Tundra Icon RXT Pack +/- CB +2 Shackles?
Discussion in '2.5 Gen Tundras (2014-2021)' started by InfernoBoyz, Apr 5, 2023.
  1. Apr 5, 2023 at 2:05 PM
    InfernoBoyz
    InfernoBoyz [OP] YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    With my Rack and RTT set up, I am running minimum 250lbs in the bed plus gear on trips off-road/on road camping etc.
    Lately I am noticing my rear end is sagging more than before (105k on the clock), so I am looking at ordering the RXT Pack from Icon and running option 2.
    I do have a set of brand new CB Shackles +2 that I am considering installing with them.
    Would this stack the lifts for something crazy like a 4” rear lift? I am just hoping to ride level with weight in the rear, and okay with a small rake unloaded. I never take my rack off so there is always some weight back there. Currently running TRD Pro shocks, everything else stock.
    Wondering if I should just go with the RXT pack, or if there is a benefit of running with both?
    Thank you!
    Pic for attention
  2. Apr 5, 2023 at 2:44 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I'd go RXT only. My '07 DC has bed bars, an FSR tent and awning. Plus a toolbox/house battery system. RXT in config #2 gave me ~2" lift with all that weight. If it ever sags down I can go for more with #3 setup.
    Heads up the RXT springs, they have a lot of droop, so check that your shocks aren't the limiting factor. Mine went ~1.5" past where my Fox 2.0's stopped at.
  3. Apr 5, 2023 at 2:53 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    KevinK and TRDFerguson like this.
  4. Apr 5, 2023 at 2:54 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    keep an eye on your brake lines, ABS, parking brake and diff breather lines as well.
  5. Apr 5, 2023 at 2:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I would not add extended shackles if you have the ability to move to option 3 on the RXT. These leafs are pretty soft as it is, so I’d be worried about flattening them really quickly with the added shackle geometry.
    KevinK, B.Ross and InfernoBoyz[OP] like this.
  6. Apr 5, 2023 at 2:58 PM
    VWTim
    Corvallis, OR
    Good call. I was able to get brake line spacing with the OME bracket kit. Diff breather I rerouted at the same time and ran to the tail light area. Parking brake either spaced with the OME kit or I was able to bend it for more clearance.
  7. Apr 5, 2023 at 3:30 PM
    InfernoBoyz
    Reno, NV
    Thanks for the advice here, sounds like just the RXT pack is the way. Might have my CB shackles up for sale soon then.
    Will look into the lines as well, no posts I saw on here mentioned anything about that so really appreciate the heads up.
  8. Apr 10, 2023 at 3:51 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I’m only here to confirm what these yahoos already convinced you to do - skip the shackles.
  9. Apr 10, 2023 at 3:57 PM
    pandapro
    pandapro New Member
    Let me know if you sell the shackles. I have a friend that needs some.
    BTW, the RXTs are great! Save the extra leaf and to go option 3 later on if they flatten.
  10. Apr 10, 2023 at 3:59 PM
    pandapro
    pandapro New Member
    Could you elaborate on combining the RXTs with extended shackles. I recently added some +2s to go along with my RXTs on option 3. I found that I was squatting when fully loaded (GFC, rear bumper, 110# spare, gear). Wondering now if I made a mistake.
  11. Apr 11, 2023 at 1:48 PM
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I’m right there with you. My RXTs are already at option 3 and my truck is just a little more squatty than I’d like, and I need another 1”-1.5” to get that sweet spot. My plan is to add a slightly longer shackle as well. I’m also using SumoStop bumps. IMG_8155.jpg
  12. Apr 12, 2023 at 8:42 AM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    I have Stage 8 Icon kit with RTX and I use option 2. I solo camp so the weight is minimal when not camping.
  13. Apr 12, 2023 at 9:05 AM
    SAGE63
    San Diego County
    Option 3, stock shakles... 7gal spare fuel, 8 gal water, jackery 880, iceco vl45 with 2 days provisions/beer and slide. sitting on 295 70r18, icon omega 2.5 bypass. C4 overland bumper with warn evo ve 12k winch on Icon 3.0 coilovers and full armor..and likely 150lbs of tools and recovery gear in the rear of the cab. Additional load in bed ezup. table, camp chair, std other camp and cooking stuff...
    aired down to 15lbs.
    not sure of what the current lift height is
    likely total weight is 7500-7600lbs
    stevep0925 and InfernoBoyz[OP] like this.
  14. Apr 12, 2023 at 10:55 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    If you actually use it offroad, longer shackles will flatten your leafs quicker... unless you also install longer bumpstops... which doesn't seem optimal. That's a universal thing, not specific to these springs.
    InfernoBoyz[OP] and KevinK like this.
  15. May 8, 2023 at 6:57 PM
    InfernoBoyz
    Reno, NV
    Sorry just checking this, still need em? I’ll sell them.
  16. May 8, 2023 at 6:59 PM
    InfernoBoyz
    Reno, NV
    Thanks boss. Got my RXT pack on the way, bummer won’t be on by my 5 day trip in a week but looking forward to installing them
