Truck turns off then on when I put it in park
Discussion in '3rd Gen Tundras (2022+)' started by Billiam, Sep 22, 2023.
  1. Sep 22, 2023 at 12:39 PM
    Billiam
    Billiam [OP] New Member
    Bill
    2022 Tundra TRD Double Cab
    Does anyone have this problem? I know at a traffic light if you press the brake farther it will shut the engine off but my problem is I will pull up somewhere put it in park, Engine shuts off then instantly turns right back on doesn’t do it all the time, but does it often enough to be irritating? Sometimes I will Park it and it will shut off and not turn back on until I touch the brake. All this is done without me manually turning off the engine or restarting the engine. This is for a 2022 tundra SR5 Trd.
  2. Sep 22, 2023 at 12:50 PM
    When you pull up and come to a stop, you’re pressing the brake hard enough to allow for stopping and shifting to park, which activates the start stop since the truck didnt know your intentions. Then once in park, it’s programmed to restart the stop/start cycle. More of a use not fitting design parameters. Not a fan of stop start.
  3. Sep 22, 2023 at 12:52 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    unbuckle your seatbelt before shifting into park, wont do it
    KNABORES likes this.
  4. Sep 22, 2023 at 2:03 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Welcome to the forums
    Turn off ASS
  5. Sep 22, 2023 at 2:07 PM
    SD Surfer
    Bruce
    So Cal
    We had a "Jeep" (I use the term loosely 'cuz this POS little clown car shouldn't be allowed to wear the Jeep name) rental car in Moab April with this ridiculous feature... you couldn't pay me enough to have this on my vehicle.
    It probably looked like I was having a siezure 'cuz of the way the car was jerking around at stoplights from me taking my foot on/off the brake so it wouldn't shut off.
    snivilous likes this.
  6. Sep 22, 2023 at 2:55 PM
    SD Surfer
    Bruce
    So Cal
    So does my turlet, but I don't get the correlation. :oops:
  7. Sep 22, 2023 at 3:01 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    I compliment Toyota every time the engine stops then turns back on after shifting into park in a parking spot.
  8. Sep 27, 2023 at 6:45 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    I had that problem too. I am very light on the brake and the engine would never stop in traffic. Only shut off and restart instantly when I put truck in park. So I corrected issue with this https://www.ebay.com/itm/1256660966...=2047675&ssuid=&widget_ver=artemis&media=COPY
    EmergencyMaximum likes this.
  9. Sep 27, 2023 at 10:15 AM
    Leatherhead237
    Leatherhead237 New Member
    Massachusetts
    2023 1794 TRD Off-Road
    Like was stated before, it is a function of the Auto-start/stop. Either buy a product to disable ASS, remember to turn it off when you start the truck, or get used to unbuckling your seatbelt before shifting to park.
    Mattedfred likes this.
  10. Sep 27, 2023 at 2:45 PM
    iforceAZ
    iforceAZ New Member
    Same issue. I'm training myself to turn off start stop before I park.
  11. Sep 28, 2023 at 7:17 AM
    mcnabb100
    mcnabb100 New Member
    I think the issue is caused by the auto e brake. When you shift into park it applies the brake, which drops the pedal and triggers ass.
    You can turn the auto brake off but i leave mine on because I park on an incline.
  12. Sep 28, 2023 at 7:50 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Mine does it only when I arrive at work with my seat belt on. Tested this morning and belt undone before shifting to park it didn’t activate.
    Never activates when I get home with my seatbelt still on.
    Difference:
    My work parking spot is flat and level, home driveway is sloped uphill a fair amount.
  13. Sep 28, 2023 at 10:28 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Turning off the silly auto stop/start feature is part of my pre-fight checklist every time I start my truck.
    Azrsx likes this.
  14. Sep 28, 2023 at 10:37 AM
    eddiefromcali
    Eddie
    100% Stock
    :fistbump:
    :argue:
    :duel:
    :rant:
    :smack:
    :fenforcer:
  15. Sep 28, 2023 at 10:54 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    I don't have an issue with mine if its shuts off after shifting to park. What usably happens is you stop to park and it shuts off and immediately restarts as you shift into park every now and then it stays shut off. Funny thing one time in a parking lot a 2nd gen owner came up and asked me what it was doing because he heard it stop and restart itself.
  16. Sep 28, 2023 at 11:03 AM
    rx3
    rx3 New Member
  17. Sep 28, 2023 at 11:04 AM
    eddiefromcali
    Eddie
    100% Stock
    It's quite embarrassing when it does that, at least to me
