Trick or tips to remove door window trims
Discussion in '3rd Gen Tundras (2022+)' started by SD.Tundra.858, Feb 12, 2023.
  1. Feb 12, 2023 at 1:03 PM
    SD.Tundra.858
    SD.Tundra.858 [OP] Family man...Toyota fan! Best spices in town!
    Travis
    San Diego, CA
    2023 Black Limited 4x4 w/ Platinum package
    Anybody have any tips or tricks removing the Chrome window trim around the doors windows? I ordered Toyota OEM blacked window trim. I don't want to jack up the Chrome ones that are in there in case I decide to put them back in. However, they seemed fairly difficult to get out but I'm sure it's probably pretty simple with the right tool or the right approach. Any suggestions are welcomed!
    Taikowaza and Soupbean77 like this.
  2. Feb 13, 2023 at 2:59 AM
    Taikowaza
    Taikowaza New Member
    Take your time, don’t force, use an inexpensive trim removal tool. Got mine off no problems, some great videos on YT.
    Soupbean77 and SD.Tundra.858[OP] like this.
  3. Apr 15, 2023 at 9:27 PM
    GigTundra1976
    GigTundra1976 New Member
    Gig Harbor, WA
    2023 Limited Crewmax 5.5 MBM
    RB20 (slim), oem bed mat, tri-fold, bed step, cheap chrome-delete door handle overlays.
    Same problem. There’s that one guy on YT with the blue tundra. His pops off with a screw driver. I tried and tried.
    There seems to be two layers once you get push down the rubber gasket closest to window (for the vertical piece in back) I tried prying under both and just the chrome top layer working my way bottom up. Got it to pop a little under just the chrome layer but in doing so I bent the lip slightly. Too scare to give it another go.
  4. Apr 16, 2023 at 12:03 AM
    Taikowaza
    Grab the entire trim, both sides with your bare hands. I don’t suggest using a screwdriver you’ll bend the the part. Gently coax it up, changing spots until you feel it pop off the window, you’ll know when it’s free
  5. Apr 16, 2023 at 8:14 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    There’s a thread on this, I can’t find it
  6. Apr 16, 2023 at 8:43 AM
    Taikowaza
    Yaboy[QUOTED] likes this.
