trusted Fumoto, bad on me
Discussion in '2.5 Gen Tundras (2014-2021)' started by belairbrian, Feb 25, 2023.
  1. Feb 25, 2023 at 4:26 PM
    belairbrian
    belairbrian [OP] New Member
    2016 Crew Max 4x4 TSS
    Well I was doing an oil change yesterday and was planning to swap in a Fumoto valve.
    Drain went great, no splashing, every drop in the pan.
    Using a brass filter drain kept every thing nice and neat. Even used my new thread in funnel. About that time I had a thought could they possibly ship the valve in the open position. Never even considered it. Figured since it was going in after draining the oil it would be shipped closed.
    You probably figured out by now, it was open. Climbed under and it was pouring oil. Got it closed empited a bag of absorbent and grabbed some more oil.
  2. Feb 25, 2023 at 4:33 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    That's funny right there.
    All due respect, but isn't there a handle that's either parallel with the valve body or perpendicular to it? Just like any other valve, it's open when the handle is aligned with the valve body..?
    I think it locks closed too, no?
    Sundog, snivilous, bulldog93 and 6 others like this.
  3. Feb 25, 2023 at 5:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I wish I could count on that always being the case. I have received 1/4 turn 1" manual valves at work that had the handle installed wrong. General rule of thumb - yes. But always verify.
  4. Feb 25, 2023 at 6:25 PM
    I went to a Fumoto valve to be able to shut off the flow. One time, many moons ago I was changing the oil on my Cummins powered truck. I forgot to open the cap to the pan. Yep...3 gallons of soot filled black all over my driveway. A Fumoto valve was ordered that day and every vehicle since has had them installed.
    Crap happens. You are definitely not the first or last.
  5. Feb 25, 2023 at 6:39 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    We've all been there.
    But!
    Henry1jg, 1UP, bgdv1 and 4 others like this.
  6. Feb 25, 2023 at 6:59 PM
    AZBoatHauler
    So.Arizona
    Pro tip - when you can see through it, the valve is open.
  7. Feb 25, 2023 at 7:06 PM
    Backslider
    Tooele, UT
    I don't need a fancy Fumoto valve to spill hot oil all over my garage floor. :)
    Ericsopa, Txexplorer23, LS3 and 18 others like this.
  8. Feb 27, 2023 at 9:04 AM
    Rocko9999
    Rocko9999 New Member
    I don't get the love for those valves. Is a tried and true, very secure, drain plug really that much trouble for people?
    TWJLee likes this.
  9. Feb 27, 2023 at 9:20 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    With aftermarket skidplates they make oil changes SO much easier.
  10. Feb 27, 2023 at 9:23 AM
    AZBoatHauler
    So.Arizona
    My issue with a drain plug is the force of two gallons would cause splatter from the drain pan all over the passenger side tire. Way messier than it needs to be.
    Gaston, fuzzamungus and Wallygator like this.
  11. Feb 27, 2023 at 3:56 PM
    eagleguy
    eagleguy New Member
    LOL
  12. Feb 27, 2023 at 3:59 PM
    eagleguy
    eagleguy New Member
    I just bought the valve drain hose and safety clips direct. The company forgot to send me the valve and the clips and then sent me the WE FORGOT email. Shame, shame
  13. Feb 27, 2023 at 4:18 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I’ve changed over 200k miles of oil with mine and love it. I never spill oil… with that part anyway :rolleyes: doing the filter is just a train wreck for me every time!
  14. Feb 27, 2023 at 4:20 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    A design flaw on the RCI skid plate necessitated a Fumoto for me just so it was offset enough not to make a mess at the end of the drain
    Wallygator likes this.
  15. Feb 27, 2023 at 4:59 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Get one of these... Amazon.com: Motivx Tools Oil Filter Drain Tool Compatible with Toyota, Lexus and Scion Vehicles with Cartridge Style Oil Filter Systems : Automotive
    They're awesome.
    Dave
  16. Feb 27, 2023 at 8:31 PM
    TruckyTruck
    Gary
  17. Feb 28, 2023 at 2:43 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
  18. Feb 28, 2023 at 4:48 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    It wasn't always this way (as us long time Fumoto guys know).
    But now when you buy a Fumoto valve these days you get a black plastic "clip" that slides on and over the lil' valve "handle." It will ONLY go on when the valve is closed. Only when closed.
    WVI, Wallygator and Tundrastruck91 like this.
  19. Feb 28, 2023 at 4:53 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i believe it's sent "open" so that when you put an open ended wrench on it to tighten it up, the lever isn't in the way and having the potential of being bent/broken. sucks for the lesson tho, but better than you trusting it all and driving off with a nice trail of oil following you with a jacked up motor because of it. live and learn. thats what i do....except the learn part.
  20. Feb 28, 2023 at 10:02 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The angle sideways in the drain hole is just perfect that when it hits the pan it can reflect and spray the brake rotor. That wasn't a fun day. The control of a fumoto or valvomax avoids that.
  21. Feb 28, 2023 at 10:59 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I've never had this problem using a 5 gal bucket instead of a drain pan. But I fully understand the appeal of the Fumoto.
  22. Feb 28, 2023 at 11:13 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Hah! I just installed my Fumoto valve on Sunday. My last 2 oil changes prior to that were absolutely miserable. One I didn't realize my oil drain pan was partially full, so that was an adventure in quickly finding another container while the damn thing's draining/spraying all over the inside of my wheel well. The other one's on me - I tried to change the oil outside. One gust of wind after another sent oil spraying in all directions, I have decided not to make THAT particular mistake ever again.
    I'm also going to do the Jowett filter housing replacement with the drain valve, just waiting on my order to arrive for my next change in 5k miles. My damn housing drain cap got stuck this change too, ended rigging up my longest socket extension to the oil housing tool and just letting it run down that into the catch pan, and man, that took forever. Ended up having to loosen it while holding the housing in my vice. Didn't take much, but there was no way to reach around my TRD skidplate to get any kind of grip or tool onto the housing to hold it while removing the cap.
    I was hard-pressed to spent north of $100 on more oil-change toys that are specific to this one vehicle, but I can sincerely say that I've been totally sold on mess-free methods and tools. It'll still only take 3-4 oil changes to pay for them vs paying labor at my dealership, but still. Ugh. Really, really looking forward to my oil changes being opening and closing a couple drain valves after connecting a couple tubes to my catchcan.
    Wallygator, GODZILLA and Fotnot like this.
  23. Feb 28, 2023 at 11:19 AM
    MedCityMoto
    Also side note - the last time I used a Fumoto valve it was on a motorcycle, the bike bottomed out on a short ramp at slightly steep angle onto a trailer, and that damn brass absolutely gave way and leaked my oil all over that trailer (thankfully fully-aluminum floor). I had to drop $200 at a stupid Triumph dealership 1100 miles away from home to get a new drain valve and an oil change so I could get the bike back on the road. These valves are not particularly strong. I was only comfortable going back to using one once I saw just how protected it is by the TRD skidplate.
  24. Feb 28, 2023 at 11:23 AM
    The Jowett housing is worth it's weight in gold!
  25. Feb 28, 2023 at 2:09 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yep. 6061 aluminum baby!!!
  26. Feb 28, 2023 at 2:26 PM
    Everything I can find indicates that it should swap over to my Tacoma, too. Very happy about that. :)
  27. Feb 28, 2023 at 6:15 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    2012 Tundra Overland Build
    Cleaning oil off drive isn't fun, been there done that, but fumoto is now standard on all my cars
  28. Mar 1, 2023 at 1:14 PM
    Philogynist
    Philogynist New Member
    NY
    Definitely. Although I bought one and never installed it. Got the valve and the socket, the whole nine yards.
    Brand new sitting on a shelf in my shop. I'd probably sell it but.......
    I got burned on PayPal during the onset of Covid so I dumped my account. No more online sales for me and I did a ton of them.
    My spouse says Facebook Marketplace is a good way to sell items locally. I'm not a Facer so she'll have to do it.
    Anyway back to our original broadcast and yes, score one when you can.
  29. Mar 1, 2023 at 1:57 PM
    That's a bummer, because I'd buy it. :(
  30. Mar 1, 2023 at 2:01 PM
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
    Ironically this thread made me immediately order a Fumoto valve for my Tundra.
    Fotnot, MedCityMoto, WVI and 3 others like this.
