Transmission fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hambone01, Mar 15, 2022.
  1. Mar 15, 2022 at 2:12 AM
    Hambone01
    Hambone01 [OP] New Member
    What type and brand is good quality transmission fluid? There is a lot of brands that don't have w/s on them.
  2. Mar 15, 2022 at 2:40 AM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Valvoline MaxLife
  3. Mar 15, 2022 at 3:54 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Maxlife...end of thread. <and walmart has it.>
    <bracing>
    I know where this is going.
    Retired...finally likes this.
  4. Mar 15, 2022 at 4:32 AM
    timsp8
    NY
    Toyota.
    Rocko9999 and WILLINH like this.
  5. Mar 16, 2022 at 1:02 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Toyota states in the 2021 specifications manual "Use Toyota Genuine *insert Coolant/Motor/Differential Oil here*" for every fluid on the truck except ATF, which they only specify Toyota Genuine ATF WS. There's even a note that says "Using transmission fluid other than the above type (Toyota WS) may cause abnormal noise or vibration, or damage the transmission of your vehicle".
    I really doubt any high quality ATF would hurt your transmission, but you may want to make your decision knowing what the owner's manual says. Especially if you're within the warranty period.
    hANNAbONE and Saltyhero13 like this.
  6. Mar 16, 2022 at 1:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    why not just use the toyota ws?
    WILLINH likes this.
  7. Mar 16, 2022 at 1:28 PM
    Trust86
    Trust86 New Member
    2007 DC
    I use Eneos model T-W. Got 24 quarts for a little over $100.
    badmotofing3r likes this.
  8. Mar 16, 2022 at 1:58 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Toyota WS
    Eneos T-W
    Idemitsu TLS-LV
    Aisin ATF0WS
    All of these are specific for the WS requirements. The Aisin fluid (made by Eneos) is sold by the folks that manufacture the transmission, so they should know what it needs.
    I've tried the generic fluids with varied results in the past in Toyotas, so I'm hesitant to use one in my Tundra.
  9. Mar 16, 2022 at 2:03 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  10. Mar 16, 2022 at 2:30 PM
    TTund16
    TTund16 New Member
    How many quarts does it take? Can't remember. Hoping it's not 24 quarts. :eek:
    Trust86[QUOTED] likes this.
  11. Mar 16, 2022 at 2:31 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Only their best blend though.
  12. Mar 16, 2022 at 4:16 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Nothing is too good for my 14R.
    Saltyhero13 and HulkSmurf14 like this.
  13. Mar 16, 2022 at 6:05 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Just gonna leave this here....
    TTund16 and Rocko9999 like this.
  14. Mar 16, 2022 at 6:12 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    badmotofing3r[QUOTED] likes this.
  15. Mar 16, 2022 at 6:26 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Red bottle. You are looking for the Toyota WS spec.
  16. Mar 16, 2022 at 6:45 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I have been using this at work for a few years with good results. Says it's compatible with Toyota ws. I think we pay @ $25 a gallon.
  17. Mar 16, 2022 at 11:38 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Red Bottle FTW
  18. Mar 16, 2022 at 11:39 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    I like Schaeffer products.
    Sumo91[QUOTED] likes this.
  19. Mar 16, 2022 at 11:44 PM
    Sumo91
    TN
    I've run Schaeffers exclusively for years in all my vehicles. I recently switched to High Performance Lubricants though, running it front to back, except for the transmission, gotta wait for my next fluid change, then I'm gonna fill it with HPL.
  20. Mar 17, 2022 at 3:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I did not see it at Walmart.
    I am epicly against walking into a dealership - or even making a special trip.
    oh , and I'm thoroughly against spending too much money
    maxlife - $18-5 qts
    toyota - $12 - 1 qt
    however, I will waste a bunch of time reading dribble on bobistheoilguy. WS is all the same.
    my '06 sequoia & '96 4R loved maxlife. never an issue.
    and...it all smells like piss.
  21. Mar 17, 2022 at 5:39 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Considering how often you change your trans oil, price shouldn’t matter. I personally stick to OEM or a WS oil and only pay $6-8 a quart. I would hate to blow up a trans by using a multi-purpose oil than spend the extra few bucks for a WS specific oil. Some people put a dollar value on the wrong things.
  22. Mar 17, 2022 at 6:06 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    As others have said, any WS fluid and you should be good to go.
    I personally went with Aisin WS fluid. Considering they make the fluid that Toyota rebrands and sells for themselves, this was what I was most comfortable with since it is OEM fluid simply at a discount. I bought it for around $5.50 a quart last year. Price is up to $6.38 on Rock Auto now. I bought 14 quarts and that was just enough to do a full flush.
    Saltyhero13 likes this.
  23. Mar 17, 2022 at 6:20 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Hugemoose and BobsYourUncle like this.
  24. Mar 17, 2022 at 7:38 AM
    Johnsonman
    Austin
    Sequoia
    Glad someone mentioned that. I had a couple older bottles and wondered if they stuff could "spoil" cuz the fluid in them smelled so bad compared to any other auto fluid! Amazingly different odor than the Blue bottle (for my Gen 3 4Runner).
  25. Mar 17, 2022 at 8:28 AM
    Trust86
    Trust86 New Member
    2007 DC
    Lol no it’s around 12 I think. I got enough to do the wife’s car too. I went with eneos bc it was right around 4-5 dollars a quart lol. Not sure if it’s synthetic or not but also has a higher flash point than WS.
    TTund16[QUOTED] likes this.
  26. Mar 17, 2022 at 8:32 AM
    CTundraForMe
    CTundraForMe New Member
    I take the "don't want to be penny wise and pound foolish" approach and use genuine Toyota fluid. Not worth the risk of tranny issues IMHO.
    If I had to change it every 6 months like I do the oil, I may take a different approach...
    EatSleepTacos likes this.
  27. Mar 17, 2022 at 10:41 AM
    MadMaxCanon
    You the man! Just ordered bunch of fluids, saved 300 with discount and free shipping!
    EatSleepTacos[QUOTED] likes this.
  28. Mar 17, 2022 at 10:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    I keep trying to think of stuff I need to buy but I'm drawing a blank, only stuff I want to buy. Happy to help.
  29. Mar 17, 2022 at 12:03 PM
    pursuit2550
    You know that the 25% is for all Toyota dealers. Just saying. I did the same thing and put it for pick up at my local dealer.
  30. Mar 17, 2022 at 12:30 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Drain and fill is about 4-1/2
