Truck won't unlock after remote start
Discussion in '3rd Gen Tundras (2022+)' started by L-P-G, Sep 29, 2024.
  1. Sep 29, 2024 at 6:25 PM
    L-P-G
    L-P-G [OP] New Member
    2024 Platinum
    Anyone else have this issue. Remote start vehicle (fob or app, doesn't matter). Touch door handle or press the unlock button on the fob, the truck does nothing, won't unlock or turn off the engine. The only way to unlock is to use the app.
    Then, after using the app to unlock, to start the engine I have to put the key next to the button as requested on the dash.
  2. Sep 29, 2024 at 6:45 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Check the battery on your fob, it may be dead.
    GODZILLA and Tundrastruck91 like this.
  3. Sep 29, 2024 at 7:03 PM
    Paulswagelock
    Paulswagelock New Member
    Mine has a similar bug. If I unlock door with app, I can’t start the truck, just get an error on the dash telling me I need the key fob. I have to use the remote to lock and unlock then everything works.
  4. Sep 29, 2024 at 7:30 PM
    L-P-G
    2024 Platinum
    Fob works fine when the truck is not remote started. Unlock, lock remote start and touch unlock/lock all work fine.
  5. Sep 29, 2024 at 8:45 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    You link fob to profile?
    TFTJ likes this.
  6. Sep 30, 2024 at 2:54 AM
    TFTJ
    TFTJ New Member
    Was gana say this - you should link the fob you have in your pocket to the profile when it starts. Make sure you dont have the other fob with you when you do it.
  7. Sep 30, 2024 at 4:35 AM
    L-P-G
    2024 Platinum
    Did it on day 1 when I bought the truck.
  8. Sep 30, 2024 at 5:19 AM
    TFTJ
    TFTJ New Member
    Have you tried reattaching your profile?
  9. Sep 30, 2024 at 5:20 AM
    DRP
    DRP Old Member
    Dave
    Does it happen with both FOBs? I realize you may not have both yet but thought I'd ask. Either way, even though the FOB seems to be working ok, I'd replace the battery just in case it's weak.
  10. Sep 30, 2024 at 7:11 AM
    iforceAZ
    iforceAZ New Member
    Maybe they are like computers now and we reboot them...lol.
  11. Sep 30, 2024 at 7:36 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Check your battery connections too. When I disconnected my battery for grill swap my fob acted screwy shorty after, I got the message to hold it on the start button. Only happened once though
  12. Oct 5, 2024 at 5:26 AM
    L-P-G
    2024 Platinum
    Yep, I've deleted the profile and re-attached it to the fob.
    This one I have not tried. I'll try it today and see what happens.
    Yea, once I wouldn't think much of it. Every time I use remote start tho, is a totally different story.
    Weird enough, I noticed that if I don't interrupt the 10 min countdown to when the engine shuts off on its own. Then, the issue is nowhere to be found, it seems to only be an issue during the countdown itself.
  13. Oct 5, 2024 at 6:32 AM
    Observer
    Observer New Member
    With all the electronics today who knows. But if you will, a bit of a hail Mary . If the battery on the fob is weak, using it to start the truck might deplete it enough temporarily to not be able to give out a strong enough signal till it recovers.
  14. Oct 5, 2024 at 6:35 AM
    Observer
    Observer New Member
    Here is a odd question for you. Is the truck in the garage when this happens?
    Story time - couple of years ago I replaced the light bulbs in my garage door motor with LEDs . After doing this in the morning I would start the truck "key operated at that time" open the door and back out but my garage door opener would not close the garage door. Long story short after searching the internet found out that the electronic pulse from the LED light bulb was interfering with the garage door signal. Change to a different light bulb and everything was back to normal.
  15. Oct 5, 2024 at 8:13 AM
    DRP
    DRP Old Member
    Dave
    I've had similar experience with LEDs i used to replace fluorescent lights in the garage. Didn’t affect the opener but definitely messed with FM radio reception. Cheapo LEDs were the problem.
    Observer[QUOTED] likes this.
  16. Oct 22, 2024 at 8:40 PM
    L-P-G
    2024 Platinum
    I wish the truck fit in the garage. It's the long bed so the wife gets to park in the middle of the garage now.
