Under-bed Battery Box (Torklift, others?)
Discussion in '2nd Gen Tundras (2007-2013)' started by AdamK, Nov 26, 2022.
  1. Nov 26, 2022 at 1:56 PM
    AdamK
    AdamK [OP] New Member
    I’m considering a dual battery setup in my 5.7L RCSB - just in the thinking-about phase at the moment.
    I’ve looked at many engine-bay setups including the SDHQ and Genesis and several other kits, as well as DIY designs.
    SDHQ and similar: I have a single ARB compressor on a mount behind the air box which may conflict with a relocated washer fluid tank. The split battery would be my preference if committed to stuff it all into the engine bay.
    Genesis: I’m not keen on the smaller group 25 batteries and crowding the fuse box as I’ve read can be a hassle. I gather the gen.3 kit addresses some of the crowding, but still calls for group 25’s. Love the thoughtful engineering though.
    So starting to wonder about mounting my accessory battery under the bed, maybe in front of the pass. wheel well, in a box like Torklift sells (Torklift HiddenPower), with a little extra engineering to support it and make theft more difficult.
    Curious if anyone here has done something similar, and where you sourced your box/rack. Torklift doesn’t have a recommended box for the RCSB, so would need to contact them for advice. Maybe there are other, better options.
    For control, I’d stick with the basics - a Blue Sea ML-ACR with override switch.
    Hardcore off-roading is not in my future, but Sierra snow trips are and maybe an eventual move to the Rockies. Modest lighting, winch (eventually), compressor … no refrigeration, etc. This would mostly be done for reassurance, and because I can.
  2. Nov 26, 2022 at 2:29 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I currently have a group 24 AGM in a vented box in my bed toolbox, but when that dies, I'll be mounting a Li-Ion in that space in front of the fender you mentioned. Seems there should be plenty of room there, gets it low, back, and to the passenger side.
  3. Nov 26, 2022 at 9:29 PM
    AdamK
    That’s a great space - perfect for a battery, air tank, integrated storage box, even a fuel cell <gasp!>.
  4. Nov 26, 2022 at 10:29 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  5. Nov 26, 2022 at 11:08 PM
    AdamK
    I see what you’ve done there - super simple and clean. I’ve followed some of your adventures - I guess you’re not concerned that the battery isn’t in a fully enclosed housing. You must have yours strapped down pretty good considering the kind of terrain you’re traversing.
    Cruzer[QUOTED] likes this.
  6. Nov 27, 2022 at 10:36 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    The mount sandwiches the battery to the bed via bolts that go through the bed. Battery is sealed and has not had any issues in the elements.
  7. Nov 27, 2022 at 11:23 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    What’s the benefit of a dual battery setup over a larger alternator? Wouldn’t a winch draw more power than the stock alternator can handle?
  8. Nov 27, 2022 at 11:33 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep it’s possible.
