TRD PRO Rock Sliders
Discussion in '3rd Gen Tundras (2022+)' started by veselik3, Dec 21, 2022.
  1. Dec 21, 2022 at 8:11 PM
    veselik3
    veselik3 [OP] Member
    22’ Tundra Crewmax TRD OR Army Green
    I can't seem to find part numbers for the factory toyota rock sliders. Also, anybody know if I will have any issues putting them on my limited TRD ORCM? Looks to be an available accessory option when building a truck on toyota.com. Thanks!44FF1254-130B-4855-83AC-D6DC9F2D7CD0.jpg
  2. Dec 26, 2022 at 1:22 PM
    toyotathon
    toyotathon New Member
    2023 Tundra TRD Pro
    Unfortunately if the truck wasn’t ordered from the factory with rock rails you won’t be able to install them. Only Tundras ordered with rock rails have the vehicle side accommodations in the frame to mount rock rails to. There is a unique frame for rock rails (L70 I believe I read somewhere).
  3. Dec 26, 2022 at 4:09 PM
    toyotathon
    2023 Tundra TRD Pro
    I agree, it is hard to believe but it is true. Frame sub assembly PN 51001-0CL70 is one of the unique frame rails for rock rail (ILA). ILA meaning in line accessory (even though rock rails are a PPO).
    PT738-34223 = C-Cab (double cab), LH
    PT738-34222 = C-Cab (double cab), RH
    PT738-34221 = D-Cab (crew max), LH
    PT738-34220 = D-Cab (crew max), RH
    source: https://parts.toyota.com/p/Toyota_2022_Tundra/FRAME-SUB-ASSEMBLY/114920143/510010CL70.html ,
    https://parts.toyota.com/p/Toyota_2022_Tundra/Frame-Rail/105912071/510010CK40.html
    ryanwgregg and (deleted member) like this.
  4. Dec 26, 2022 at 4:33 PM
    toyotathon
    2023 Tundra TRD Pro
    If my memory serves me right, on frames with the accommodations, there should be 8 weld nuts on the outboard side both LH and RH.
    Just trying to save OP and others the heart ache. Easiest way to prove this would be to go look and see if the weld nuts are in the frame. I already know they’re not on my truck as I ordered the cast running boards.
  5. Aug 18, 2023 at 11:35 AM
    moosetenderloin
    moosetenderloin New Member
    2023 tundra Trd pro
    I have a 2023 tundra Trd pro. Was headed down to pick up these oem rock rails from a guy who has a ‘22 Trd pro. They will not work on my truck. If anyone has any additional info please send my way. I’d like to see if there’s any easy way I can install them without compromising the frame..
  6. Aug 18, 2023 at 2:36 PM
    LR Pro 2022
    LR Pro 2022 New Member
    2022 LR Pro
    Glad i read this before i bought some
  7. Aug 18, 2023 at 2:36 PM
    LR Pro 2022
    2022 LR Pro
    I asked about a pair today locally
  8. Aug 19, 2023 at 10:15 AM
    Atone
    Atone New Member
    Jesse
    Los Angeles
    has to be a way to secure them to this
    Sixty9Four20 likes this.
