TRD PRO Heritage Grill Instal Questions
Discussion in '3rd Gen Tundras (2022+)' started by tlpilot30, Feb 20, 2025.
  1. Feb 20, 2025 at 8:55 AM
    tlpilot30
    tlpilot30 [OP] New Member
    Good Day 3rd Gen Brain Trust,
    I am ordering the OEM TRD Heritage Grill part #53101-0C220 for my 2025 Tundra Platinum TRD sport with 3in Lift. My question is, Does this part/grill come with the T O Y O T A lettering installed on it? Or do I have to order those letters as well? I am having Dealership instal and want to make sure all parts are in place when I take delivery of my 2025 Platinum TRD Sport. I also ordered from Westcott the Front Camera Relocation Bracket for the new OEM TRD Heritage Grill. Thank you, all and any input on how to properly have the dealership instal this Grill and the S8 Baja Designs Light Bar with Rave OEM type switches to operate light bar is appreciated.
  2. Feb 20, 2025 at 9:13 AM
    JDAZ
    JDAZ New Member
    Yes, it has the lettering.
    Will the dealership install an aftermarket light bar?
    What about marker lights or are you leaving those blank?
  3. Feb 20, 2025 at 12:55 PM
    tlpilot30
    Thank You....I do not want the marker lights, and I will be talking to the dealership about it shortly.
  4. Feb 20, 2025 at 1:14 PM
    JDAZ
    JDAZ New Member
    Just an FYI, ther will be 3 open 1x3" holes in the top of the grille where the markers go. I'll try to find a pic unless you don't care. I personally thought it looked funny without them
  5. Feb 20, 2025 at 1:32 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    You can add the marker lights later, without pulling the grill. You'll just have to loosen the shutters & squeeze your arm in there.
    23 Platinum likes this.
  6. Feb 20, 2025 at 1:37 PM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    Not sure but I don't think the Heritage grill comes with the bracket needed to mount the Baja light bar. I think you may need those support bars.
    This thread has some good info.
    https://www.tundras.com/threads/swap-out-grills.138752/
    The Diode Dynamic one does have the bracket check if Baja has it as well
  7. Feb 20, 2025 at 6:16 PM
    tlpilot30
    I will be using the Baja Designs S8 20 Inch Grill Kit for Tundra w/TRD Grille Conversion
    https://www.bajadesigns.com/product...n-sequoia-w-trd-grille/?vid=168763&sku=448078
  8. Mar 25, 2025 at 6:55 PM
    TundraCan
    TundraCan New Member
    Do you have to have TRD pro Tundra in order to order TRD Pro grill? Mine is 2025 Platinum non TRD model and I am interested to install TRD Pro grill
  9. Mar 25, 2025 at 7:52 PM
    Raven67
    Kentucky
    Nope, just order one & carry on...
    TundraCan[QUOTED] likes this.
  10. Mar 25, 2025 at 8:49 PM
    R1Style_
    R1Style_ New Member
    ON Canada
    2025 Tundra TRD Rally
    You'll need a T6 Torx screw driver to remove the front camera from the old bracket to the new one.
  11. Mar 26, 2025 at 5:03 AM
    tlpilot30
    I have a 25' Platinum. I ordered the TRD Heritage Grill (Part # 531010C220) from a dealer. Make sure you also order the Westcott Designs Front Camera Relocation Bracket as well. I am happy with the results!
  12. Mar 26, 2025 at 5:15 AM
    TundraCan
    but will they ask your VIN#? I am from Canada and here they ask for VIN and evidence that you have TRD Pro to order TRD Pro parts otherwise they will reject the order and the system will not allow them to proceed. I know it is weird.
    I wonder if US dealership will allow Canadians to order TRD pro parts
  13. Mar 26, 2025 at 5:17 AM
    TundraCan
    nice! Why you didn’t order the OEM TRD Pro light bar?
    Rave also sells TRD pro grill as a kit which comes with the light bar, marker lights, and camera mount. May I know why you didn’t order the kit from Rave? Is it cheaper to order from dealership?
  14. Mar 26, 2025 at 5:22 AM
    lapoolboy
    lapoolboy New Member
    Because it is CANBUS.
  15. Mar 26, 2025 at 6:35 AM
    TundraCan
    Can you please elaborate? I asked two separate questions so not sure what do you mean.
  16. Mar 26, 2025 at 6:46 AM
    lapoolboy
    The OEM lightbar is controlled via CANBUS. This means it is very difficult, if not impossible, to control it if the truck didn't come with it from the factory. This is why everyone who installs the heritage grille installs an aftermarket lightbar so it can be controlled with a standard switch.
    About Rave, their harnesses seem good but the consensus is that their hard parts (grilles, lights, etc) seem to be poorly-made. Classic example of "you get what you pay for."
  17. Mar 26, 2025 at 6:51 AM
    TundraCan
    ahh okay I understood now.
    Rave also sells OEM grill and marker lights. I was just curious why not getting the OEM kit from Rave instead from Toyota directly. Is there an advantage? Is it cheaper from Toyota?
  18. Mar 26, 2025 at 7:14 AM
    JDAZ
    JDAZ New Member
    Rave has a pretty big mark up on their OEM parts. Of course, if that’s the only way you can get the OEM parts then it is what it is. I am in the middle of this process too. I am using a real OEM light switch and also replacing the brushed chrome pieces and the fog light bezel with OEM painted parts from OEMpaintedparts.com
  19. Mar 26, 2025 at 7:21 AM
    TundraCan
    Okay thank you. I wonder if US Toyota dealerships are willing to install TRD Pro grill to my Canadian Tundra if I am too lazy to DIY. Or would they only assist US Tundra.
  20. Mar 26, 2025 at 7:29 AM
    JDAZ
    JDAZ New Member
    Maybe. Depends on the dealer. Most dealers probably don’t want to install parts on a truck that aren’t meant for that truck. For example you will need a camera relocation bracket which is non OEM. Also, as mentioned before, if you want a light bar installed it will be non OEM as well as the marker lights, even though the marker light assembly is OEM, the electrical connection is non OEM. I would think a private shop might be more willing to do the installation
    TundraCan likes this.
  21. Mar 26, 2025 at 9:16 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    The light bar RAVE sells is junk...its a china unit that doesnt compare to the Baja Designs bar at all. Even the OEM bar is a joke...light is aimed to work with your high beam and the pattern is not ideal, nor is the angle adjustable. Youre better off with a Baja Designs or even a any other brand other than those OEM knockoffs.
    The BD kit will cost you more than the grille and markers though, but its worth it...wouldnt run anything else.
    Baja Designs likes this.
  22. Mar 26, 2025 at 9:25 AM
    lapoolboy
    I kinda like the stock lightbar for what it is....it doesn't project down the road much but it does light up the sides pretty nicely like ditch lights.
  23. Mar 26, 2025 at 9:37 AM
    tlpilot30
    I preferred the Toyota OEM Grill ($210 discounted on their website) and I wanted the nicer light bar from Baja Designs (20inch S8). I did use the Rave OEM type switch to turn it on and off.
    eddiefromcali likes this.
  24. Mar 27, 2025 at 11:44 AM
    Calif-Tundra
    Bob
    This is the way to go. Buy the TRD Pro grill (Ebay, dealer, other) and get the Baja Design or Diode Dynamics 20" light bar to mount in the slot. You get a better light AND can control with a stock looking switch you can mount in one of the empty switch locations lower left of the steering wheel. Pair that with Diode Dynamics Fog Lights and Baja or DD ditch lights, and you can turn Night into Day! Lol :thumbsup:
  25. Mar 28, 2025 at 9:32 AM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Should have gotten one of these grill instead!!!!
  26. Mar 30, 2025 at 6:33 PM
    Bmyers7990
    Bmyers7990 New Member
    2024 tundra trd off road lunar rock
    Does anyone know the part number for the toyota letters on the pro grille
  27. Mar 31, 2025 at 4:21 AM
    JDAZ
    JDAZ New Member
  28. Mar 31, 2025 at 10:47 AM
    Bmyers7990
    I need the actual part not the overlays
  29. Mar 31, 2025 at 10:54 AM
    lapoolboy
    Letters are not available separately from the grille.
    Siblue likes this.
  30. Apr 13, 2025 at 12:47 PM
    Spacecowboy863
    Spacecowboy863 New Member
    looks good!
