Under Dash Footwell lights
Discussion in '3rd Gen Tundras (2022+)' started by smileytn1, Jul 23, 2023.
  1. Jul 23, 2023 at 6:59 PM
    smileytn1
    smileytn1 [OP] New Member
    HI ALL ! Has anybody put under dash foot well led lights on their 2022 tundra? I saw mods for older models but was wondering where to tie in wires to get to work with doors and dome lights . Thanks for all replies! smileytn1
  2. Jul 23, 2023 at 7:33 PM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    I did. I purchased the factory LED lights (they snap right into place and cost about $17 each) and then fashioned a harness to connect them to the center console light. This is the blue light that shines down right over where the factory phone charger is (or would be if you don't have one). Pretty easy, took about 1-2 hours.
  3. Jul 23, 2023 at 8:26 PM
    TSS Army Green
    TSS Army Green New Member
    Can you provide the part number for the factory LED lights?
    SC4333 and TundraDan723 like this.
  4. Jul 23, 2023 at 9:06 PM
    twins89
    twins89 New Member
    TN
    2023 SR5 TRD Sport Crewmax
    I am also interested in doing this project. Part numbers would be great.
  5. Jul 23, 2023 at 9:20 PM
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    Followinb
    iiawah808 likes this.
  6. Jul 23, 2023 at 10:24 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Following as well
  7. Jul 23, 2023 at 11:33 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Wouldn’t you think the harness with the power line we need for the factory lights is passing right by these snap in points already? Maybe someone can share the colors of both wires going to the footwell lights ?
  8. Jul 24, 2023 at 6:37 AM
    RatPanda
    RatPanda New Member
    Ryan
    LAMP ASSY, INTERIOR ILLUMINATION, NO.1
    Part Number: 81080-0C010
    You’ll need two. No harness near there that I can find. Not on an SR5. I made my own connectors by depinning an old harness and pulling out the female pins. I covered them with heat shrink and slid them over the pins on the LEDs. You can’t tell what the correct polarity is on the LEDs so just swap the wires until they light. Remember, you’re tying into the interior lights so that circuit is only powered when the interior lights are on.
  9. Jul 24, 2023 at 6:48 AM
    RatPanda
    RatPanda New Member
    Ryan
    You're looking for Connector I61 plugged into the combination switch assembly. (The light is on the bottom of that assembly). You need pins 9 (green) for power and 16 (lavender) for ground.
    ghunter321 and bulldog93 like this.
  10. Jul 24, 2023 at 6:56 AM
    RatPanda
    RatPanda New Member
    Ryan
    OR… if you’re not comfortable making your own connectors you could order two of these instead…
    Part Number: 81080-0C050
    These lights have the connectors and a short harness included. They normally go in the doors and provide light to the door pockets. These are like $27 each from local dealer. So $10 more for each LED but it includes a harness that you can splice into. They will fit the attachment points in the footwells.
  11. Jul 24, 2023 at 8:22 AM
    iiawah808
    Oahu, HI
    Has anyone confirmed if the harness is there in a limited?
    OP had an SR5, I ordered light two of the leds with the harness just now. I will probably take a peak under there to see if the plug is there already later.
  12. Jul 24, 2023 at 10:49 AM
    PNW Tundra Mike
    Southern Cal
    I have a Limited as well and am not sure where they are mounted. Anyone have a pic of where the footwell lights are actually? Thanks in advance.
    iiawah808[QUOTED] likes this.
  13. Jul 24, 2023 at 10:51 AM
    PNW Tundra Mike
    Southern Cal
    Thanks for these!! Where did you get these diagrams? I’d love to have access to the diagrams for the whole truck.
  14. Jul 24, 2023 at 1:36 PM
    RatPanda
    RatPanda New Member
    Ryan
  15. Jul 24, 2023 at 3:46 PM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    I've done VLEDs footwell lighting and OEM ambient lighting on my Limited. Not prewired so I tapped dome and illumination circuit.
    Pics are on my build thread.
    SC4333, ghunter321 and Taco-Spike like this.
  16. Jul 24, 2023 at 5:49 PM
    PNW Tundra Mike
    Southern Cal
    Thanks for all the pics. I like those for the rear footwells too.
    I think I'll just do the whole thing custom since none of the oem harness is in nearby
    but I'll tie into the dome light circuit to work in conjunction with all the rest.
  17. Jul 27, 2023 at 6:13 PM
    RatPanda
    RatPanda New Member
    Ryan
    And the final pics…this is an SR5 with upper trim Toyota parts retrofitted.
    in_the_mud, Brums, LakeLife and 5 others like this.
  18. Jul 27, 2023 at 6:15 PM
    RatPanda
    RatPanda New Member
    Ryan
    I also did lights on all 4 doors..there a separate thread on that…
    in_the_mud, Brums, LakeLife and 4 others like this.
  19. Jul 27, 2023 at 8:04 PM
    PNW Tundra Mike
    Southern Cal
    Very nice work!! I like the blue vs white. Thx
  20. Aug 7, 2023 at 7:03 PM
    smileytn1
    Wow ! Thnks for the info! smileytn1
  21. Aug 8, 2023 at 9:26 PM
    trd1993
    trd1993 New Member
    Did you add a light to the center console? Not sure if just how it shows up on camera, but it looks a lot brighter than what comes stock.
  22. Aug 9, 2023 at 4:20 AM
    RatPanda
    RatPanda New Member
    Ryan
    No, that center light was already there. None of these lights are as bright as these pics suggest. I took the pictures with my iPhone and they are all overexposed. These lights are all quite subtle. Much more so than these pics suggest.
    trd1993 likes this.
  23. Aug 9, 2023 at 8:41 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Do have a list of the aorta you used to pull this off. Looks awesome!
  24. Aug 9, 2023 at 8:44 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Is it all the OEM stuff or something else?
  25. Aug 9, 2023 at 9:49 AM
    RatPanda
    RatPanda New Member
    Ryan
    All OEM lights for what I did… I can pull the parts list together when I get home…I made my own cables. Not too hard. The parts…mostly fit my SR5 - there is a small amount of dremeling involved but no where you would ever see it, even if you removed the lights…
    KClav likes this.
  26. Aug 9, 2023 at 10:00 AM
    Black widow TRD
    Manuel
  27. Aug 9, 2023 at 12:35 PM
    Ransom122
    Ransom122 New Member
    22 Tundra SR5
  28. Aug 9, 2023 at 1:10 PM
    Black widow TRD
    Manuel
    I’ve yet to install it. I will go with Rat Panadas. According to the reviews it’s hit or miss with the adhesive.
  29. Aug 20, 2023 at 10:08 AM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    Did you ever get a parts list put together? Thanks for all the info. looks great!
  30. Aug 20, 2023 at 1:16 PM
    RatPanda
    RatPanda New Member
    Ryan
    poolgreenlife and LakeLife like this.
