Tundra Battery Specs
Discussion in '2nd Gen Tundras (2007-2013)' started by seemurph, Jun 16, 2021.
  1. Jun 16, 2021 at 10:40 AM
    seemurph
    seemurph [OP] New Member
    2008 Toyota Tundra 5.7l
    Hey all!
    Quick question - I needed up replace my battery in my 08 Tundra 5.7l. I went online at Advanced Auto, put in my vehicle specs, found the battery it said "fit my vehicle". I purchased this battery which was a Duralast Gold 24F 750 CCA. I didn't put the battery in right away because I was in the middle of a move and didn't remember where my tools were at the time. I recently changed that battery and the next morning the battery appeared to be dead. Did I get too small of a battery? I've read that I may need to bump up to 27F and 800-850 CCA. What's your thoughts? TIA
  2. Jun 16, 2021 at 10:49 AM
    The 24F is fine. I would take it to Advanced and have them test it.
    Black Wolf and NewImprovedRon like this.
  3. Jun 16, 2021 at 10:50 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Sounds like maybe a bad battery, I put a new Interstate same specs last fall and works fine. A dead battery isn't going to start anything;)
  4. Jun 16, 2021 at 11:00 AM
    seemurph
    Ok! That's what I was thinking (dead battery) but I've only had this truck for about 10 months and just wasn't sure. Really appreciate it guys, I'll take it back to advanced auto and get the test done and either way they should replace it for me. Thanks!
  5. Jun 16, 2021 at 12:51 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    My '07 takes a 27F.......Toyota Truestart 60 month battery, (2year free replacement) sells at the dealership for
    $ 120.00 bucks.
    RitcheyRch and seemurph[OP] like this.
  6. Jun 17, 2021 at 7:39 AM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    27F is standard on the cold weather package... 24F is on everything else.
    You're fine with either, especially since in my searching 27F is extremely hard to find and when you do find one it's only available in the lower grade batteries so it ends up having the same CCA as a nicer 24Fs.
    my truck originally came with a 27F, but the previous owner put a 24F in it... it's fine.
    Danny3737 likes this.
  7. Jun 18, 2021 at 5:55 AM
    Billy Bob Tundra
    Billy Bob Tundra New Member
    NewImprovedRon likes this.
  8. Jun 20, 2021 at 11:20 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    either the battery you bought was bad , or you have a parasitic draw issue meaning something is drawing power while the trucks off. if the battery is dying while the truck is running your alternator is going bad. (or in some rare cases you have to many accessories needed more power than alt out put)
