Unlocking doors with a dead battery?
Discussion in '2nd Gen Tundras (2007-2013)' started by dmarr35, Nov 9, 2018.
  1. Nov 9, 2018 at 4:17 AM
    dmarr35
    dmarr35 [OP] New Member
    Don
    2010 TUNTRA CREWMAX
    My battery went dead because I left the interior light on I could not unlock the door because of the dead battery my question is should my drivers door unlock even with a dead battery my will not could my latch assembly be bad?
  2. Nov 9, 2018 at 5:23 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s stupid but I think that’s what will happen with a dead battery. Someone had this problem around here a while back. I think he had to pop the front fender liner loose to get to the battery and put a charge on it.
  3. Nov 9, 2018 at 12:04 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    so even the key doesn't unlock it :O wtf toyota?!
    AZBoatHauler likes this.
  4. Nov 9, 2018 at 12:16 PM
    15whtrd
    15whtrd Mr. Blonde
    From my knowledge yes. I haven’t had a dead battery and had to deal with that. But that’s what I’ve heard. And I will give you that, that is stupid, WTF!
  5. Nov 9, 2018 at 12:37 PM
    dmarr35
    Don
    2010 TUNTRA CREWMAX
    it is crazy but I wanted to make sure there was not a problem I caan not get an anser from Toyota
  6. Dec 25, 2020 at 12:04 PM
    BigHerb4x4 CrewMaxx
    BigHerb4x4 CrewMaxx New Member
    Herbert
    2010 CrewMax Limited 4x4
    None
    This is crazy but it just happened to me. I was dumbfounded when my key didn’t work to get in my truck after my battery died. I called my mechanic and he came over and saved the day. He was able to gain access to the alternator located on the passenger side and connected jumper cables to give me enough juice to unlock my door. Hope this was helpful.
    NewImprovedRon and 13tundradude like this.
  7. Dec 25, 2020 at 1:34 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Wow, this is good info!
  8. Dec 26, 2020 at 4:47 AM
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    Wow. Good to know.
    Other cars I've had at least had a mechanical backup to pop the door open if you had a dead battery (and I've had to use them). So just to confirm again, the physical key in the lock will not open the door if the battery is dead? That's kind of ridiculous.
    Will need to work on a work around while it's not dead.o_O
  9. Dec 26, 2020 at 4:51 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, I'm having a hard time believing you can't put the key in the door and turn it to unlock if the battery is dead. That worked on my Kia Forte...
    booya69 and GODZILLA like this.
  10. Dec 26, 2020 at 10:29 AM
    BigHerb4x4 CrewMaxx
    Herbert
    None
    Yes that’s correct the physical key will not unlock the truck if the battery is dead. It makes no sense to me.
    DVCNick likes this.
  11. Dec 26, 2020 at 10:32 AM
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
    Then what’s the purpose of the physical key and key locking mechanism in the door?
    Cpl_Punishment likes this.
  12. Dec 26, 2020 at 10:42 AM
    DVCNick
    DVCNick New Member
    In case of a dead fob I guess...
    But it should absolutely be mechanical in case the battery is dead, that's nuts.
  13. Dec 26, 2020 at 10:43 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I'm thinking of trying to see if I can unlock my truck with the battery disconnected.
    snivilous, 1lowlife, RNDABOUT and 5 others like this.
  14. Dec 26, 2020 at 10:49 AM
    DVCNick
    DVCNick New Member
    Let us know the results, I'd be curious to know if this was redesigned at some point. Probably should check the manual as well...
  15. Dec 26, 2020 at 10:51 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    It would seem absurd not to be able to unlock the door with just the key if the battery is dead.
  16. Dec 26, 2020 at 10:54 AM
    DVCNick
    DVCNick New Member
    I wonder if you could modify the hood latch to be able to open it from the outside. Some cars are set up that way anyway...
  17. Dec 26, 2020 at 11:04 AM
    Warreng
    Warreng New Member
    Wow, thanks for letting us know!
  18. Dec 26, 2020 at 11:46 AM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I have a pair of 2002 trucks, a Ford Sport Trac and my new to me Tundra Access Cab. Both have door lock remotes and neither allow a worn ignition key to unlock a door. Also, the original, worn key won't move the pax airbag switch on the Tundra. However, a newly cut key works in both functions, and the original valet key opens the Ford doors. So, I think the problem is worn keys generally used only in the ignition switch, tailgate and gas door. The keys and these tumblers seem to wear together and continue to function. Thing to do is to source a new key (hardware store key copied from a worn one may not work) and keep it for power out entry.
    First post, I see. Howdy, y'all!
    Leo's first and landphil like this.
  19. Dec 26, 2020 at 4:00 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Battery died on mine and would not unlock with the remote or touch pad. I used the key to unlock and it worked just fine.
  20. Dec 26, 2020 at 4:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that it's trying to be determined if this is just a 2nd Gen thing though. But thanks.
  21. Dec 26, 2020 at 4:11 PM
    French Avocado
    Utah / Wyo
    Happened on both my 2nd and 3rd gen Tundras and both unlocked with key but dead battery.
  22. Dec 26, 2020 at 4:12 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cool! Thanks again.
  23. Dec 26, 2020 at 6:44 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Not a Tundra but I could lock/unlock my 2012 Sequoia driver door with key when my battery was removed for exchange. Could also lock all the other doors with the inside manual locking button.
  24. Dec 26, 2020 at 9:38 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    2016 physical key worked just fine to lock/unlock. My battery was dying so i took it out the truck to put it on a trickle charger. During the process i was using the key to lock and unlock the door. No issues at all.
    DVCNick, Cpl_Punishment and rv740 like this.
  25. Dec 27, 2020 at 7:04 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    My 2011 when the battery goes dead i can unlock with the key just turn to the left driver door unlocks to the right all doors unlock. Never had an issue.
    Wynnded likes this.
  26. Dec 27, 2020 at 7:06 AM
    DVCNick
    DVCNick New Member
    If all your doors are unlocking with one key turn the battery isn't dead..
    Lovetrucks likes this.
  27. Dec 27, 2020 at 7:22 AM
    coTony
    Tony
    Montrose, CO
    Vegas4x4 just said his battery was on a bench being charged and he was able to unlock/lock with the key
    vegas4x4, deptrai and Cpl_Punishment like this.
  28. Jan 17, 2025 at 3:32 PM
    Bo_knows33
    Bo_knows33 New Member
    Bo
    2011 Tundra XSP
    I think what everyone is missing is...if you're not the original owner/DO NOT have the original "G" chipped key, the copied key will not open the drivers side door whether the battery is dead or not. My truck is at a body shop, newer key fob wont work, my key wont open the door(due to it being a copy)' and of course the hood is latched. So I guess I am going to have to try the alternator charge or battery charge from underneath the truck. What an ass pain. Im trying to find a way to order an original "G" chipped key so this doesn't happen again.
    OR....the key is too worn to open the door.
  29. Jan 17, 2025 at 7:01 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Gird your loins...they are spendy!
  30. Jan 17, 2025 at 7:17 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    This is an old thread but I have a few spare keys for my Tundra that are dumb keys made from blanks. They can open both front doors and tailgate even with no truck battery/disconnected, but cannot start the truck. Thus I think your keys may be too worn down physically or something else is going on. The key chip is specifically picked up in the steering console and matched with the immobilization computer (and vins in the ecu) for trucks without push to start.
