TRD Lift up on 35” Nitto Ridge Grapplers Looks & Rides Great!
Discussion in '3rd Gen Tundras (2022+)' started by FLTundra22, Feb 28, 2023.
  1. Feb 28, 2023 at 5:34 PM
    FLTundra22
    FLTundra22 [OP] New Member
    St Aug, FL
    ‘22 Limited TRD Off Road 4x4 Crew Max Lunar Rock
    TRD 3” lift, 35” Nitto Trail Grapplers, BackFlip tonneau
    Took the plunge but spent less than I thought…worked out a deal to get everything including tires and labor at the dealership. The ride is slightly more classic “off road truck” vs the SUV smooth ride of OEM but next time I’m in Ocala National Forest will be sure to put the new 5”+ of clearance, improved break over angle and more aggressive tire tread to the test.
  2. Feb 28, 2023 at 5:36 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Looks fantastic
  3. Feb 28, 2023 at 6:00 PM
    cruiserhead
    cruiserhead New Member
    Looks awesome. Do you by chance have before and after measurements?
  4. Feb 28, 2023 at 7:31 PM
    toyrider
    toyrider New Member
    Rob
    2023 Toyota Tundra TRD Pro
    Looks great and nicely done
  5. Mar 2, 2023 at 11:18 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Is the Trd lift the one that comes on the Trd pro? It fit 35’s with no other modification?
  6. Mar 2, 2023 at 11:57 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Welcome…in this case NO.
    This TRD OEM lift is a separate aftermarket one Toyota sells and installs (separate prices).
    The Pro “lifts/suspension is totally different
    Yaboy likes this.
  7. Mar 7, 2023 at 5:57 PM
    FLTundra22
    St Aug, FL
    Hey all,
    Spent $2700 after tax for the kit through Coggin Toyota in Jax, FL…but you need to buy online and have them deliver to the parts Dept and note that they don’t accept returns…but a crap ton cheaper than the listed $3900. The installation was less than the expected “20 hours of labor” so landed at $2350 at Coggin but heard that Ernie Palmer Toyota has done more of them and is running the install for only like $1500. I bought the Nittos on a buy three get one through Coggin and it landed right around the cheapest price for four I could find in the internet. Definitely get your tires to the dealership or through the dealership as they need them on the truck to correctly recalibrate all the sensors/cameras at the new height. All in all, I gotta hand it to the guys at Coggin as they really did a super solid job and I could tell they were proud of their work as they all came out to show me all the details in person when I came to pick it up.
  8. Mar 7, 2023 at 6:00 PM
    FLTundra22
    St Aug, FL
    Didn’t get before measurements but the both wheel wells now sit at just above 42” from the ground. My 5’ tall wife now has a hard time climbing in and is pissed at me!
    cruiserhead likes this.
  9. Mar 7, 2023 at 6:02 PM
    bigjuice
    WA State
    2024 Terra TRD Pro
    I’m guessing you don’t have sidesteps?
    …gonna be time to get some installed if that’s the case
  10. Mar 7, 2023 at 6:05 PM
    FLTundra22
    St Aug, FL
    Last note, have the kit delivered to the dealership you intend to have install as the kit is heavy as $hit…and if anyone is interested in buying my barley used (less than 8K mi when removed) Falken tires and the original TRD Off Road Suspension, I’ll cut a fellow Tundra Bro a deal but will be posting to sell online here soon…at my request, the dealership neatly packaged back up the original suspension into the boxes of new suspension and is ready to go!
  11. Mar 7, 2023 at 6:07 PM
    FLTundra22
    St Aug, FL
    I have the steps already, LOL, but doesn’t help too much it seems.
    bigjuice likes this.
  12. Mar 7, 2023 at 6:48 PM
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Looks good, did the dealer unplug your fog lights?
  13. Mar 18, 2023 at 6:59 PM
    jhtram
    jhtram If I'm curt with you it's because time is a factor
    Jay
    Raleigh, NC
    2023 Lunar Rock Tundra Limited TRD
    OEM TRD Lift Maxxis RAZR AT LT285/65R20 tyres Spidertrax 1" Spacers Retrax Pro XR Tonneau Bumpershellz 'stache overlay TRD Pro Fender Flares Yakima Overhaul HD Bed Rack OEM Blackout Overlays aFe Front Tow Hooks Talon's Cat Shield Undercover SwingCase Toolboxes TufSkinz Console Cover (Matte black) ScreenProtech LCD and instrument cluster protectors Tailgate & bumper vinyl inserts (texas decal king)
    What did you use to black out your door handles?
  14. May 8, 2023 at 7:53 PM
    bigcat
    bigcat New Member
    2023 Lmtd OR TRD Lift
    TRD factory lift
    @FLTundra22 looks great, I have the exact same setup except with 285/65/20R tires and picked up my truck from the dealer with the lift installed. Curious do your tires rub at all? Mine rub quite a bit on the sway bar so I’m taking it back to have them readjust. Everything I can see in Toyota’s specs for the lift suggest that my tires should fit fine without rubbing so I’m thinking it’s a problem with the install or alignment.
  15. May 8, 2023 at 8:41 PM
    cruiserhead
    please post what the dealer says. I have the exact same problem. My dealer kind of shrugged their shoulders and didn’t know why.
    I put in 1” spacers and that mostly helps. But I’d rather not run spacers.
  16. Dec 1, 2023 at 7:57 AM
    406Gentry
    406Gentry New Member
    2024 Tundra
    Any updates on this? I just picked up my truck last week from dealer. TRD lift installed by dealer, kept OEM 20” wheels and put on 285/65R20 Falken AT3 and have rubbing on the sway bar at full turn. Only got 285s because supposed to be no rubbing! Would have put on 295s if I would have known I would be tackling rubbing issues.
  17. Dec 1, 2023 at 8:08 AM
    jhtram
    Jay
    Raleigh, NC
    I have the same setup and tyre size (Maxxis RAZRs at 285/65R20). Had sway bar rub. Had install and alignment checked and it all checked out but still rubbed. Added 1" spacers. That caused mud flap and fender well carpet rub so removed the mud flaps and pinned back the carpet. After that it was all good. Good thread here with my alignment specs and what others have experienced.
    I think you will find my experience pretty consistent this rim/tire combo and the OEM lift.
