Tundra Transfer Case or ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by birk22, Jan 18, 2023.
  1. Jan 18, 2023 at 9:41 AM
    birk22
    birk22 [OP] New Member
    Eastern AZ
    2015 Tundra SR5
    Disclaimer - I'm new to this and not a mechanic. My 2015 Tundra recently would not come out of 4Low until I turned key off and finally it went into 4High. Then it took awhile to get it into 2High. The light kept flashing for the 4High indicator. I took it to Toyota and they told me I need a new transfer case ($4,400). There are no leaks, no humming noises & they replaced my transfer case oil last summer (never mentioned finding metal in it). I'm not sure what to do now other than I know I won't purchase a new transfer case. I'm not a mechanic but it seems like transfer cases don't go out very often (in 2 yrs I've only used 4 wheel drive three times - don't know history of the truck). They told me this diagnosis was from a Code. Thanks.
  2. Jan 18, 2023 at 10:22 AM
    koifish
    koifish New Member
    2015 Inferno Double Cab TRD Pro
    Get a second opinion. And not from Toyota, but at an independent shop that works on Toyotas. I had rodent damage to a wire harness that was causing my "low fuel" light to stay on. Dealer wanted to replace the entire frame harness for $5400. Went to an independent shop that I use for my other Toyotas, $350 to repair the wire damage. Post up your location, I'm sure the folks on here can find you a trusted mechanic.
    WILLINH likes this.
  3. Jan 18, 2023 at 10:24 AM
    birk22
    Eastern AZ
    2015 Tundra SR5
    Good idea. I live in a small town so don't have any places that may specialize on Toyotas; but have a few shops I can check. Thank you.
  4. Jan 18, 2023 at 10:32 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I’d replace the oil again with the correct spec 75W. Engage and disengage 4Lo several times. Even if you have to power cycle the truck (turn it on and off).
    I’m wondering if they put the wrong gear oil in your TC last year. Most of the time they use 75W-90, and that is 3-4X as thick as the correct 75W at operating temp.
    Sumo91 and AZBoatHauler like this.
  5. Jan 18, 2023 at 10:50 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Your electrical motor in the transfer case that actuates it from 2WD to 4WD or front diff electrical motor hub lock mechanism is probably getting stuck. There are 2 electrical motors in the transfer case (one for the 4Hi and 4Lo) and another electrical motor in the front diff to lock the hub. You suppose to activate your 4WD Hi and Lo once a month to make sure the mechanism moves and gets lubricated.
  6. Jan 18, 2023 at 11:24 AM
    birk22
    Eastern AZ
    2015 Tundra SR5
    I checked my records (invoice) and they don't state what oil they use for the transfer case. Thanks for the ideas.
    Terndrerrr likes this.
  7. Jan 18, 2023 at 11:27 AM
    matictundra
    Franco
    AZ
    I used Revnol 75W oil when I did my transfer case.
  8. Jan 18, 2023 at 11:37 AM
    AZBoatHauler
    So.Arizona
    How much was the service? That might help…
    I’d bet they used 75-90 and that is the source of your problem.
  9. Jan 18, 2023 at 12:28 PM
    birk22
    Eastern AZ
    2015 Tundra SR5
    the complete transmission/transfer case/hub service was $350.
  10. Jan 18, 2023 at 12:39 PM
    AZBoatHauler
    So.Arizona
    Since the correct fluid for the t-case costs $160, I’m guessing they didn’t use the good stuff.
  11. Jan 18, 2023 at 12:42 PM
    birk22
    Eastern AZ
    2015 Tundra SR5
    Found a Toyota specialist shop in Phoenix area - will get a 2nd opinion. Would a Toyota Dealer really use the wrong stuff? If that could be it, I wonder why it eventually shifts - after turning the key off/on?
  12. Jan 18, 2023 at 12:47 PM
    timsp8
    NY
    Are you sure it was in neutral when shifting from 4 lo? The 4wd system is supposed to be exercised for about 10 miles a month. Most don’t do it though. I really only use mine in winter. Maybe it just needs to be used some and then everything will loosen up.
  13. Jan 18, 2023 at 12:49 PM
    Terndrerrr
    Music City
    6UR-FE
    Most dealerships use 75w90 even if it’s wrong. Also, if you’re not exercising that actuator at least monthly, it’s not going to work smoothly for you.
    I’ve brought actuators back from the dead just with new (correct) gear oil and going into and out of 4Lo several times with the shift lever in neutral.
  14. Jan 18, 2023 at 12:55 PM
    birk22
    Eastern AZ
    2015 Tundra SR5
    It was in neutral.
  15. Jan 18, 2023 at 1:12 PM
    CTundraForMe
    CTundraForMe New Member
    I have a 2015 that I bought used.
    It's doubtful the only prior owner EVER used 4wd in 98,000 miles.
    I tested 4H and 4L before I bought it. It worked.
    After I brought it home, it got stuck in 4L.
    Fortunately I have a Toyota master mechanic family relative...
    We dropped the tcase and he took it to some mechanic friends and they opened it up.
    Found a "non essential piece" that had come off and got in the way of the gear mechanism.
    They cleaned it out, put it back together, and I put the genuine-expensive-weird-toyota-tcase-fluid-in-a-tin-can in it.
    Haven't had a problem since.
    Except I am hesitant to put it in 4L ever again. :/
    EDIT: Link to tin can: https://www.amazon.com/TOYOTA-Genuine-Transfer-Litre-08885-81080/dp/B086R57CRP
    AZBoatHauler likes this.
  16. Jan 18, 2023 at 1:22 PM
    Terndrerrr
    Music City
    6UR-FE
    This is not helping to prevent your problem from happening again.
    BlueRibbon4x4 and matictundra like this.
  17. Jan 18, 2023 at 1:29 PM
    matictundra
    Franco
    AZ
    This is cheaper and works...
    https://www.ravenolamerica.com/passenger-car-products/75w-gear-oil-ravenol-mtf-3/
    You not shifting 4L once a month makes the problem worst.
  18. Jan 18, 2023 at 1:56 PM
    CTundraForMe
    I understand the 4L situation. The challenge is we have one vehicle, and live in the middle of nowhere. Getting stuck in 4L again would be a very serious problem.
    Are you sure shifting into 4L monthly is required? The manual states:
    It doesn't say anything about 4H or 4L. However it also doesn't say anything about the transfer case, and both will use the "front drive components".
  19. Jan 18, 2023 at 2:05 PM
    Terndrerrr
    Music City
    6UR-FE
    I do put it into 4Hi and 4Lo at least once a month. The manual could have been worded better. The gears in the front diff turn in 2H, so you don't need to activate 4wd in order to lube them. It appears to me that the manual here is talking only about the transfer case, which seems to be what the manual means by "front drive components". The actuators need to be used, 4wd needs to be engaged, and the gear oil in the transfer case needs to be whipped up to lube everything up properly at least once a month.
    The 4Lo in my LX wouldn't engage properly and would throw dash lights on every time until I swapped fluid and engaged it every day (after warming the vehicle up) for the better part of a week. Now it works perfectly and smoothly.
  20. Jan 18, 2023 at 2:08 PM
    matictundra
    Franco
    AZ
    Going to both 4Hi and Lo helps with electric motor actuation preventing the electric motors getting stuck beside the benefit of system lubrication. Watch the link video for actual operation of the system.
    https://www.youtube.com/watch?v=47m7QAPrpsI
    Terndrerrr and AZBoatHauler like this.
  21. Jan 18, 2023 at 4:11 PM
    Terndrerrr
    Music City
    6UR-FE
    Looks like 4wd activates the big ring gear and the entire passenger side CV axle. Very cool video. Loved seeing inside the transfer case.
    Chucksmith07 and CaptRussia253 like this.
  22. Jan 18, 2023 at 4:53 PM
    Rocko9999
    Rocko9999 New Member
    Why is it so expensive?
  23. Jan 18, 2023 at 5:45 PM
    birk22
    Eastern AZ
    2015 Tundra SR5
    $3,600 for a new transfer case!
    CaptRussia253 likes this.
  24. Jan 18, 2023 at 6:12 PM
    timsp8
    NY
  25. Jan 18, 2023 at 6:56 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I’ve called 5 local Toyota and Lexus dealerships and all use bulk 75w90 valvoline. Some haven’t even heard of Toyotas 75w fluid.
    I only used 75w90 in my transfer case for the 4runner, GX460 and now tundra without any issues. I do put it in 4H/4L once a month so maybe that’s why I haven’t had any issues.
  26. Jan 18, 2023 at 7:07 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Where in the Phoenix area are you? I have a very qualified Toyota only independent shop on the east side that can likely get this resolved for you. PM me if you would like more info.
  27. Jan 18, 2023 at 7:07 PM
    AZBoatHauler
    So.Arizona
    The Toyota 75W has a very unique additive pack. Lots of phosphorus.
  28. Jan 18, 2023 at 7:49 PM
    CTundraForMe
    I don't think "dealers" are a fair representation of Toyota. Instead they are a fair representation of the current state of society, which, IMHO, is in a pretty bad state.
    That's why they charge you $90 for a cabin air filter installation.
    Or recommend replacing your transfer case when it can be fixed for far less.
    Or severely over tighten your lug nuts leading to warped rotors.
    Or recommend "turning" your rotors.
    Or countless other examples you'll find here in this forum which is has led "dealers" to be renamed to "stealers".
    Anyhow, the reason I'm saying this is just because the dealer knows nothing about "genuine Toyota transfer case fluid" doesn't mean it's not the best thing to use.
    From my perspective, I find it odd how people are willing to spend $50,000 or more on a truck, and then go cheap on fluids. :confused:
  29. Feb 2, 2023 at 11:40 AM
    737fixer
    737fixer New Member
    Please don't get wrapped around the wrong oil. 75w vs 75-90 vs every other gear oil imaginable will not create the issue you are having. Yes, for long term, use the proper spec oil but you're having an issue with solenoid(actuator) and the actuation of modes. Please just find a nice piece of straight QUIET road and shift between 4HI back to 2WD many, many times. Then start going from 4HI to 4LO to 4HI to 2WD again, many times. The only weak point in our transfer case is the actuation solenoid and this is only weak from lack of use as others have pointed out. No guarantee but, as shown and in many other forums here, this is almost always the problem. Then, of course, try to switch modes at least once a month. When it starts working normal you can change the oil if you feel the need. The dealership will absolutely use the cheapest bulk 75-90 it can find but this will absolutely not harm your transfer case. I, like everyone here chooses a higher quality oil like a Ravenol 75W but again it's a minor difference. Please, always understand, the dealer will always use the cheapest fluids they can find in a 55gal drum. Your dealership engine oil change will absolutely be 0w-20 but it will be some bulk, almost no additive, garbage.
    AND NOW THAT I SAID THAT ALSO CHECK THIS OUT. Sorry, computer illiterate, just type into search bar. I live in Phoenix so water, ice, and slush don't effect us.
    2007-2020 Transfer Case Actuator
  30. Feb 2, 2023 at 12:31 PM
    jhinderliter
    jhinderliter New Member
    its not the oil its the actuator ...
    ran into the same issue with my taco , the dealer quoted 14 hours to replace the actuator..
    I went to the next higher assembly and found a 100k mile transfer case in the junk yard for $250...
    pretty easy swap...
