TruckyTruck's Build
Discussion in '2nd Gen Builds (2007-2013)' started by TruckyTruck, Jan 7, 2014.
  1. Jan 7, 2014 at 3:58 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    2013 TSS Off-Road
    5.7l Crewmax
    Sr5 w/leather, 4x4
    May 2013
    Stock:
    Mods:
    *Ceramic based CTX window tint 30% All the way around.
    *Intake Carbon filter delete
    *Intake gasket w/o screen
    pt# 22271-50050, behind throttle body. This is to get rid of the whistle you hear very badly if you have a drop in air filter.
    *TRD air flow accelerator
    *Toyota Tundra bed rail system
    *TRD wheel locks (sold along with TSS wheels)
    *Paracord interior handles
    *White led lights in cab ceiling
    *Relocated differential breather
    Union - M10 x 1.00 Thread Pitch, 3/8” Barb Toyota part #90404-51319, Breather Plug part #90930-03136
    *Tailgate anti-theft/deterrent
    Just a simple hose clamp wrapped in electrical tape, to avoid scratching the paint.
    *Radar detector mounted and hard wired
    *De-badged only Tundra emblems on front doors and Toyota emblem on tailgate
    *Passenger seatbelt anchor
    *Custom Tekonsha P3 Brake Control install
    *Complete sound system overhaul
    -Kenwood Excelon DDX491HD Head Unit
    http://www.crutchfield.com/S-fb0BKBD67VX/p_113DDX491H/Kenwood-Excelon-DDX491HD.html
    -Replaced with Alpine 6x9s
    6x9 image dynamics front
    http://www.sonicelectronix.com/item_22336_Image-Dynamics-CTX-69.html
    -6.5 image dynamics rear
    http://www.sonicelectronix.com/item_22335_Image-Dynamics-CTX-65.html
    -Polk D4000.4 125 rms per channel amp
    http://www.polkaudio.com/products/pad4000_4
    -Replaced with Polk Monoblock
    Eclipse 300 rms sub amp that I've had for 10 years
    -Slim custom sub box made by Tech12volts
    made with 5/8 mdf and fiberglassed inside for strength. They guy who made it for me took the sub specs I gave him specifically for that sub and built the box to fit it and the slim space for my crewmax. It ran me 175 shipped.
    -Pioneer TS-SW3001S4 12 inch slim mount
    http://www.sonicelectronix.com/item_18212_Pioneer-TS-SW3001S4.html
    -e2 EWDB2 by Scosche fused dist block
    http://www.sonicelectronix.com/item_15319_e2-EWDB2-by-Scosche.html
    -Stinger SHD201 inline anl fuse holder
    http://www.sonicelectronix.com/item_17748_Stinger-SHD201.html
    -NVX XW0BL20 1/0 gauge wire 20 ft
    http://www.sonicelectronix.com/item_46862_NVX-XW0BL20.html
    -NVX XW4BL5 4 gauge 10 ft
    http://www.sonicelectronix.com/item_40534_NVX-XW4BL5.html
    -NVX XW4GR5 4 gauge 10 ft
    http://www.sonicelectronix.com/item_40535_NVX-XW4GR5.html
    -Xscorpion ANL250PL 250 amp inline fuse. Bought 2 just in case
    http://www.sonicelectronix.com/item_39076_Xscorpion-ANL250PL.html
    -Xscorpion ANL80PL 80 amp dist block bought 4 just in case
    http://www.sonicelectronix.com/item_39080_Xscorpion-ANL80PL.html
    -Stinger SI421.5 2 for Lc7i to door speaker amp
    http://www.sonicelectronix.com/item_38862_Stinger-SI421.5.html
    -Stinger SPT5101 1/0 gauge terminal
    http://www.sonicelectronix.com/item_42113_Stinger-SPT5101.html
    -Taco tune adapters for front and back. The rear adapters had to have the speaker hole widened. And the fronts didn't work with the 6x9s that I bought. Which was strange because taco tunes recommends them. I had to use a 5/8 inch thick piece of wood cut out in the shape of the adapter to add to making the magnet clear the speaker.
    -One very important thing to me was not to lose any functionality of the rear seats lowering and moving. The amps were mounted under the seats so they wouldn't interfere with the seats.
    *Raamaudio sound deadening all 4 doors and rear wall
    *Exhaust:
    -BAMuffler made by Keith Carty owner of DirtyDeeds Industies
    Dual exhaust system made for TRD pipes, all done in stainless steel, X-Pipe, Resonators welded onto the system directly behind the mufflers. In high temp black paint.
    -TRD Pipes black satin ceramic coated
    -TRD Pipes set came with hanger for the extra pipe and a new wider heat shield
    -I think I may have watched every video on the web with Tundra exhaust systems. Thats what it feels like anyway. I wanted to make sure I got the right sound and that it wasnt too quiet and that it wasnt too loud. After talking with Keith from BAMuffler and going over it in my mind for about a month, I finally ordered my system with a plan in mind to have something unique. I then ordered my TRD pipes and sent them to the ceramic coat guy who took about a week to get them back to me.
    -I ended up with exactly what I wanted, so maybe this could help someone else to decide too.
    My suggestion would be to listen with a good headset.
    http://m.youtube.com/watch?v=ddH9718IKLI
    *Door sill protection
    https://www.tundras.com/threads/skate-or-diy-12-door-sill-protection.657/
    *Fuel Octane Wheels 20x9 +20 Offset
    *Flashlight Mod
    *Lock'er Down Safe
    *Front Seat and Console Covers
    carconsolecovers.com
    *Removed September 2019. New setup below.
    2015
    Front: Fat Bobs Coilovers, Light Racing UCA's & Coachbuilder Shims
    Rear: Coachbuilder +3 Shackles & Polyurethane Bushings
    3.25 inches in front lift
    1.5 inches in the rear
    Measurements from the center of my hub to the fender:
    Front, both 24.5
    Rear, both 25.5
    Front and bottom of side step, both 14.75
    Rear and bottom of side step, both 15
    *First set lasted 100k miles. On my second set.
    Toyo AT2 Extremes 35×12.5×20
    *Hypertech In-Line Speedometer Calibrator - Part #730103
    *Body Mount Chop
    Relentless Fabrication Plates
    *Torque App and Bluetooth OBD Dongle
    http://www.amazon.com/gp/product/B00H9S71LW?redirect=true&ref_=ya_st_dp_summary
    *Removed and waiting for new bumper
    Baja Designs Squadron Pro Driving Combo Led Lights
    *Tool Box
    https://www.tundras.com/threads/truck-box-security.5644/page-2
    *Removed for OV Tune
    Dap Tune 12-26-17
    daptuning.com
    *Slotted Frozen Rotors
    http://www.frozenrotors.com
    *Custom Made Cooler Security
    *Electrical Panel
    *Elka Suspension
    *Alcan Springs
    *Coachbuilder +1 Shackles
    *Wheeler's Superbumps
    Front and Rear Springs
    *SPC Light Racing Ball Joints
    Upgraded Version With Zerks
    *OV Tuned
    Dyno on my truck / 9-4-2019
    https://youtu.be/u4OeADRd5Ig
    OV Tune post after Dyno
    https://www.tundras.com/threads/ovt...development-thread.44977/page-29#post-1367859
    *My Lift Thread With Measurements
    https://www.tundras.com/threads/second-gen-lift.53517/
  2. Jan 7, 2014 at 6:43 PM
    T-Rex266 SpaceX Director Staff Member
    Exhaust sounds nasty! Love it!
    NoMoTaco and TruckyTruck[OP] like this.
  3. Jan 7, 2014 at 6:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That does sound sick! Looks great too. What are your thoughts on a corsa exhaust?
    TruckyTruck[OP] likes this.
  4. Jan 7, 2014 at 7:40 PM
    I've heard great things about them...I forgot why I decided not to go with it though :(
  5. Jan 7, 2014 at 7:50 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I had a trd on my Tacoma and i loved it. I think for the tundra the corsa is single exit and the trd is dual exit, which I do think looks nicer. Price is similar. I think corsa sport may be louder than the trd?? Not sure.
  6. Jan 7, 2014 at 8:08 PM
  7. Jan 7, 2014 at 8:21 PM
    TruckyTruck
    Gary
    Corsa sounds pretty good, but the problem with all dual exhaust set ups on the tundra is the change in the powerband. All dual set ups will cause some drop in the low end for our trucks. The reason I went with this particular one, was the straight thru muffler design, an xpipe, and it uses the dual trd tail pipes. Those things will make it to where it barely loses any of the low end. I think with a lot of set ups you are going to have a fairly good loss. The best set up for to and power gain with the tundra if you are not doing headers or have a charger, would be a straight thru design that utilizes the single out stock tail pipe. The only reason I know any of this was research and the gentleman I purchased mine from has dyno'd the tundra with numerous setups to see what works best. That being said... The truck has a load of power, so you may not even notice that tq loss.
    Lancewall0719 and MotoTundra like this.
  8. Jan 7, 2014 at 8:29 PM
    I went with a single exhaust as it's one less thing to worry about ripping apart if you wheel...I'll try to get some video this week of mine...but, the exhaust shop suggested a single exhaust as well due to the possibly of losing power...
  9. Jan 7, 2014 at 8:39 PM
    TruckyTruck
    Gary
    Yeah probably so. Toyota has the tundra dialed in pretty well. I'd like to see that video. I decided on duals just in case I go with headers. One thing a guy can do to bring back a lot of that low end tq is to get a hypertech interceptor. When I installed mine it felt like it brought it back and then some.
  10. Jan 7, 2014 at 8:42 PM
    TruckyTruck
    Gary
    That corsa isn't true duals is it... it might be pretty good. I've only seen them online.
  11. Jan 7, 2014 at 8:53 PM
    That's the programmer that recals the spedo for the bigger tires? If so, that's what I have.
  12. Jan 7, 2014 at 9:01 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    The corsa is all single with twin tips.
  13. Jan 8, 2014 at 6:35 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    That exhaust is supposed to add 89 ft/lbs to a stock tundra... OP do you think you got that?
  14. Jan 8, 2014 at 6:40 AM
    TruckyTruck
    Gary
    They make the speedometer unit and a tuner for the tundra. I've got the tuner. It's pretty nice. Changes shift points and holds out the 6th gear when you are on the hwy instead of down shift g at the slightest press of the pedal. It also De-sensitizes the pedal on take off. So it doesn't jump so hard if you just press it for normal acceleration. And gives I think 17 hp and 21 tq.
  15. Jan 8, 2014 at 6:41 AM
    TruckyTruck
    Gary
    The full race system with headers is supposed to, but I have true duals from the cats back. I do plan to have it dyno'd though to see where it's at
  16. Jan 9, 2014 at 10:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Love this truck. Want to sell it to me?
  17. Jan 9, 2014 at 10:30 PM
    csuviper
    Broomfield, CO
    What features does the TSS Off-Road have over the SR5 or TRD Off-Road?
  18. Jan 10, 2014 at 10:19 AM
    TruckyTruck
    Gary
    Ha, yeah its my favorite truck I've owned. The TSS package is something gulf states Toyota does. It's purely cosmetic. So the truck is a 4x4 with an sr5 package and then they add the 20s, black steps, floor mats and decals. I think the skid plate is a little different too. There may be a couple other things I'm not thinking of, but you get the basics. It's cosmetic. After this pic I removed the tundra badging off the doors and the little Toyota badge above the tundra badge above the tailgate. All the other badging I am going to leave on the truck including the SS decals. The trd off - road actually has the bilstein shocks and this one has the sr5 shocks. I was OK with that because I plan to change them to what I want.
  19. Jan 19, 2014 at 6:48 PM
    TruckyTruck
    Gary
    Just got done with a complete stereo overhaul.... I am beside myself with how awsome it came out. Took me about 40 hours. A lot right? Well it took that to do it perfext and keep all the functionally of the rear seats. Ill be posting the crap out of this thread with all my mods and this stereo overhaul. Man I love trucks, more specifically mine. Ha
  20. Jan 19, 2014 at 6:50 PM
    csuviper
    Broomfield, CO
    Nice. Def want to see all the details.
  21. Jan 19, 2014 at 8:08 PM
    X2
  22. Jan 29, 2014 at 8:20 PM
    TruckyTruck
    Gary
    Updated! Finally... still have pictures on 3 different devices, so I have more including one that might be important, the location of the diff breather. Anyway, ive got more to come and a list of ideas... enjoy.
    The sound system is almost completed so ill get thos pics up soon.
  23. Jan 29, 2014 at 9:37 PM
    csuviper
    Broomfield, CO
    Very nice. Keep adding in the photos for all the mods. Curious about a couple.
    Did you wind up the para cord on the handles yourself?
    Is the tailgate anti theft just a hose clamp?
    What is the seatbelt anchor?
  24. Jan 29, 2014 at 9:42 PM
    TruckyTruck
    Gary
    Yes, I wrapped the Paracord myself. Super tight so it would feel solid.
    You got it, just the hose clamp. It already has the lock on the tailgate, bit just in case I did it. I also used black electrical tape around the hose clamp be for I put it on so it wouldn't hurt the paint.
    Seatbelt anchor- you ever ride around with your windows down and the front passenger belt flops around? Well I bought a factory anchor for the pillar and installed it. I'll get a pic up tomorrow.
  25. Jan 30, 2014 at 7:03 AM
    TruckyTruck
    Gary
    Should I bring down the size of the larger pictures? It seemed fine from my phone, but looking at it on my computer this morning, the pictures are HUGE! And is there anyway to resize them without taking them down and replacing them? I like the exhaust picture size.
  26. Jan 30, 2014 at 4:54 PM
    @Bob
  27. Jan 30, 2014 at 5:33 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    lookin good!!!
  28. Jan 30, 2014 at 8:49 PM
    TruckyTruck
    Gary
    I'm thinking I may need to replace them with thumbnails :pccoffee:
  29. Jan 30, 2014 at 8:55 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    this forum will resize them to fit properly on whatever device someone is viewing it with...so no need to, unless you think they're too big in general
  30. Jan 31, 2014 at 7:26 AM
    TruckyTruck
    Gary
    oh ok, I just didn't want it to mess people up. ive got a lot of pictures... ha
