Truck bed camping build out
Discussion in '1st Gen Tundras (2000-2006)' started by Timtam, Apr 1, 2025.
  1. Apr 1, 2025 at 7:50 PM
    Timtam
    Timtam [OP] New Member
    2002 Gold Tundra AC
    Chunkier tires and some custom floor mats, working on a camping setup in the back!
    Howdy all,
    I got these two heavy duty plastic drink pallets for free and want to use them as the base for a camping set up. Going to fill the margins on the sides with some flip up storage or something but wanted the masses opinions in case anyone else had some creative ideas!
    It's gotta be supported all the way across because we have a double camping mattress
    Apologies if this is posted in the wrong thread
    G_unit3000 and Wallygator like this.
  2. Apr 1, 2025 at 7:58 PM
    Need a few more of them. Honestly though, don’t get too locked into using them for your truck camping build, you can likely build it out better not having to work around those. Not sure how much those even weigh.
    FrenchToasty and Wallygator like this.
  3. Apr 1, 2025 at 8:30 PM
    Timtam
    2002 Gold Tundra AC
    They are about 35lbs each, mostly wanted to use them because they were free
  4. Apr 1, 2025 at 11:09 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    You might be better off with some 2x10’s to get you over the wheel. This will allow you to use the bottom for storage and give you some flip up storage on the side
    This is an old pic of mine, I have a double cab so my bed is deeper than an AC. I have my bed on the left. And I can fit the standard 10in tote under it (2 wide and 2 deep) and still have room for my shoes and stuff
  5. Apr 2, 2025 at 3:32 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. Apr 2, 2025 at 6:41 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I agree with knabores. They might limit you more than help. I definitely get seeing something like that for free and thinking it'll be a great start for a camping setup, but I also wonder if they're going to cause more trouble than help. IMO they aren't long enough, wide enough, or tall enough.
    ATBAV8 and FrenchToasty like this.
  7. Apr 2, 2025 at 8:13 AM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    You're going to lose head room by building those decks ...
  8. Apr 17, 2025 at 3:38 PM
    Timtam
    2002 Gold Tundra AC
    Ended up building it with the pallets anyways. Made it work with stuff I already had laying around. Pretty simple, but really just needed a flat place for the mattress. Here's the final product! 20250416_201153.jpg
    FJ432 likes this.
  9. Apr 17, 2025 at 3:56 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Mustanley and KNABORES like this.
  10. Apr 17, 2025 at 6:18 PM
    Wait, isn't that the inverse?
    KNABORES likes this.
  11. Apr 19, 2025 at 7:26 AM
    MT-Tundra
    Montana
