TRD Sport lowered suspension?
Discussion in '3rd Gen Tundras (2022+)' started by JBASS2, Jul 4, 2022.
  1. Jul 4, 2022 at 7:35 AM
    JBASS2
    JBASS2 [OP] New Member
    Keep in mind I have very little idea what I am posting about. HaHa.
    So the TRD Sport has the front suspension lowered? How is that done, and would it be an easy adjustment to put it back to where the TRD off road is? Supposedly, the truck only sits 1/2 inch lower so it might not matter, but I wondered if its easy to adjust the suspension back to where it is not lowered?
    TheGreenGoblin likes this.
  2. Jul 4, 2022 at 9:35 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I was actually wandering this as well when I picked up my TRD sport.
    From what I found. Everything is the same except for the strut assembly itself. I'm not sure if the strut is shorter or if the spring is different.
    I see Icon stage 1 suspension which reuses the OEM spring and top mount, it shows that the you'll get less of a lift for TRD sport model. I'm guessing the spring is the culprit for the lower front end.
  3. Jul 4, 2022 at 11:19 AM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
  4. Jul 5, 2022 at 10:16 PM
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
    The trd sport does sit a bit lower. I believe the spring a slightly shorter and it definitely has a different shock than the off road.
    If your using an aftermarket coilover it doesn’t matter, you’ll end up at the same height on the sport as the off road.
    If your reusing your factory strut you will be 1/2” +/- lower than an off road with the same lift / spacer.
  5. Dec 7, 2022 at 5:00 PM
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    Anyone know if the TRD Sport rear springs are actually shorter than standard suspension? I see the articles that say 1/2” but I wonder if anyone here has measured. I’d like to lower the rear just a bit.
  6. Dec 8, 2022 at 8:18 AM
    motojunkie
    motojunkie New Member
    South Florida
    2022 Tundra TRD OR 2023 Supra GR
    I think there the same in rear and only the front is .5in lower.
  7. Dec 8, 2022 at 8:52 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    Can confirm, only the front is lower.
  8. Dec 8, 2022 at 9:18 AM
    David713
    David713 New Member
    I guess I'll have to wait for TRD or the aftermarket to come up with something. I will check on the price of a new rear spring from the dealer so I can use it to design a new shorter spring with the same spring rate and have it made. It's not a straight single diameter spring with the ends flattened so that may make it difficult to get a pair made for anything close to a decent price.
  9. Dec 9, 2022 at 4:53 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    You can look for take offs from the TRD OR models in the market place or online, that might be the least expensive option
    OHwendTrd likes this.
  10. Jan 9, 2023 at 10:03 AM
    Jaxb103
    Jaxb103 New Member
    2023 Tundra TRD Sport
    Can anyone measure their sport for me- particularly the rear. Just installed my 1” Cornfed rear spacer and didn’t get the 1” of lift. Called cornfed and they are as confused as me. I was 23 1/2” and 23 3/4” center of hub to fender prior to install. Front coils went on prior and I re measured. I did gain 2 1/2” up front with the 2” front coils, which makes sense because the sport is lower. I’m probably going to remove and check again but someone measuring would ease my mind.
  11. Jan 9, 2023 at 11:06 AM
    alex17117
    Alex
    my sport sits at 23" and 22.75" in the rear...front is 21"
  12. Jan 9, 2023 at 12:05 PM
    Jaxb103
    Jaxb103 New Member
    Appreciate it
    alex17117 likes this.
  13. Jan 9, 2023 at 1:46 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    https://sosperformance.com/products/2022-tundra-23-lowering-kit-tr-2030
  14. Jan 9, 2023 at 4:13 PM
    Space Wrangler
    Space Wrangler New Member
    2023 Tundra
    I'm having RC 1.75" front and Cornfed 1" rear installed on My TRD Sport tomorrow. Center of hub to fender is about 23" rear and 20 3/4" front now. I will measure after and see.
  15. Jan 9, 2023 at 6:17 PM
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
  16. Jan 9, 2023 at 6:18 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Looks like they're whole site is down atm
    But I used them to lower my Tundra. Also for the big brake kit on my previous Tacoma
  17. Jan 9, 2023 at 6:19 PM
    earlwright239
    Ok thanks
  18. Jan 11, 2023 at 7:33 AM
    Space Wrangler
    2023 Tundra
    I installed RC 1.75 in front (center hub to fender went from 20 3/4" to 22 1/2") and Cornfed 1" rear (went from 23" [I only measured 1 side before] to 23 1/2" and 23 3/4") so probably less than a full inch of lift from the rear cornfed. Before/after pic above (Sorry it is not a great pic...).
    socaldad likes this.
  19. Jan 11, 2023 at 10:32 AM
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    It looks good with the RC spacer and cornfed rear. Any plans for tires upgrade, although it doesn't look bad/or too small currently for the lift
  20. Jan 11, 2023 at 12:09 PM
    Space Wrangler
    2023 Tundra
    My last tires were Yokohama Geolandar A/T X which were great except for horrible wet traction on pavement. I was about to get these 275/65R20 TOYO Open Country A/Ts and at the last minute decided to try the Michelin LTX A/T2 in the same size (34.2 in diameter, I think,-still looks small on the Tundra...). I am > 95% on road with a 20 mile interstate commute to work every day and so far these have been quiet, smooth, and great traction on wet pavement. I do wish they were more aggressive looking.IMG_6699.jpg
    socaldad[QUOTED] likes this.
  21. Aug 21, 2023 at 7:43 PM
    Adriano F
    Adriano F New Member
    Adriano
    Do you know if that lowering kit fits the 2023 Tundra Limited TRD Off road package without air suspension?
  22. Aug 21, 2023 at 8:05 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Mine won't (it's for sale). Idk about the 2023s, haven't looked into those. But saw options on their site for em
