Turn Signal Flasher Removal
Discussion in '1st Gen Tundras (2000-2006)' started by Cybertek, Aug 28, 2021.
  1. Aug 28, 2021 at 8:17 PM
    Cybertek
    Cybertek [OP] 67 Tons of Romping, Stomping mean!
    William
    Pensacola, FL
    2006 Tundra Double Cab 2WD SR5
    None
    I have a question concerning the turn signal flasher removal. I read somewhere but can't remember where or maybe I dreamed it:) that the hazard warning flasher and the turn signal flasher are the same flasher, does anyone know the answer? I have attached a photo of what the flasher looks like in the 06. The flasher seems to have been Zipp tied in, why would that be done like that? Is it okay to cut the zip tie, undo the connecting cable and just pull it out?
    Has anyone had any hyperplasia issues on an o6 where upgrading all the exterior light to LED's?
    I use SuperBrightLEDS and they want pictures of all the bulbs plus the flasher so that then can make sure Ihave the correct LEDS for this truck. As always I welcome anyone's advice or help. I have learned and completed do many projects just by asking questions here, so thanks so much, salute!
  2. Aug 28, 2021 at 8:24 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's not a flasher. It's an alarm impact sensor.
    FrenchToasty and AZTundra like this.
  3. Aug 28, 2021 at 8:38 PM
    AZTundra
    Paul
    Phoenix, AZ
    Yup, looks like an alarm shock sensor.
  4. Aug 28, 2021 at 9:31 PM
    Cybertek
    William
    Pensacola, FL
    None
    Okay, thanks, I will keep looking, salute!
  5. Aug 29, 2021 at 4:43 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Turn on a turn signal or the 4-ways and follow the sound.
  6. Aug 29, 2021 at 6:56 AM
    Cybertek
    William
    Pensacola, FL
    None
    Okay, thanks, I will try that, salute!
  7. Aug 29, 2021 at 7:51 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    You're in the right area, just point the camera up. The relay should be the same blue color. I had issues with my 05 when I tried to cheap out and get some sylvania LEDs. I changed the relay, but it didn't help. The bulbs weren't setup to be on + turn. VLEDs has the appropriate turn signals. They're not cheap, but you can catch sales around most major holidays(next weekend maybe).
    NewImprovedRon likes this.
  8. Aug 29, 2021 at 8:12 AM
    Cybertek
    William
    Pensacola, FL
    None
    Tha k you, I willget those, salute!
  9. Aug 29, 2021 at 9:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to the 2006 FSM, this is indeed true !
  10. Aug 29, 2021 at 12:53 PM
    Cybertek
    William
    Pensacola, FL
    None
    Great diagrams, thank you, salute!
  11. Aug 29, 2021 at 1:05 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    The relay for that was red on my 06 and beside the interior fuse panel. I swapped mine out for the diode dynamics smart relay. My wife’s sequoia got one also. Cool thing about it is the programmable flash patterns
    SateenC1 and FrenchToasty like this.
  12. Aug 29, 2021 at 2:11 PM
    Cybertek
    William
    Pensacola, FL
    None
    Thank you, I will look at those, do you still have the order details?
  13. Aug 29, 2021 at 2:15 PM
    Cybertek
    William
    Pensacola, FL
    None
    I just checked their site, they offer two different for non-dtrl, which one did you use?
  14. Aug 29, 2021 at 2:31 PM
    There's a 'smart' one that has a lot of convenience features, and a 'dumb' one that just helps with hyperflashing.
    I was warned by their team that my truck wasn't supported because I have daytime running lights - different plug-in or some crap. Speaking of which, I should go down and confirm that. I want the smart one for the convenience-flash feature alone.
    Teutonics likes this.
  15. Aug 29, 2021 at 4:05 PM
    Cummins3500
    Logan
    Here’s a bulb list for my tail lights. I can get you a list for the interior, third brake light, and switch backs up front if you need them
    So my 06 has the drl’s too. I just unplugged mine under the hood. I’ve been meaning to hook them back up and see what happens but haven’t done it yet. I’d assume your 06 has drl’s also. Those smart taps work on the double cabs but the access cabs use a different relay
  16. Aug 29, 2021 at 6:44 PM
    Cybertek
    William
    Pensacola, FL
    None
    No DRL just a very simple truck, so I should be okay with DD standard 10.00 flasher I hope, thanks for your thoughts.
    Cummins3500 likes this.
  17. Aug 29, 2021 at 6:53 PM
    Cummins3500
    Logan
    Should be good to go with the standard. If your still deciding on where to buy bulbs, I personally recommend diode dynamics. They’re customer service and shipping turn around times are awesome. I did use GTR for their reverse bulbs, those things are ridiculous bright.
    FrenchToasty likes this.
  18. Aug 29, 2021 at 7:06 PM
    Only thing I would do if I were y'all. Pull your existing flasher. Make sure to cound the pins and compare to what's pictured at DD's site (8 pins). Else you're throwing money at something you can't use.
  19. Aug 29, 2021 at 7:31 PM
    Cybertek
    William
    Pensacola, FL
    None
    I will do the pin count just to be sure. Who is GTR?
  20. Aug 30, 2021 at 4:25 AM
  21. Aug 30, 2021 at 5:24 AM
    Cybertek
    William
    Pensacola, FL
    None
    Thank you, salute!
  22. Aug 30, 2021 at 8:21 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Thanks for this, good information on both counts. That smart one is cool... outta my price range... but cool nonetheless!
  23. Aug 30, 2021 at 8:27 AM
    Cybertek
    William
    Pensacola, FL
    None
    I looked at the "Smart Tap" also, just more bells & Whistles than I need, it was awesome to see what a flasher can do for a vehicle. Great for parking on the street, can't miss it, well somebody would and crash your truck anyway, you just can't fix stupid, salute!
    shifty` likes this.
  24. Jun 28, 2023 at 12:36 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    OK, I found the flasher. How do I get it out? It seems like it's locked in somehow. Is there a tab holding it in. I don't want to break it off. Thanks
  25. Jun 28, 2023 at 3:17 PM
    There's a tab holding it into its place, and the harness plugs into it. I had to look carefully at it, which is difficult in its awkward position, and use a plastic spudger to pop the flasher out. I kept the harness attached so I had something to hold and exert leverage with. It's weird the first time you do it.
  26. Jun 28, 2023 at 3:23 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    That's what she said.
  27. Jun 28, 2023 at 3:35 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Thanks Shifty, I figured it out and ever6works with my new LED Flasher
    Thanks Shifty, figured it out and everything works as it should with my new LED Flasher. I swear it took me longer to do this than change all the lights out. Next challenge is how does this clear clip separate so I can put it on the new flasher and clip it in. All this thinkin' is tough on an old man. My head hurts! 20230628_145836.jpg 20230628_145832.jpg 20230628_145823.jpg
  28. Jun 28, 2023 at 3:37 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Ha! But a Lotta fun.
  29. Jun 28, 2023 at 4:35 PM
    I believe you're going to be pushing up in the direction of the arrow on that red tab while pulling the translucent piece toward you.
  30. Jun 28, 2023 at 4:51 PM
    SateenC1
    SateenC1 Fossil
    Bob
    Got it! Sheesh what a PITA. Thanks for the advice.
