Tundra TRD Interior
Discussion in 'General Tundra Discussion' started by TrunkUp, Mar 21, 2020.
  1. Mar 21, 2020 at 11:06 AM
    TrunkUp
    TrunkUp [OP] New Member
    2019 Toyota Tundra TRD 4x4 Sport
    AMP Power Steps/ TRD Dual Exhaust
    Hi guys,
    I'm new to the forums and looking for the part numbers for the door panel and ac inserts, with the red stitching. I have a 2019 Tundra TRD 4x4 Sport. I have seen TRD with them online, so I know they exist, but the dealership isn't offering much help. I appreciate any help and I included pics, thanks.
  2. Mar 21, 2020 at 12:40 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Those come in the Pros. Most dealerships won’t sell you Pro parts unless you have a Pro. @Roman May be able to help with part numbers though.
    TrunkUp[OP], Roman and Inquiringone like this.
  3. Mar 21, 2020 at 1:23 PM
    Here's the part # for the dash pad.
    TrunkUp[OP] and Inquiringone like this.
  4. Mar 21, 2020 at 1:38 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    @Roman
    He’s the man when it comes to Tundra parts, or @Jim LE 1301 first responder.:thumbsup:
    Roman and Jim LE 1301 like this.
  5. Mar 21, 2020 at 1:48 PM
    Welcome from NY, by the way.
    @Roman can help you with those parts.
  6. Mar 21, 2020 at 4:11 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    TrunkUp[OP] likes this.
  7. Mar 21, 2020 at 6:11 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Throwing out the welcome mat for your first post...Greetings from Gettysburg
  8. Mar 29, 2020 at 10:07 AM
    TrunkUp
    I appreciate the feedback and part number. I'm good with changing out the whole door panel, so if anyone has the part number for them, I'd appreciate it. Also thanks for the welcome to the group.
    toyofan87 likes this.
  9. Mar 29, 2020 at 10:12 AM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I second this. I recently had my padded door panels recovered/replaced with leather and stitching to match my interior. It may be cheaper for you to take the door panels to an upholstery shop and have them match the leather and red stitching. I had the same thing done with my center arm rest. I'll post pics later, as I don't have the truck right now.
    Toyotoholic[QUOTED] likes this.
  10. Mar 29, 2020 at 3:23 PM
    chrisbusnut
    Pasadena, CA
  11. Mar 30, 2020 at 10:53 AM
    lonelydriver
    lonelydriver New Member
    honestly they feel kinda cheap, might be better to have a local guy upholster it with higher quality material
  12. May 20, 2020 at 9:00 AM
    TrunkUp
    @chrisbusnut Thanks for that, I'm looking into having the center console done as well. When they did the door panels did the piece come out or did they run the stitch through the whole panel?
    @Jim LE 1301 thanks for the part number. Are we sure that is for a 2019 Tundra? The parts department at my area dealership has not been able to help so far and the emails I received from the Toyota were vague. I have a 2019 TRD Sport 4x4 with the red stitched seats and gear shift knob.
    I included what they said below and when I look up the part number they provided on the Toyota site, it does not specify if it is red stitching and they advised that if it's the wrong one, I have to pay a restocking fee to exchange or return it, so I just want to pick the right one first, thanks everyone.
    "Thank you for contacting us. The Parts Specialist reviewed your inquiry per VIN provided and provided the following information;
    Per the VIN provided the correct number is 55064-0C050-C0
    Part numbers 55064-0C010-C4 (BLK WITH RED,)and 74220-0C060-C0 those are based on the description but might not work due to the models and might also require a VIN as they are for the TRD Pro models and Toyota requires the customer to own a TRD model to purchase
    Best regards,
    Parts Questions Support Dept."
  13. May 20, 2020 at 10:35 AM
    chrisbusnut
    Pasadena, CA
    @TrunkUp , they removed the old vinyl covered panels on the door panels and replaced them with new leather covered panels, with the stitching running along the top. Those stock panels aren't really removable, as they are heat welded to the door panels (not sure if that's the right terminology), but they can be removed. The new panels are basically glued back in place. I'm really happy with the results.
  14. May 20, 2020 at 10:40 AM
    Elduder
    Elduder New Member
    67610-0C311-C5
    67620-0C291-C5
    Should be the right and left sides, youre looking at about $1100 for both. The upholstered part of the door is attached with plastic rivets and the leather section on the door is not available as a separate part.
    *edit, thats for the front only, so double that for all 4 doors.
  15. May 20, 2020 at 12:03 PM
    It will fit.
    Order it from @Roman it will be cheaper and there is a shipping discount.
    Roman likes this.
