Transmission Fluid Temperature Sensor
Discussion in '1st Gen Tundras (2000-2006)' started by Minimalcreep1, Oct 30, 2024.
  1. Oct 30, 2024 at 11:01 AM
    Minimalcreep1
    Minimalcreep1 [OP] New Member
    Chad
    2003 Tundra TRD 4.7
    Hey all,
    my engine light is on and I think the code is pointing to the tranny temp sensor. Anyone know where to find it? I’m struggling finding info online. Thanks!
  2. Oct 30, 2024 at 11:45 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Can you post the code you're having from the check engine light?
    FrenchToasty likes this.
  3. Oct 30, 2024 at 12:19 PM
    Need the code to understand if you’re even chasing the correct thing down.
  4. Oct 30, 2024 at 12:54 PM
    Minimalcreep1
    Chad
    2003 Tundra TRD 4.7
    Hey guys, sorry about that. P0713
  5. Oct 30, 2024 at 2:04 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Open circuit or high resistance (>157 ohms) in the circuit. Remove connector at tranny and ohm it out with a VOM
  6. Oct 31, 2024 at 8:45 AM
    Minimalcreep1
    Chad
    2003 Tundra TRD 4.7
    Yeah ten four. Problem is I can’t even find it.
  7. Oct 31, 2024 at 11:13 AM
    Note this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Do yourself a favor. Click that link. See the 4th or 5th line, look the link to Service Manuals. Grab the one pertinent to your year.
    Inside you can lookup the OBDII P-code you got and see it points you to what can cause the condition on DI-394, and diagnostic process on DI-412. It appears the engine coolant temp sensor (green sensor, on passenger side of throttle body) is involved in the circuit FYI. I suggest you click the button to download a copy for future use, it may not be online forever.
    Also note on the same line of that thread, link to wiring diagrams. May be helpful in your endeavors to test with a DMM.
    If you're feeling lazy and don't want that wealth of information on your hands, here's the screenshot from the 00-03 FSM showing info that may get you started. It may just be the ATF temp sensor is borked, or a harness is fried/loose/busted.
