Trd pro and off road/ black steel aftermarket bumpers
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by cjscinta, Jul 30, 2021.
  1. Jul 30, 2021 at 8:26 AM
    cjscinta
    cjscinta [OP] New Member
    Nashville TN
    Just looking for some pros and cons. I have a 2017 trd pro tundra in cement. Someone backed into me in a parking lot and I will have to replace my front bumper end cap. I like the fact that my bumpers match the rest of the truck but I’ve been thinking about replacing my bumpers with some black steel ones with led lighting. I really don’t want to lose my front skid plate in the process but I understand some bumpers are not compatible with the trd pro skid plate.
    Has anyone done this and what are your thoughts? Keep it stock or go for the bumpers? I’m not planning on selling it anytime soon but I could always put the old ones back on. Is it easy to do?
  2. Jul 30, 2021 at 8:34 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Click my build thread at the bottom but this is an Expedition One bumper with a TRD PRO skid on a 2016.
    doggiecareman likes this.
  3. Jul 30, 2021 at 7:13 PM
    cjscinta
    Nashville TN
    Looks great. Thanks.
  4. Aug 1, 2021 at 2:28 PM
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Go with a black steel bumper…so much better looking than stock! C4 Overland bumper…TRD skid plate works perfectly.
    J&ATundra, avssuc, junior and 6 others like this.
  5. Aug 1, 2021 at 3:57 PM
    cjscinta
    Nashville TN
    Oh yeah. That does look good. Did you do the back bumper too? I’m trying to use the same manufacturer for the front and back because I’m worried the paint or finish won’t match.
  6. Aug 1, 2021 at 5:17 PM
    Weavin Pro
    I like your question! Actually I really love the C4 front bumper…but wanted a spare tire carrier for the rear, which C4 doesn’t offer. So I ordered the Expedition One rear bumper with carrier. I ordered both of them in raw steel and have them powder coated locally so they are the same finish.
    AggiePhil likes this.
  7. Aug 1, 2021 at 6:13 PM
    cjscinta
    Nashville TN
    Good idea. Thanks again.
  8. Aug 1, 2021 at 7:04 PM
    I have the RC bumper on mine along with the RCI skid plate.
  9. Aug 1, 2021 at 7:06 PM
    Line-X is the way to go.
  10. Aug 1, 2021 at 7:09 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Demello offroad ftw
    good luck in your search
  11. Aug 7, 2021 at 3:52 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I just installed the barricade hd2 on my tundra. I have the TRD skid plate and would have ordered the hd2 skid plate to use both together if it wasn’t on back order :(
    I was hesitant with the black/white versus color keyed on my Super White, but am pleased with the end look; I’d think it would look good on your Cement color.
    I also have a dif drop, so had to use a spacer kit on my TRD skid plate…in case you see the aluminum spacers in the photos.
    cjscinta[OP] likes this.
  12. Aug 7, 2021 at 4:10 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    Every time I see a pic of this truck I shake my head...well done, well done.
  13. Aug 7, 2021 at 4:39 PM
    cjscinta
    Nashville TN
    I just ordered the same bumper. Looks awesome on yours. Which light bar did you go with and what is the length of the opening? 30 in?
  14. Aug 7, 2021 at 4:57 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    How much cutting and modifying is involved with these aftermarket steel bumpers? Are there any that are “plug and play”.
  15. Aug 7, 2021 at 5:00 PM
    cjscinta
    Nashville TN
    According to the description none but I haven’t installed it yet.
    shawn474[QUOTED] likes this.
  16. Aug 7, 2021 at 5:07 PM
    shawn474
    MoCo, Maryland
    Let us know how it goes; I would be very interested if there isn’t a lot of modification needed.
    cjscinta[QUOTED][OP] likes this.
  17. Aug 7, 2021 at 5:12 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Thanks! I picked one up from a company called SD Lighting here in AZ (the owner was very friendly/helpful)…it’s advertised as a 32”, but the light portion is 30”. it has a center laser led, so I thought I’d try it out. It’s incredibly bright, but you need to purchase a separate wiring harness if you don’t already have a light bar with fuse/button/relay that’s been run (light only come with couple foot long cable with deutsch connector) The opening is 31.5” as I recall from measuring. No need to buy separate mounting bracket for it, the bumper includes a set that’s highly adjustable to get the light sitting in the opening however you’d prefer.
    Also, I ordered an H11 wire harness for the fog lights that come with the bumper to retain the factory fog light harness/controls. Would consider Caliraised as another option for you main light bar too-great customer service and fast shipping on the harnesses.
    Light bar I used:
    https://www.sdlightingaz.com/collec...-double-row-leds-laser?variant=35774856331415
    Harness for fogs to factory connector:
    https://caliraisedled.com/products/...t-pod-oem-adaptor?_pos=1&_sid=01f7b54e9&_ss=r
    If you have/want to retain use of your front parking sensors, you’ll have to drill the new bumper. I used a 3/4” step bit (the full 3/4”) and then a carbide dremel bit and file to widen it a bit at the bottom and on the sides to get the sensor through. I’ve added a pictures in case you need to reference them for where I relocated mine.
  18. Aug 7, 2021 at 5:25 PM
    cjscinta
    Nashville TN
    Thanks for the info.
  19. Aug 7, 2021 at 5:33 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    for the bumper I used (barricade hd2) only cutting/modification was for re-installing the factory front parking sensors (in fairness, it tells you that it does not come drilled for reuse of these sensors, and you could just deactivate them with the button in the cabin if you never use them anyway) …also need an additional 8 large washers (10mm x 34). They provide 20, but tell you to use 8 in the first step in mounting the bracket on the factory bumper studs with reuse of the 8 factory nuts (4 on each side). The 20 washers have to be utilized for other parts of the install (not sure why the didn’t include the extra 8 since there are not washers when you remove the factory nuts from the studs. A quick run to ace hardware was simple enough to get the additional washers, but would’ve been nice to know up front.
  20. Aug 7, 2021 at 5:40 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    you’re welcome…feel free to pm me if you have any questions when you install. I mounted all my lights and the sensors before mounting up the bumper. If you have a friend to help it would be beneficial as the bumper is heavy/awkward on your own. You don’t need to remove the grill to take off/install the bumper. Plenty of YouTube videos to reference if you search Tundra bumper removal. I was too impatient and did it on my own with a floor jack and some 2x4’s. Also used this on each side at a time to hold it in position to get the alignment the way I wanted with the fenders/wheelwell and gap beneath the grill/under the headlights. Takes a little time, but not difficult. Just hand thread everything on initially so it’s loose to make the adjustments before tightening everything down.
  21. Sep 4, 2021 at 12:56 PM
    cjscinta
    Nashville TN
    I just finished the front bumper. Barricade HD. It was very easy to do though I have no parking sensors. The hardest part was getting the bumper bolts loose. Stripped a couple of nuts and tore up some knuckles. Those things were on tight. Came out great I think. I have the rear bumper next. 27AD65A2-8177-489E-8AD8-A2B52ABF7510.jpg
    GarTX526 likes this.
  22. Sep 4, 2021 at 1:04 PM
    cjscinta
    Nashville TN
    GarTX526, U-moto and 1P7R9O4 like this.
  23. Sep 4, 2021 at 2:41 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    @cjscinta looks great! Congrats on getting it installed
  24. Sep 4, 2021 at 6:30 PM
    cjscinta
    Nashville TN
    Thanks for all the encouragement.
    1P7R9O4[QUOTED] likes this.
  25. Sep 4, 2021 at 9:58 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Any opinions on the rough country bumpers? Seem like a great value with included lights and it's half the cost of everyone else.
  26. Sep 5, 2021 at 3:39 AM
    cjscinta
    Nashville TN
    From what I’ve read it’s made with the same gage steel as the others. I talked to a car install guy that said their products are pretty good. All my leds are RC. Seem to be pretty well made.
    MadMaxCanon[QUOTED] likes this.
  27. Sep 5, 2021 at 4:54 PM
    MadMaxCanon
    Awesome thanks for the feedback!
  28. Sep 5, 2021 at 4:59 PM
    I have it on the front of mine. You will have to change the fog lights to street legal ones though. I had mine Line-X'ed. I didn't like their rear bumper. I have Road Armor for that one.
  29. Sep 5, 2021 at 5:00 PM
    Line-X is your answer to that.
    avssuc likes this.
  30. Jan 15, 2025 at 4:34 AM
    Geodude82
    Geodude82 New Member
    Have you had any functionality issues with the sensors? I was thinking about doing the exact same thing if I was to pick up the Barricade.
