TRD Fox shock help
Discussion in 'Suspension' started by Tundra1D6, Oct 9, 2022.
  1. Oct 9, 2022 at 10:48 AM
    Tundra1D6
    Tundra1D6 [OP] Well that escalated quickly…
    Got a new to me pair of fox shocks from a pro. They arrived after being serviced from Fox Friday.
    While loading them up to go install I noticed the “L” and “R” shocks for the front have something strange happening.
    The springs do not match the shocks. The left shock has the spring orientation facing the “R” and the right shock has the spring facing the “L”.
    Never noticed this prior as I purchased them used and sent the to get serviced.
    Photos attached, if this is normal so be it. Just wanted to ask a dumb question before I rip things apart.
  2. Oct 9, 2022 at 12:19 PM
    Tundra1D6
    Anyone happen to know?
  3. Oct 9, 2022 at 12:26 PM
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    That’s possibly going to be an issue. L and R on the spring is for UCA clearance at full droop. L and R on the shock is based on bottom collar height. The bottom collar position helps compensate for “toyota lean”.
    notice in the picture the space relationship of the bottom spring collar to the top of the reservoir. It’s different to adjust for lean.
    JLS in WA and FISHN43 like this.
  4. Oct 9, 2022 at 12:31 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Yes- the one with the lower collar seated higher on the shock body should be designated as the left (driver) side. The spring on the left one is slightly compressed to give lift and compensate for the “driver-side lean”.
    JLS in WA likes this.
  5. Oct 9, 2022 at 12:40 PM
    Tundra1D6
    How would I fix this?
    You’d think fox would know this and do things correct the first time.
  6. Oct 9, 2022 at 1:48 PM
    OGDark Knight
    Jeff
    Spring compressor and swap springs to correct shocks.
  7. Oct 9, 2022 at 1:59 PM
    Tundra1D6
    The springs are the same part numbers. I don’t fully understand.
  8. Oct 9, 2022 at 2:11 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Looks to me like the those are index marks for right and left. Take a side by side picture showing the collar heights.
  9. Oct 9, 2022 at 2:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    those just alignment marks for the top mount. just install the top first and spin the bottom with a big screw driver to align the bottom bolt hole. spray some wd40 if you need to.
  10. Oct 9, 2022 at 2:53 PM
    Tundra1D6
    So what’s correct?
    The strut marked on the bottom or the spring?
    If the L strut goes on the left side I can move the top hat to accommodate.
    If anyone with a pro has a second to snap a few photos it would be greatly appreciated.
    Also thanks all for the help.
  11. Oct 9, 2022 at 2:56 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    strut mark is right, those spring are flat top and bottom, it don't even matter which side is on. as long as top and bottom bolt align it's all good
  12. Oct 9, 2022 at 2:56 PM
    FISHN43
    FISHN43 New Member
    Ohio
    The circled one goes on the driver side. Reservoir faces out towards the tire.
  13. Oct 9, 2022 at 3:02 PM
    Tundra1D6
    Much appreciated everyone!
    FISHN43 likes this.
  14. Oct 9, 2022 at 3:03 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    From the above pic the bottom one is like 20 -40 degrees off
  15. Oct 9, 2022 at 3:04 PM
    FISHN43
    FISHN43 New Member
    Ohio
    It can be turned.
  16. Oct 9, 2022 at 3:06 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just want to let op know bottom one need to turn…lol
  17. Oct 9, 2022 at 3:56 PM
    Tundra1D6
    So the strut mounts need to be turned to accommodate the struts as the struts are side specific and the soakings are the same left or right.
    Got it!
  18. Oct 9, 2022 at 4:15 PM
    OGDark Knight
    Jeff
    Springs are same but indexed differently per side based upon upper control arm clearance at full droop.
    You can find instructions online for all this.
  19. Oct 9, 2022 at 4:37 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    There is a left and a right, I can snap some pics of mine if you need it.
  20. Oct 10, 2022 at 7:05 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    On my 2019 PRO, the left (drivers' side) the bottom of the strut is marked "L" and the Spring itself is in the "L" position. Seems like you could loosen and rotate the spring. Since the springs are the same part number, makes no sense to swap them over.
  21. Dec 9, 2022 at 5:45 PM
    bmw345
    bmw345 New Member
    CT
    Did you ever get these straightened out and installed?
  22. Dec 9, 2022 at 6:25 PM
    Tundra1D6
    Sure did, orientation of “L” and “R” makes zero difference as the springs are the same on both sides. However the only real difference are the shocks themselves as they are marked left and right.
    Compared to my 2.0’s these aren’t much different.
    I went in expecting more and got mediocre response. 2.0’s are better bang for the buck FYI, but that’s me.
  23. Dec 9, 2022 at 6:30 PM
    bmw345
    bmw345 New Member
    CT
    Sorry to hear! Love mine! Post up some pics!
  24. Dec 9, 2022 at 7:31 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I’m pretty certain the orientation does make a difference.
  25. Dec 9, 2022 at 7:57 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    What 2.0’s are you referring to?
