Turbo wastegate issue
Discussion in '3rd Gen Tundras (2022+)' started by JoeCle, Aug 18, 2022.
  1. Aug 18, 2022 at 3:36 AM
    JoeCle
    JoeCle [OP] New Member
    I'm sure this issue has been beat to death already, but I could not find an answer to this....I had the reduced power and check engine light coming on and the truck would not go over 15 mph. It was not a normal 3.5 liter minus turbo, it sputtered and when floored went 11 mph.
    I turned it off and back on and everything was fine. It's at the dealer now. If it is the turbo wastegate, will this throw a code in the history specifically for this issue? Thanks
  2. Aug 18, 2022 at 4:48 AM
    nodak67
    nodak67 New Member
    JR
    so whats the point of starting a new thread when there is already a full thread about anything related to the turbo wastegates?
    22PlatWCP likes this.
  3. Aug 18, 2022 at 5:07 AM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
  4. Aug 18, 2022 at 5:07 AM
    JoeCle
    If you actually read the thread you would answer your smart ass response. It's full of wastegate issues but I could not find answer to specific question
  5. Aug 18, 2022 at 5:09 AM
    JoeCle
    Message count, seriously? I have a life and looking for an answer about a problem
    wxman91 and Roctane84 like this.
  6. Aug 18, 2022 at 5:13 AM
    JoeCle
    thanks 22platwcp for the info
  7. Aug 18, 2022 at 5:59 AM
    Iwantone22
    Iwantone22 New Member
    22 Tundra Limited 4X4 ICE
    Don’t worry about those guys. Their old gen trucks don’t got much going on besides a AC knob and windshield wipers. Their just bored so they come troll the 3rd gen threads :infantry:
  8. Aug 18, 2022 at 7:30 AM
    Sounds like a different issue if shutting off the vehicle “reset” and fixed the problem.
    Keep us updated on what is found (if anything). Thanks Joe.
  9. Aug 18, 2022 at 8:41 AM
    JoeCle
    Dealer just called and said no codes showing now so nothing they can do. If it repeats the problem, bring it back…
  10. Aug 18, 2022 at 9:06 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    The wastegate issue is well documented and usually occurs after spirited driving. What kind of driving were you doing when it happened? There was a guy on here who's truck died but wouldn't restart and that was an ECU issue I believe. Obviously the biggest issue for you is your trust in the truck has been disrupted wondering when/if this is going to happen. Hard to believe there were no codes from something like that but the fact it reset itself after turning it off and restarting makes me think it's electronic.
    Don't worry about the internet police chiming in on this about another thread as this isn't a textbook wastegate failure.
    FourCatDay and Hoff like this.
  11. Aug 18, 2022 at 9:19 AM
    JoeCle
    I pulled out of my development and jumped on it a little but nothing crazy, just accelerated rapidly to 50 or so. Then, check engine came on along with a message kept switching from reduced power to e brake failure…back and forth between messages.
    You are 100% correct, trust has been disrupted and feel like reliability is issue now
  12. Aug 18, 2022 at 12:07 PM
    deepdesign
    deepdesign New Member
    Yeah I agree. I looked for the answer for his question and it’s not there.
    So I agree with you that your answer is is not there but you could have posted this question under that thread making it easier for people with the same problem.
  13. Aug 18, 2022 at 12:51 PM
    JoeCle
    Though all this, my question still has not been answered. Is there actually a code for bad wastegate that would show in history?
  14. Aug 18, 2022 at 1:13 PM
    deepdesign
    I would assume that an engine malfunction light on and reduced speed would mean a code was issued. But what it is who knows. Itried Google searching and can’t find the Specific code for that issue. Only Toyota techs would know that. But once again I can’t imagine that light going on with no code. But that light might go on for various issues.
  15. Aug 18, 2022 at 1:16 PM
    deepdesign
  16. Aug 18, 2022 at 1:17 PM
    deepdesign
  17. Aug 18, 2022 at 1:20 PM
    JoeCle
    That's helpful thanks. Looks like the codes are very specific
  18. Aug 18, 2022 at 1:31 PM
    deepdesign
    Your welcome!!
  19. Aug 18, 2022 at 1:33 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Since the waste gates on our tundras are electric then yes there should be a code thrown if there is a issue with the waste gates
  20. Aug 18, 2022 at 3:04 PM
    JoeCle
    I just it back from the dealer today and I think it's weird they said there was no codes in the history at all. The advisor said the codes go away after time but it was at the dealer 3 hours after the check engine light and reduced power limp mode...that was yesterday. You'd think something would be in the history
  21. Aug 18, 2022 at 3:14 PM
    deepdesign
    Or they just aren’t being truthful.
  22. Aug 18, 2022 at 3:24 PM
    JoeCle
    that was my thought...
  23. Aug 6, 2024 at 11:02 AM
    Noboxcars
    Noboxcars New Member
    Same issue. With my 2022 1794, the check engine warning displayed and the power significantly diminished. I was putting stress on the trunk but I bought a Toyota with the expectation it can handle said "stress." I was towing a 6000 Lb travel trailer, going slightly up hill in 100 degree heat. I was using cruise control and in hindsight that may have been a mistake. Althougj, I have used it in the past with no problem. My truck has 22500 miles on it. I plan to take the trunk in but since the engine warning light is no longer there, I don't expect a solid explanation. More to come....
  24. Aug 6, 2024 at 11:08 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Just 12 days short of 2 years and bump*
    ..and 2years short of a full 1794
    mrfreeman and Breathing Borla like this.
  25. Aug 6, 2024 at 11:28 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Sometimes these turbo engines may have a hiccup and give a check engine once in a blue moon.
    If you turn it off and it resets to normal, more than likely it’s not an issue. I’ve had it happen, all is well.
    Breathing Borla likes this.
