Transmission cooling design question
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Jun 22, 2024.
  1. Jun 22, 2024 at 9:13 AM
    SDHNTR
    SDHNTR [OP] New Member
    Still trying to figure this out. For those of you who have an OBD tool and app to read actual trans temps…
    Have you ever been under load (towing or pulling a long hill) and, while still under load, actually seen the tranny temps cool down? As in, have you ever actually experienced the cooling fan kicking on and having any cooling effect at all? I haven’t, and I’m trying to deduce if that might be contributing to my problem. All I know is, while under even a mild load and the trans starts getting hot, the temps are a one way direction up until load is totally relieved. It will not cool down until I stop and/or go downhill and take the load off. Sometimes that’s not convenient or even safe.
    Seems odd to me. Isn’t that what a fan is supposed to do? I’ve had other vehicles before where the fan kicking on had noticeable effect on trans temps, enough to overcome the mild load and cool thingsdown without having to pull over. That never happens with my Tundra. Is it designed differently? Is the fan somehowdesigned to only cool the water and not thetrans? Or does it just do a poor job ofcooling the trans?
  2. Jun 22, 2024 at 10:52 AM
    koditten
    Kirk
    Midland of the Mitten
    I'm not for sure, but I don't think 3rd gets have transmission cooling plumbing.
  3. Jun 22, 2024 at 10:54 AM
    SDHNTR
    I know that. There is no auxiliary cooler. But Isn’t the fan supposed to kick on and cool down the tranny too by blowing more air thru the radiator?
  4. Jun 22, 2024 at 11:17 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s called a radiator fan, not a transmission fan.
    Wallygator and koditten like this.
  5. Jun 22, 2024 at 1:14 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Even under no load, I see close to 220 and I don't hear the fan kick in. I'd assume the fan is not helping after a certain speed? I was doing 70+ last week when I saw those temps.
    FrenchToasty likes this.
  6. Jun 22, 2024 at 1:18 PM
    SDHNTR
    Right. But when the trans uses the radiator as a heat exchanger, shouldn’t cooling the radiator also cool the transmission? Thats what I’m trying to figure out.
  7. Jun 22, 2024 at 1:38 PM
    koditten
    Kirk
    I'm pretty sure the only thing the radiator is used for is to heat your Trans oil. It's not a cooler, it's to help it get up to temp faster.
  8. Jun 22, 2024 at 2:35 PM
    eddiefromcali
    Eddie
    100% Stock
    Definitely regulates temp
    koditten[QUOTED] likes this.
  9. Jun 22, 2024 at 3:20 PM
    Wallygator
    Yeah not sure you could hear the fan kick on or not at 70+ mph
  10. Jun 22, 2024 at 3:22 PM
    SDHNTR
    Right. Hence my questions. So has anyone actually ever seen the temps come down, while still under load, due to the fan?
    Because even at slow speed when I can hear the fan kick on, I’ve never seen it reduce trans temps.
  11. Jun 22, 2024 at 3:48 PM
    Wallygator
    Between the generations there is a ton of info on the trans temps. Toyota eliminated the dedicated trans coolers in 2019 I think? A step back IMO. The trans will last the warranty because you can be sure Toyota torture tested it. Knowing that I was not comfortable with the temps I was seeing (220's). Depending on how you use your truck, at the least, it's probably wise to drain and fill every 60,000 miles. I tow a lot and off road frequently so I added an auxilliary aftermarket trans cooler from Genuine Cooling Systems.
    This thread is not about your Gen but there is a lot of info in here...
    https://www.tundras.com/threads/5-7l-transmission-cooler-kits.60550/
    Google search is better than searching in thread. There are several from your Gen that have added coolers.
    koditten likes this.
  12. Jun 22, 2024 at 3:51 PM
    SDHNTR
    Yes, I’m well aware, but I’m not modifying anything while still under warranty. And most of all I’m just trying to understand how this thing is designed to work.
    Wallygator[QUOTED] likes this.
  13. Jun 22, 2024 at 4:06 PM
    Wallygator
    It works like every other car on the road that doesn't have a separated from the radiator auxilliary trans cooler. I'm not sure about the 3rd gens but as far as the warranty goes, I was willing to take the chance for 20+ degree cooler transmission temps. An the kit for my gen uses all factory equipment except for the cooler itself. YMMV.
  14. Jun 22, 2024 at 4:07 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Your 3rd gen acts like my 2nd ('15 Seq) - 75mph = 220 StopGo (repeated 5 or more times a few blocks each) = 248 (for a few seconds then back down to 230s) allowed to idle for 10 mins after the 248 runs = 183. So it is capable of cooling but only if allowed to idle and I think that is because the puck used to warm the trans up faster using some on the way to the heater core hot water doesn't have the Capacity to cool much when its using 195 degree water a few ounces at a time. Its enough capacity to increase temps from 0 and up but not near enough for reducing.
    Does lowering the gear its in to one that is a straight gear no overdrive to allow slipping and therefore extra heat - makes the engine work harder but it can cool itself just fine in case condition so move the strain to it for now. Luck.
  15. Jun 22, 2024 at 4:11 PM
    Azblue
    The Dirty T ( ^_^)_且
    Originally the Tundra had a completely independent trans cooler, later models had it integrated into the radiator, but it was still a dedicated cooler with transmission fluid separated from the radiator coolant within the radiator. This was deleted in 2019 and all that was left was coolant lines to the trans for warming purposes. My question is does the 3rd Gen have the same system as earlier Gen 2.5s with both cooling systems contained in the single radiator, or are there no dedicated trans fluid line going to the radiator?
    If there is not a separate system for the trans fluid to the radiator, the fan isn't going to do shit to cool the transmission.
  16. Jun 22, 2024 at 4:24 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Not in my year of ownership - towing or not. That's pre external cooler install. All transmission Temps monitored with SGII. There is no stand-alone cooler on the gen3. The hockey puck cooler/warmer is truly warmer. If you want to cool you will need to add an external cooler.
