Feb 5, 2025 at 9:33 PM
    Dreaded_marauder
    Dreaded_marauder New Member
    2020 Tundra TRDOR 2018 4Runner TRDOR
    I’m so happy there are people like you out there for my lazy ass! Just ordered my kit and stoked to cool this whale down!
  26. Feb 6, 2025 at 3:07 AM
    Jmunk
    Thanks - I enjoyed the process of designing and getting them made. I will say that everything turned out nice and the powder coat finish looks great.
  27. Feb 10, 2025 at 5:43 AM
    Jmunk
    For anyone wanting to save a few dollars and get a raw steel bracket to paint or powdercoat on their own send me a message.
    I’ve started taking my measurements from the Hayden 689 and the fitting clearance issue mentioned above and working on the CAD file. I should have one of them cut and in my hands in a few weeks. If anyone wants to use the 689 cooler let me know and I can keep you posted on the progress. I’m also working on getting a good supplier for the AN fittings require.
  28. Feb 14, 2025 at 11:46 AM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    This is a great product from a great seller! I received mine in less than a week from the time I ordered. Everything is well packaged and all the hardware is labeled which is a bonus. I sourced all my oem parts for my trans cooler with a Hayden 679 cooler and installed it about a year and a half ago. I did make my own custom brackets that worked well but this bracket is top notch.
    Old bracket haha
    New bracket
  29. Feb 14, 2025 at 12:46 PM
    Jmunk
    Looks great! I’ve spent the extra money on the stainless hardware and spacer. I’ve made sure to used good quality components and not the cheapest.
    I hope you found the installation to be quick and painless. Let me know if I need to make anything more clear in the installations tips.
    I do have a batch of brackets at powder coat for the Hayden 689 (will also fit the 679). Once I get those back and the required AN fittings I will offer those.
    I think the bracket and Hayden cooler combo works well and surpasses the transmission cooling capabilities of the earlier years with OEM coolers. Great way to get it done for much less than some other options, especially if you buy the OEM parts in a bundle from one of the eBay sellers.
    Thanks again for sharing the photo!
  30. Feb 15, 2025 at 8:34 AM
    Jmunk
    Here is another photo of one that got installed. Thanks for the photo Lee.
    bulldog93 and Tripleconpanna like this.
