Truxedo Elevate Rack System
Discussion in '3rd Gen Tundras (2022+)' started by Alienmanpdx, Jul 4, 2023.
  1. Jul 4, 2023 at 1:42 PM
    Alienmanpdx
    Alienmanpdx [OP] New Member
    Bill
    Has anyone installed the Truxedo Elevate Rack System on a 2023 Tundra? There seems to be a strip of metal hanging down from the rail that is keeping the clamp from going up high enough to get a good grip. Cutting a slot in the metal strip is a solution but not something Truxedo talks about in the installation. This rack is supposed to work with the Bak Revolver X2 and they for sure don't work together. Besides the Bak byisn't fitting either, it has a clamp problem because of this metal hanging down.
  2. Jul 4, 2023 at 5:23 PM
    Hike5
    Hike5 New Member
    2022 Tundra Limited Crewmax
    Did you remove the bed rail? They have a set of clamps that utilizes the bed rail
  3. Jul 4, 2023 at 10:27 PM
    Alienmanpdx
    Bill
    That's interesting. Is that a 2023? My bed I not spray on. Those are not the clamp I got and Bak saw my photos and didn't say mine were the wrong ones. The sheet metal on yours looks different where you clamp is. Mine has larger gap behind it. I can't believe Toyota makes different beds for different Tundra models. Thank you.
  4. Jul 5, 2023 at 5:51 AM
    Hike5
    Hike5 New Member
    I have a 22 Limited but the beds are the same. I assume yours came with the rails on the inside? It kind of looks like they were taken off. If you contact truxedo I’m sure they can get you the right clamps.
  5. Jul 5, 2023 at 6:21 AM
    Alienmanpdx
    Bill
    What cover do you have on your truck?
  6. Jul 5, 2023 at 10:04 AM
    Hike5
    Hike5 New Member
    Truxedo Sentry CT. So far loving it!
    Spartanfam and Maharisc like this.
  7. Jul 16, 2024 at 3:51 PM
    Lastcast
    Lastcast New Member
    Alberta
    2024 Limited
    Bumping this old thread - has anyone installed the Truxedo Elevate with an OEM Toyota trifold tonneau cover?
    I'm hoping to do that this week.
  8. Jul 16, 2024 at 5:20 PM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    TBD
    I have this rack on my '22 with factory rails inside the bed and an Undercover Flex, which is very similar to.the factory tri-fold. Works great.
    MAC25Tundra likes this.
  9. Jul 16, 2024 at 6:26 PM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    I have the Tundra deck rails and bolted the Elevate TS rails to it with the included clamps which slid into the deck rails. I specified that I have the Toyota deck rails when I purchased it. In fact, I purchased 2 more clamps per side to hold it more securely. I have the Truxedo X15 low profile tonneau cover as well.
  10. Jul 17, 2024 at 7:35 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Plan on getting this for my 23 with bakflip mx4
  11. Jul 17, 2024 at 7:51 AM
    Lastcast
    Lastcast New Member
    Alberta
    2024 Limited
    Thanks for the pics. I'll post pics with OEM tonneau cover when I get it on.
  12. Feb 1, 2025 at 7:32 AM
    slcsez2000
    slcsez2000 New Member
    Those clamps still working ok?
    I am doing something just like that and seems flimsy since they don’t clamp all the way to the top (wish were longer) but maybe it doesn’t matter since the weight of anything on the rack would be pushing down.
  13. Feb 2, 2025 at 7:43 AM
    Spartanfam
    West Michigan
    Yes, the rails still work fine. I’ve loaded two 35lb kayaks on them and driven at highway speeds… the teeth on the rail clamps add quite a bit more surface area and vertical constraint than you think. The load really moves to the shear strength of the bolts that Toyota holds the bed rails in with.
