Tundra valve Body Casting (1 vs 2 sensors)
Discussion in '2nd Gen Tundras (2007-2013)' started by cmycook, May 18, 2024.
  1. May 18, 2024 at 4:25 PM
    cmycook
    cmycook [OP] New Member
    I just installed a new valve body in my 2007 Toyota Tundra (5.7L 2WD). Near completion and realized a difference in the casting. The new casting has only one hole drilled out for a temperature sensor; my old casting had two. I have two sensors. As far as I can tell, everything else seems identical. I found another site that lists this casting and specifies 1 sensor (didn't see this before). Does anybody know if this is the only difference in these castings? Can I simply drill the hole to accommodate the second sensor?
    In my old casting, the top hole circled in red is drilled out and matches the second hole circled in red.
