Transmission Fill Hole….
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brandon-35, Feb 21, 2022.
  1. Feb 21, 2022 at 7:48 PM
    Brandon-35
    Brandon-35 [OP] New Member
    Brandon
    Ok.. this is probably a new one.
    I went to do a drain and fill today on my transmission. And unfortunately when I pulled the fill plug the threads in case came with it.only thing I can think of is the last mechanic that did the service over tightened it and left it.
    So here we are. I am thinking I can pull the front drive shaft, pull the pan. And helicoil the fill plug hole. Anyone know what’s behind the fill plug? Is there room for a helicoil?
  2. Feb 21, 2022 at 7:51 PM
    24mm ….big hole.
  3. Feb 21, 2022 at 7:53 PM
    Brandon-35
    Brandon
    What do you mean? It’s a 24mm bolt head. I think the threads are 18-19mm
    WILLINH and ColoradoTJ[QUOTED] like this.
  4. Feb 21, 2022 at 8:04 PM
    Yes, that sounds correct. Might be tight to get the tools needed to do a helicoil. Good luck. Let us know how it goes.
    WILLINH likes this.
  5. Feb 23, 2022 at 2:23 PM
    Brandon-35
    Brandon
    I think I can pull the driveline. And if I need more space i believe I can pull the cross member and rear transmission support and lower the trans a little. Can probably also remove the cat and exhaust in that area.
    Waiting for a helicoil kit that big to get here. I’ll update.
  6. Feb 23, 2022 at 3:00 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    That sucks. Since there is no pressure in there and it's above the fill line, I wonder if there is some kind of expanding rubber plug, sort if like a bilge plug on a boat that would work if you can't readily helicoil it?
  7. Feb 23, 2022 at 3:10 PM
    Brandon-35
    Brandon
    Not sure. Luckily I don’t need to drive it, I have another vehicle.
    worst comes to worst. Does anyone know how difficult it is to pull the transmission?
    i had to do it on a 94 pickup, and it was fairly painless.
  8. Feb 24, 2022 at 4:16 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    I’m a fan of time-sert fittings, don’t know much about helicoils, but have had good success with timeserts in an oil pan.
  9. Feb 24, 2022 at 8:29 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Pulling the transmission should be easy, doesn't seem like it's much work just looking at it.
    If I were in your shoes, I would use an expandable freeze plug, they're about 5 bucks and work well. You'd have to drop the trans for a proper helicoil repair, you have to get the correct drill bit and thread tap, then drill it, tap it, and install the helicoil. Another thing to consider, if you attempt it, is that you want your transmission with the pan side DOWN when you drill and tap it. If you rotate it pan side up (where it's easier to work with), then whenever you drill and tap, there will be at least SOME metals shavings that will fall into the trans that ain't gonna be found. And you don't want that.
    I'd also stick a block of wood behind the hole when you go to drill it, just in case your drill bit punches through too hard, you won't damage whatever is behind it.
    Drop the valve body to get more working room. If you plan on re using the filter, don't forget to grab another O ring gasket for it.
    The arrow is pointing to the fill plug hole.Screenshot_20220224-101255_Samsung Internet.jpg Screenshot_20220224-101400_Samsung Internet.jpg autograde-engine-parts-570-004-64_1000.jpg
  10. Feb 24, 2022 at 8:55 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Sumo91 likes this.
  11. Feb 24, 2022 at 9:09 AM
    Sumo91
    TN
    I wouldn't want something sticking out of my transmission that far. The regular expansion plugs are almost a flush fit. The trans doesn't build hardly any pressure. A regular expansion plug will work fine.
    But I really do like the product you posted, I could see alot of different uses for it.
  12. Feb 24, 2022 at 2:29 PM
    Brandon-35
    Brandon
    Good Call on removing the valve body. that said do you really think the trans has to be pulled? I have the drive line and cat out already. I think if I drop the cross member I will have enough room with a 90deg drill.
    Sumo91[QUOTED] likes this.
  13. Feb 24, 2022 at 2:36 PM
    Welcome from NY.
  14. Feb 24, 2022 at 3:17 PM
    Sumo91
    TN
    If you have a 90deg drill you should be good. I assumed you had a regular drill.
  15. Feb 24, 2022 at 7:21 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Your a fool to get metal in the transmission which you will. You won't think you will but you will. Use the expansion plug. Done. Permanent repair. By the way Makita makes the smallest right angle drill on planet, work of art. No battery but 110v
    parkerbows and NWPirate like this.
  16. Feb 25, 2022 at 8:05 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    No way would I pull the trans for that. An expansion plug will work perfectly for that, since there no pressure their anyway
  17. Mar 7, 2022 at 8:51 PM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    Interesting to come across this.
    Dealer jacked up my threads then said they were like that when they pulled the plug. Which is odd given they are the only ones to touch it. Either way, they played the blame game, so I took it to a local shop. He threaded it with pipe thread similar to the transfer case. Did an awesome job. That seems simpler than a helicoil.
  18. Mar 7, 2022 at 8:57 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    See if anyone makes a self tapping oversize drain plug for that size. When I worked at shops years ago we had a bin of oversize repair plugs. Like 14.5mm and 1/2" single oversize and double oversize.
