Tundra/Sequoia 4.7 swap
Discussion in '1st Gen Tundras (2000-2006)' started by ChipB, Feb 7, 2024.
  1. Feb 7, 2024 at 5:45 PM
    ChipB
    ChipB [OP] New Member
    Chip
    2003 Tundra TRD
    I have a 2003 tundra trd with a bad engine. I found a sequoia engine that states it is compatible. I messaged them. Said from 2000-2004 would interchange. Stated I would have to swap some parts such as exhaust manifolds and oil pan. Is there anything else? Don’t want any surprises. Thank you so much.
  2. Feb 8, 2024 at 8:55 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    You didn’t say what year sequoia engine you’re looking at.
    2000-2004 engines all interchange. I thought all the oil pans and exhaust manifolds for both the 1st gen tundras and sequoias are the exact same? The throttle bodies might be different between the years. The early tundras had an actual speedo cable that opened the TB. The later models were drive by wire.
    Perhaps the reason why the seller says that the sequoia engine needs the exhaust manifolds swapped is because they’re cracked? And maybe its oil pan is dented?
  3. Feb 8, 2024 at 10:12 AM
    ChipB
    Chip
    2003 Tundra TRD
    It is highly possible you are correct. I don’t know Toyota engines that well. The donor engine is from a 2000-2004 Sequoia. I still have engine in mine. So I should have parts to swap if need be. Just trying to get a heads up before I tackle this.
  4. Feb 8, 2024 at 10:13 AM
    ChipB
    Chip
    2003 Tundra TRD
  5. Feb 8, 2024 at 10:57 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    What's "bad" on your original engine?
  6. Feb 8, 2024 at 4:21 PM
    ChipB
    Chip
    2003 Tundra TRD
    Engine locked up. Got it that way. It was my dad’s. Poorly maintained engine wise.
  7. Feb 8, 2024 at 5:37 PM
    whodatschrome
    lots of dents
    My only pro tip is to use LOTS of penetrating oil on the manifold and exhaust pipe collector threads. After lubing them up, i'd then smear a coat of anti-seize all over the rest of the threads. The OEM exhaust locking nuts can easily gall to the studs! The nuts are either going to come off really easy, or they ain't coming off at all. I also wouldn't use any impact tool either. The speed at which the nuts spin will cause excessive heat and will probably also cause the nuts to gall to the studs. Take PLENTY of time to remove them by hand!
    Sunnier likes this.
  8. Feb 8, 2024 at 5:39 PM
    Locked up, but why? Timing belt snapped?
    I've managed to free absurdly frozen engines frozen for a decade or more - by simply putting a blast of Marvel Mystery Oil into each cylinder, waiting 2-3 days, then turning it over.
    Sunnier likes this.
  9. Feb 8, 2024 at 5:51 PM
    ChipB
    Chip
    2003 Tundra TRD
    Broke a rod. Wouldn’t budge with 3 ft breaker bar.
    whodatschrome and shifty` like this.
  10. Feb 9, 2024 at 5:03 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    did you verify the broken rod?
    don’t see that problem very often with these engines (one other time I can remember)
  11. Feb 9, 2024 at 8:02 AM
    ChipB
    Chip
    2003 Tundra TRD
    I didn’t. You could hear it knocking 6 months before it locked up is what he told me. With way it had 232,000 on the odometer. Found a 72k engine to put in it.
    whodatschrome likes this.
  12. Feb 9, 2024 at 8:50 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    This screams T Belt. Maybe not, maybe I should have read the thread.
  13. Feb 9, 2024 at 9:44 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  14. Feb 10, 2024 at 6:05 AM
    232k miles is barely breaking in on these engines. 125-175k is ideal. Be careful with that low mile engine. Inspect thoroughly for sludge. (It probably sounds like I'm kidding, but this is not a joke)
  15. Feb 10, 2024 at 1:50 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Before you install the new engine would ideal time to replace any rubber items like hoses, seals, belts etc.
  16. Mar 23, 2024 at 1:10 PM
    ChipB
    Chip
    2003 Tundra TRD
    Can someone tell me what this oil applies to? I bought a 2003 tundra 4.7 but pans are different.
  17. Mar 23, 2024 at 1:20 PM
    ChipB
    Chip
    2003 Tundra TRD
    I think I figured it his out. Con someone confirm that this is a LX470 pan?
  18. Mar 23, 2024 at 1:38 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Looks like it to me.
  19. Mar 23, 2024 at 2:05 PM
    ChipB
    Chip
    2003 Tundra TRD
    Does anyone know if the sumps are the same for Lx470 and the Tundra 2003?
