Tundra Not Running Right After Recall
Discussion in '3rd Gen Tundras (2022+)' started by Corbeano1, Mar 28, 2024.
  1. Mar 28, 2024 at 11:28 AM
    Corbeano1
    Corbeano1 [OP] New Member
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    I was told there is a recall about the transmission (trucks will advance while in neutral)
    The did (10,000 miles) service and the did the recall
    Man,,,, this thing is jerking and skipping a bit when acelerating . Feels like the Trans doesn't know what to do.
    It's drivable but not very smooth. ( I hope this doesn't mess with the plugs or anything else)
    I asked the service about other complaints, and none so far on the recall.
    Im headed back in a few days to reverse what they did,,, NOT GOOD>
    Has anyone else been thru this?
  2. Mar 28, 2024 at 11:30 AM
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    Its the transmission relearning your driving habits. Its normal. Drive it for 100-150 miles and it should be returning to usual. My old tacoma did it, and my tundra did it too on the parking brake recall.
    TundraFl83 and Corbeano1[OP] like this.
  3. Mar 28, 2024 at 11:37 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    Accelerate from 0-60 at mild to moderate throttle several times to relearn transmission shift characteristics. They should have done that once they completed the transmission control module reflash. Obviously didn't.
    pwpblue, kirkb and Corbeano1[OP] like this.
  4. Mar 28, 2024 at 11:40 AM
    raylo
    raylo not so new member
    Frederick, MD
    I noticed the same thing. I hope it gets back to being totally smooth again.
    pwpblue and Corbeano1[OP] like this.
  5. Mar 28, 2024 at 11:43 AM
    Tb2
    Tb2 New Member
    James
    I just had my trans recall done and didn’t notice any difference
    PNW Tundra Mike likes this.
  6. Mar 28, 2024 at 11:54 AM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    I have been doing this, thinking it would relearn if that is the issue... Its getting worse?
    Platinum_Tundra likes this.
  7. Mar 28, 2024 at 11:56 AM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    Does it really take 150 miles to relearn if that's the case? That will take a long time driving around here in town lol..
    It's pretty jerking at a slow, steady increase of speed. Thank you for info btw
  8. Mar 28, 2024 at 12:38 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Well if slow and steady isn’t making it learn, then the correct answer is clearly to drive it like you stole it. One of two things happens: the transmission control unit learns, or you blow up the transmission. If you blow up the transmission, you can get a new one. Toyota can’t fix or replace any major component these days in a reasonable amount of time so you can probably lemon law the truck while you wait!
  9. Mar 28, 2024 at 12:40 PM
    raylo
    Frederick, MD
    I should have mentioned in my earlier post that mine is much better. The first drive it was really noticeable. I just went out for groceries after having the truck sit for a couple of days, and it feels pretty much like normal and smooth. I am one week out from the service, maybe 100 miles or so.
  10. Mar 28, 2024 at 1:02 PM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    Dang,,,, Lets hope the Transmission will figure itself out.
  11. Mar 28, 2024 at 1:07 PM
    nafterclifen
    nafterclifen New Member
    Pocono's, PA
    Whatever they did to satisfy the recall, I guarantee you that they will NOT undo it. I would have the same thoughts if I were in your shoes but that's wishful thinking.
    Duckinatruck and Corbeano1[OP] like this.
  12. Mar 28, 2024 at 1:19 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Damn, this thread is making me second guess my scheduled appointment for the trans recall. Mine is so silky smooth, and it doesn't roll in neutral. I'd hate to mess that up.
    Regarding the "learning" theory, my truck had 12 miles on it when I picked it up new. Why didn't I notice this transmission learning curve then?
  13. Mar 28, 2024 at 1:24 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Had my Transmission recall (ecu flash) and don't have any symptoms you describe. Runs and shifts fine. Wonder if your ecu flash had an electrical system voltage hiccup during the flash?
  14. Mar 28, 2024 at 2:10 PM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    Had my recall done last week, I did notice some funky shifts when leaving the dealership, shifting at a higher than normal RPM.....But as others have said, its part of the relearning process.....Mine is doing great now, I also never had the neutral lurch.
    pwpblue likes this.
  15. Mar 28, 2024 at 2:45 PM
    RallySauce
    Middle TN
    Break in period, keeping it under 4000 rpms, not realizing it cause youre happy you are in a brand new truck, could also have an initial setup from the factory and doesnt need to relearn from scratch per se. Could be a number of things. I didnt experience it initially either but i bought my truck with 350 miles on it. Dealer trade.
  16. Mar 28, 2024 at 2:51 PM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    My wife drove it today and told me it was hiccuping when accelerating.
    Im a little surprised the service guide didn't mention the truck relearning when I mentioned the transmission issues?
    I will find out Sat... Maybe they will let me talk to the tech and see what he or she says.
    pwpblue likes this.
  17. Mar 28, 2024 at 2:54 PM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    I would tend to agree with this. After my recall, I noticed there was extra miles on my odometer than when I brought it in(about 10). Suspect the techs took it out to do just that... relearn.
    Corbeano1[OP] likes this.
  18. Mar 28, 2024 at 3:19 PM
    Matt2015Tundra
    2023 1794 CrewMax
    I've been doing some research on this transmission "learning" thing.
    I'm reading that it's a myth that the transmission "learns to adapt to your driving style". The transmission adapts to changes in the hydraulic fluid (the ATF) due to age, contaminants, etc. and it adjusts how the hydraulic pressure is applied to the clutches that shift the gears. Apparently there are several different torque tables/maps the TCM can select from. It should not take 100-150 miles for the proper tables to be selected. It should happen almost instantaneously after a re-flash of the TCM.
    At least that's what my research shows. Please correct me, If I'm wrong.
  19. Mar 28, 2024 at 3:23 PM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    Wow, some more info. I appreciate that. Interesting. I wish I knew a Toyota tech here online to get some inside info.
    pwpblue likes this.
  20. Mar 28, 2024 at 3:35 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    It's my understanding that upon a TCM or ECU flash, it's the AI in the computer that is basically reset back to new and instantly starts logging the new data. The transmission is just waiting for data from the TCM (to be told what to do). When you only do in town stop and go driving it really doesn't have a chance to see the full range of available information (all gears and wide range rpms). Usually the tech will get on the highway and rip it up to 75 a couple times and have the truck go through every gear and essentially setting the new performance parameters for the AI and you're good to go. Your truck will continue to try and optimize as you drive but doesn't start off like that.
    If you put it into S you bypass the AI. See how it drives in S but don't drive it like there's an egg on gas. Let it work! I think you'll be fine
  21. Mar 28, 2024 at 3:36 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    @ryanwgregg will chim in.
    Just had mine done today and same thing. Fun y how it's in first gear as soon as you stop now then go no throttle lag now just a gear bang here and there lol. Time will tell!
    Feels like it's in tow haul mode.
    Corbeano1[QUOTED][OP] likes this.
  22. Mar 28, 2024 at 3:39 PM
    TundraBrew
    TundraBrew New Member
    I can understand the relearning thing. But I would hope that the dealership would've performed a test drive, and maybe warn the OP of this condition.
  23. Mar 28, 2024 at 3:40 PM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    The dealer is about 20 minutes from the Interstate (only place to get the truck through all gears) Bad traffic here in Sarasota (Blue Hair Snow Bird Season,,,,,no offense to those who do this)
    anyways,,, they don't have time to get to interstate,,, there got to be another way if indeed the trucks has to do this to "relearn its thanga"
  24. Mar 28, 2024 at 4:37 PM
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    Kind of off topic, but how do you have a "2023 1794 TRD Pro?"
    You either have a 1794 -or- a TRD Pro. Maybe you have a 1794 w/ the TRD Off Road package? OR do you have two Tundras?
    Enquiring minds want to know!
    ryanwgregg likes this.
  25. Mar 28, 2024 at 4:52 PM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
  26. Mar 28, 2024 at 5:01 PM
    pwpblue
    Greensburg,PA
    20240328_200318.jpg VideoCapture_20240328-200231.jpg Update: drove the tundra around alittle bit with normal throttle. Shifting smooth as daisy's after a few miles again. My lab sure loves that rear window being down that's for sure or I get the sad eyes look!
  27. Mar 28, 2024 at 6:20 PM
    303Gen3
    Golden Colorado
    What!?
  28. Mar 29, 2024 at 5:47 AM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    Awesome!!!!!! I will take the truck out this morn, city and highway driving and see what happens.
    pwpblue[QUOTED] likes this.
  29. Mar 29, 2024 at 9:18 AM
    Corbeano1
    Corbin
    Lakewood Ranch, FL
    2023 1794/TRD
    Ok,,, good news.
    I took a spin to this morn. Everything is way smoother. It's like and day and night.
    Good for the peeps who called it.
    I appreciate everyone's help. Have a great weekend.
  30. Mar 29, 2024 at 12:02 PM
    RallySauce
    Middle TN
    Hey i got a diff shipped in 2 days, does that count as a major component? Lol
    lol typo on the rpms/miles, fixed. :D
    303Gen3[QUOTED] likes this.
