Truck rolling backwards from Park on slight incline driveway
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by askochis, Mar 2, 2023.
  1. Mar 2, 2023 at 1:56 PM
    askochis
    askochis [OP] New Member
    Alan
    2014 TRD Limited Tundra
    2014 Tundra, TRD Pro, Limited owner here. Yesterday, I got home and had to rush in for a phone call and forgot to apply my parking brake (which I usually always do!). A few hours later i noticed my truck had creeped down the driveway a considerable amount - about 5 or 6 feet from where it was originally parked. I attributed it to snow melting under the rear tires and the car creeping with it and called it a day but then it happened again today. I tested it without the parking brake and lo and behold - 4 hrs later the freaking truck was 5 feet down the driveway again! I obviously wont be parking without the e-brake from now on (pretty much like i always do) but surely this amount of creeping is not normal? Video is below and any help/advice is appreciated, I'm scratching my head on this one especially with how SLOW it moves but will get it in to get looked at it too ASAP.
    https://www.youtube.com/watch?v=jfJ_pIkxYOQ
  2. Mar 2, 2023 at 3:38 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Sir, you may have transmission park issue. It should not roll that much once in "P" = park.
    fuzzamungus, FlyingWolfe and KNABORES like this.
  3. Mar 2, 2023 at 3:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have this issue with my parking brake too, it will move a few inches every time then stop, when it stops is when i put it in park from neutral. I really need to adjust the parking brake cable one of these days. Its a common issue i hear on these trucks.
  4. Mar 2, 2023 at 3:40 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Yeah...WTF...
  5. Mar 2, 2023 at 3:43 PM
  6. Mar 2, 2023 at 3:43 PM
    MadMaxCanon
    not tryin to be a dick but are you sure it was in P?
  7. Mar 2, 2023 at 3:46 PM
    AZBoatHauler
    So.Arizona
    I’m having deja vu - last time it was concluded it was melting ice under the tires causing it to slide. I don’t think it’s a coincidence the truck is parked on a pile of ice. I doubt the wheels rotated as it slid. Gravity and lack of friction doing its thing.
  8. Mar 2, 2023 at 3:47 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Well, that ain’t right lol. I see in the video the front and rear wheels are indeed spinning as it rolls down the driveway.
  9. Mar 2, 2023 at 3:47 PM
    askochis
    Alan
    This is the original video when it was parked on ice, not the second time when it wasn't parked on ice.
    AZBoatHauler[QUOTED] likes this.
  10. Mar 2, 2023 at 3:48 PM
    Rockwell
    Rockwell New Member
    New Jersey
    2021 Tundra Crew Max SR5
    This is insane! I've had this happen before with vehicles, but it has always been due to ice. Never in park on dry ground.
    WTH? I mean is the parking pawl just not engaged at all? or just slightly? if that's even possible?
    I would definitely show that video to Toyota and have it looked at. I'll be keeping an eye on mine now, that's for sure.
    Please follow up if you find the culprit.
  11. Mar 2, 2023 at 3:49 PM
    AZBoatHauler
    So.Arizona
  12. Mar 2, 2023 at 3:50 PM
    AZBoatHauler
    So.Arizona
    ^yep I found the other thread. Weird it looks like the back wheels turn.
  13. Mar 2, 2023 at 3:53 PM
    Taco-Spike
    Two Trucks
    Ants.
    Lots and lots of ants. They shady AF
    AZBoatHauler and Rockwell like this.
  14. Mar 2, 2023 at 3:54 PM
    Perhaps the grinding noise was incomplete disengagement of the parking pawl. Now it’s worn and won’t hold the truck.
  15. Mar 2, 2023 at 3:56 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Park the truck nose towards the street and see if it does the same thing.
  16. Mar 2, 2023 at 3:57 PM
    matictundra
    Franco
    AZ
    Video shows rear tire is turning. I would take it to the dealer for sure if you are sure you had it in park. You driveway is not even an extreme incline.
  17. Mar 2, 2023 at 3:58 PM
    askochis
    Alan
  18. Mar 2, 2023 at 4:00 PM
    askochis
    Alan
    I am certain 100% certain it was in park - i reproduced it today and triple checked it was in park. So bizarre
  19. Mar 2, 2023 at 4:03 PM
    AZBoatHauler
    So.Arizona
    Wouldn’t be able to get the key out if it was left in gear - never would have held in N.
  20. Mar 2, 2023 at 4:03 PM
    askochis
    Alan
    This is a really good idea! I'll try that tomorrow morning when I get back. Here's the craziest part - it's almost like when the sun warms the truck up it causes it to creep... scared that it is the transmission now though....ugh
  21. Mar 2, 2023 at 4:03 PM
    you had your suspicions then
  22. Mar 2, 2023 at 4:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    When you get back in it, is it still in P or is there a visible sign of slippin outta gear with it being in a different setting?
  23. Mar 2, 2023 at 4:09 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have the same year truck as you, my drive way is on a cul-de-sac but my driveway appears steeper. I have only ever used the parking brake when I park on the incline with the boat (3700 lbs) of the enclosed trailer.
    Have never had it move, snow/ice/concrete...never moved.
    When I do use the parking break I put the the truck in neutral with the brake applied, keep the brake applied and set the parking brake. Let go of the regular brake to make sure the enough parking brake is applied and the truck doesn't creep backwards, and then put the truck in park.
  24. Mar 2, 2023 at 4:21 PM
    Retired...finally
    I couldn't see it it the video but if both the rear wheels are in fact turning in the direction it's rolling there is an real problem. Seems more likely one is turning backwards on ice or snow.
  25. Mar 2, 2023 at 5:22 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Ford had a recall in 2020 for some trucks. The shift cable was not installed correctly which allowed the key to be removed without the vehicle being in park, despite the gear select showing to be in park… allowing it to roll.
    Maybe your transmission cable needs some maintenance.
    If your truck was a Ford f150… be glad it’s not because the forum there does not seem to be so cooperative in solving problems (judging from one really long post about a 150 rolling when supposedly in park).
  26. Mar 2, 2023 at 5:26 PM
    askochis
    Alan
    Absolutely and it's still nightmare fuel!
  27. Mar 2, 2023 at 5:30 PM
    askochis
    Alan
    I'm pretty sure I saw these threads yesterday as I was googling....seemed eerily similar
    Toyota service said they'd call me back but I assume that won't be until tomorrow.
  28. Mar 2, 2023 at 5:58 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Damaged parking pawl is one possibility. Other is you have one wheel on ice and non-LSD which can roll if one wheel slips.
  29. Mar 2, 2023 at 6:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    With an open diff in the rear axle, it only takes one rear wheel to slip for the truck to slide backwards. The other wheel will roll.
    Is your Tundra 4wd? Park it in 4hi, and see if it stays put.
    Retired...finally likes this.
  30. Mar 2, 2023 at 6:51 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
