Tundra Bed mounting solution
Discussion in '2.5 Gen Tundras (2014-2021)' started by Apw3007, Nov 22, 2023.
  1. Nov 22, 2023 at 6:57 AM
    Apw3007
    Apw3007 [OP] New Member
    2021 Tundra crewmax TRD OFF ROAD
    Hey all! I’ve been shopping around for some GFC platform campers. Found one from a 21 f150 short bed that I think I can make work. Has anyone had experienced mourning ford things to a Toyota bed? I know tundras have the bed rails and ford typically bolt to the under side of the bed lip.
  2. Nov 22, 2023 at 7:58 AM
    Welcome from NY.
  3. Nov 22, 2023 at 8:16 AM
    Fergie
    Fergie New Member
    I mounted an AT Habitat from a Dodge to my 14 Tundra; it needed a filler plate at the front, but that was easy enough to make. The width was perfect and still bolted down to my bedrail tops without issue.
  4. Nov 22, 2023 at 2:11 PM
    Apw3007
    can I ask how you did it? Before I make the drive to check the GFC out. Was there a adapter you needed for the T slots?
  5. Nov 22, 2023 at 8:17 PM
    Fergie
    Fergie New Member
