TRD Sway Bar 2023 1794
Discussion in '3rd Gen Tundras (2022+)' started by LouALouA, Mar 23, 2023.
  1. Mar 23, 2023 at 1:24 PM
    LouALouA
    LouALouA [OP] New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    I have a 2023 Tundra 1794 4x4. I would like to reduce the body roll. I'm not interested in lifting it as I mostly drive on paved roads. Has anyone installed TRD sway bars on theirs? If so has it greatly improved body roll? I can't find any part numbers for the 22-23's TRD sway bars.
  2. Mar 23, 2023 at 2:15 PM
    Taco-Spike
    Two Trucks
    if using mobile device, turn your phone sideways with screen lock unlocked or desktop mode
    mayan and ryanwgregg like this.
  3. Mar 23, 2023 at 3:01 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Don't restrict your search to Tundra parts.
    The Sequoia sway bars may be a bit stiffer.
  4. Mar 24, 2023 at 3:29 AM
    LouALouA
    Lou
    Central Florida
  5. Mar 24, 2023 at 6:24 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    So they just painted em red?
  6. Mar 24, 2023 at 7:33 AM
    LouALouA
    Lou
    Central Florida
    As far as I can determine the bushings and links are OEM . So I don't need changing anything else with TRD sway bar install. Can anyone confirm this.
  7. Mar 24, 2023 at 1:27 PM
    LouALouA
    Lou
    Central Florida
    Did I not see the bushings and links in your TRD thread or did you just update it? Also I noticed in the TRD web site, that if you swipe on the sway bar pix it shows what looks to be a rear sway bar. May be a different year as it doesn't show model years.
  8. Mar 24, 2023 at 7:37 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Could be the links are slightly extended due to the higher stance.
    Soupbean77 likes this.
  9. Mar 25, 2023 at 6:08 AM
    LouALouA
    Lou
    Central Florida
    Parts ordered today. I'll report back after I install them. Thank for your help.
    ryanwgregg likes this.
  10. Mar 26, 2023 at 3:24 PM
    rohmbd
    rohmbd New Member
    I'm considering ordering too. I'm hoping that the TRD Pro end Links are unnecessary.
  11. Mar 26, 2023 at 5:14 PM
    txtundra311
    txtundra311 New Member
    I have Anti sway bars in front & rear.
    Completely changed how the truck rides on hwy for the better, if you drive 90% or more on the hwy its a must, handles like a sports car now, planted in fast turns
    LouALouA[OP] likes this.
  12. Mar 26, 2023 at 5:18 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Do you have a 2022+ truck?
  13. Mar 27, 2023 at 5:13 AM
    LouALouA
    Lou
    Central Florida
    It's a 2023.
  14. Mar 27, 2023 at 5:22 AM
    LouALouA
    Lou
    Central Florida
    I requested that the vendor email me the installation instructions as Toyota is great at NOT automatically including them. Hope I actually receive it. But looking at the 3 " lift kit instructions that ryanwgregg posted. The link appears to have a larger bushing which requires a different bolt. Hopefully its included. So the TRD sway bar may require the links.
  15. Mar 27, 2023 at 6:45 AM
    txtundra311
    I had them on both my 2020 & 2023
  16. Mar 27, 2023 at 8:53 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. My 19 was a TRD SPORT so it already had it. I put one on my 14 and yes made a world of difference. I though the 22's + would already have one since it's coil now.
  17. Mar 27, 2023 at 11:53 AM
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    Please do let us know! I have a 2022 1794 6.5" and definitely can use a little more frame support via sway bar!
  18. Mar 27, 2023 at 2:22 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    The only aftermarket anti sway bars I would consider for this 3rd gen would be Hotchkis, Ridetech (close second), and Hellwig (third choice); but unfortunately they don’t have any application.
  19. Mar 30, 2023 at 1:07 PM
    LouALouA
    Lou
    Central Florida
    SITREP. Received my TRD sway bar order today. The weight is incredible. I bet the Fedex Guy is still cussing me out. Determined that TRD sway bar definitely needs the TRD links as the link is clocked differently then OEM to match the bend of the TRD sway bar mounting point. The OEM and TRD links are the same length. The TRD sway bar came with bushings, so i didn't need to order them. There was no bolts or bar link adapters included with links. So I will need to order bolt (90105-A0232) and TRD Fr stabilizer bar link adapter. I'm using the 3" lift kit instructions but I'm not lifting the truck. Page 34 says I need the bolts, but also states that the bar link adapter (shown in pink) which is included in the lift kit is also needed. Since I didn't buy the lift kit I need to order bar link adapters. Page 2 item 12 lists PT983-34340 cap, link adapter.
    ryanwgregg are you able to confirm that PT983-34340 cap, link adapter is correct?
  20. Mar 30, 2023 at 1:54 PM
    LouALouA
    Lou
    Central Florida
    The OEM diagram doesn't show the PT983-34340 cap, link adapter. The TRD link has large splines where the bolt goes through. so it needs some kind of bushing. Don't know if the OEM one is removable as I haven't disassembled anything yet. Maybe the splines line up with splines on the frame it mounts to and I don't even need the additional bolt?
  21. Mar 30, 2023 at 2:09 PM
    LouALouA
    Lou
    Central Florida
    Thanks. If the boss gives me access to her truck tomorrow, I'll do the install.:)
  22. Mar 30, 2023 at 2:17 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    It would be beneficial if you could please weigh them and report the difference. Thanks for the info you’ve been posting.
  23. Mar 31, 2023 at 2:46 PM
    LouALouA
    Lou
    Central Florida
    Sway bar replacement went well. Nothing too complicated. There is always one bolt that fights you. I didn't have a torque spec for the upper link nut. I tightened it to German spec, gutentite. All other fasteners where torqued to spec. Took a quick test drive corners much flatter. Would recommend upgrade for those of you that don't like the body roll in corners. The TRD sway bar weighs in at 45 lbs. and is 1.530" in diameter. It appears solid. The OEM is 28 lbs. and is 1.630" in diameter. It appears hollow. There was an approximate 1/2 inch gap between the end of the lower link post and the fastener washer. Maybe that is what the cap, link adapter and new bolt were designed to fill, in the the 3" lift instruction. I'm very happy with the mod.
    Kap1, Yaboy, Polo08816 and 3 others like this.
  24. Mar 31, 2023 at 2:53 PM
    rohmbd
    rohmbd New Member
    Fantastic.... just so I don't order the wrong things...
    I need to order the sway bar (bushings are included), end Links, and bolts....is that it?
    rhinoj and (deleted member) like this.
  25. Mar 31, 2023 at 2:58 PM
    LouALouA
    Lou
    Central Florida
    I reused all the OEM fasteners. Didn't need to purchase any additional fasteners. I just surmise that in the TRD 3" lift kit instructions, the cap, link adapter and new bolt were designed to fill that gap I described above.
  26. Mar 31, 2023 at 3:03 PM
    LouALouA
    Lou
    Central Florida
    The 111 Ft.lbs. was for the lower bolt. Is it the same for the upper nut? Is that the 111 in your diagram?
  27. Mar 31, 2023 at 3:04 PM
    rohmbd
    rohmbd New Member
    So just the sway bar and end Links, fantastic. Thank you
    Yaboy and (deleted member) like this.
  28. Mar 31, 2023 at 3:07 PM
    LouALouA
    Lou
    Central Florida
    I may buy the cap, link adapter and new bolt. They are cheap. Just to satisfy my my curiosity.
  29. Mar 31, 2023 at 3:13 PM
    LouALouA
    Lou
    Central Florida
    It was covered in bubble wrap from the factory. The end links where in a bubble wrap pouch. It was shipped in a box surrounded by paper. One end of sway bar did poke out of the box in shipping. I will see if they have touch up paint as there is a couple of nicks to bare metal. Just to prevent rust. The FedEx guy wrote very heavy on the outside of the box.
  30. Mar 31, 2023 at 4:48 PM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    May I ask how much it would cost to acquire a sway bar
