Transmission pan bolt size
Discussion in '2nd Gen Tundras (2007-2013)' started by kranyx, May 21, 2021.
  1. May 21, 2021 at 12:03 PM
    kranyx
    kranyx [OP] New Member
    '07 DCLB 5.7
    I'm going to be replacing the transmission filter soon and was curious what the pan bolt size was since I've heard they like to snap.
    Anyone happen to know?
  2. May 31, 2021 at 8:44 PM
    kranyx
    '07 DCLB 5.7
    Bump.
    I attempted this today.... tried 3 bolts.... broke 3 bolts and stopped...
    I'm not even sure I can get a bolt out to measure them haha
  3. May 31, 2021 at 9:28 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    TIS states that it's a 4.4mm bolt but doesn't say how long.
  4. May 31, 2021 at 10:02 PM
    kranyx
    '07 DCLB 5.7
    4.4 is the Nm for the torque specification, not how big the bolt is :-/
  5. May 31, 2021 at 10:08 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    The torque specs are in the parenthesis. For example 39in pounds for this bolt.
  6. Jun 1, 2021 at 4:36 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Sorry mate, your wrong. See image below indicating it is N.m outside the parentheses.
  7. Jun 1, 2021 at 4:59 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yup, you are correct. That number did look like it though :hattip:
    coldcanuk and RustyShackle323 like this.
  8. Jun 1, 2021 at 9:54 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    all but three are thru bolts (meaning the length doesn't have to be something specific if its continuously threaded to point). Wish i had a number for you for length. The blind bolt holes (the two in the back most likely won't snap for sizing purposes)
    When i did this "dance" i didn't realize you could cut the top few threads off the bolts and that you could have used penetrating oil on the threads a few days before attempting. I would have done that first prior to attempting to remove by just snapping.
    I'd consider leaving the pan in place while you fix the snapped bolts too (otherwise you will be continuously showered with tranny fluid).
    kranyx[OP] likes this.
  9. Jun 1, 2021 at 10:09 AM
    kranyx
    '07 DCLB 5.7
    yeah... I assumed the rears were blind which is why that was the 3rd one I snapped... at that point I just wanted a bolt to measure.
    I might have enough threads on the broken heads (2 or 3?) to get the pitch off one... and should be able to measure the length because they are through hole. (which I didn't realize until I was under there or a would have sprayed them with oil first)
    good tip on leaving the pan on... I probably wouldn't have thought of that.
  10. Jun 1, 2021 at 10:12 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    When i did this i snapped all but the blind ones, spend some quality time with tranny fluid running down my head (I had a lift which was very helpful. On the last bolt i realized the threads sticking up and realized i had wasted time trying to pull rust through the holes.
    I was able to drill and extract without tapping.
  11. Jun 1, 2021 at 11:20 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    No need to replace your filter, fix the bolts and change the fluid. I broke one of mine off and had to drill, tap, and helicoil it. The filter had virtually nothing in it at 173k miles. The transmission will give out long before filter.
  12. Jun 2, 2021 at 4:55 AM
    timsp8
    NY
    Are there threads or did just the bolt head snap off? If so go to a hardware store with it and use one of their testing things on the bolt aisle to match it up.
  13. Jun 2, 2021 at 6:50 PM
    kranyx
    '07 DCLB 5.7
    It appears to be a m6x1.0 25mm long.
    I have 2 threads on one of the heads that I compared to another bolt and then counted the number of threads from a picture online :p close enough to have replacements on hand for round 2.
