Upgraded to trd pro leds. WOW!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, Nov 18, 2020.
  1. Nov 18, 2020 at 6:16 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Got my headlights in today, oem led trd pro headlights. Installation was a breeze with @iHacker harness. Sooooo much brighter than stock, I put a coat of turtle wax on each headlight before Installation to combat uv rays and prevent hazing. Yes... I know my truck is dirty, its getting washed tomorrow.
    Resized_Resized_pixlr_20201118191629446.jpg Resized_Resized_pixlr_20201118191724633.jpg
  2. Nov 18, 2020 at 6:19 PM
    Awesome Sauce!
    Sumo91[OP] likes this.
  3. Nov 18, 2020 at 7:41 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    Sweet, looks good! I got the same setup and love it. What tow mirrors are those? Do you have a link?
  4. Nov 18, 2020 at 7:54 PM
    Sumo91
    TN
    I don't have the link. I got them off ebay. Gm style mirrors without the chrome. I love them. The lens on them hold moisture sometimes but I'm not too picky. They do their job well and look good doing it!
    16 blue crewmax and HulkSmurf14 like this.
  5. Nov 19, 2020 at 6:04 AM
    Sumo91
    TN
    polox40, bigalsnow and Black Wolf like this.
  6. Nov 19, 2020 at 6:11 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    The headlights look great! My only qualm with them is that going down narrow country roads or logging roads they send the beam straight forward, there is NO lighting to the sides, so making tight turns you are essentially blind. Fog lights have really helped in that regard though.
  7. Nov 19, 2020 at 8:28 AM
    Sumo91
    TN
    Really? I think they have much better side lighting than the stock lights, but the forward facing beam is much brighter than the sides. When driving with fields on both sides of the road I was amazed at the amount of light that was coming from the sides and illuminating the field
    teamtlr likes this.
  8. Nov 19, 2020 at 8:36 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Sumo91[QUOTED][OP] likes this.
  9. Nov 19, 2020 at 8:51 AM
    Sumo91
    TN
    The driver side is solid, passenger shakes just a little bit, probably just need to tighten it down more. They don't have the puddle lamps but I plan on taking them off my stock mirrors and fitting them to these.
  10. Nov 19, 2020 at 8:54 AM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    Nice mod!
  11. Nov 19, 2020 at 10:34 AM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    Is this basically a straight bolt in plug and play with his harness? Looks 10x better with those headlights
  12. Nov 19, 2020 at 10:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Awesome!
    It makes a world of a difference in just overall looks even with the lights off. Plus the added benefit of the LED's :cheers::hattip:
  13. Nov 19, 2020 at 11:42 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Its not "hard" but it isn't just a matter of plugging the new lights into the old harness. There are 2 options, the easy one or the hard one. The easy one is very close to a simple plug and play using the iHacker harness in between the new lights and the old harness but the LED DRL's stay on full brightness even with the headlights on (they don't dim like they are supposed to) and I could honestly see that being an issue, the DLR's are very bright and they scatter light everywhere. The "harder" installation makes the headlights work the way they do on the new trucks where the DRL dims when the headlights are turned on. it requires running a wire back through the firewall (that's the hardest part for a guy like me with big hards) and depinning a plug and adding a pin (I think) to another plug. I'd say its a 3/10 for difficulty for an average joe, but I'd say its a 5/10 for cursing and swearing and regretting your decision to do it. Once its done though you will be happy, it looks and acts like OEM and doesnt look like a 17 year old pot head did it and got lazy half way through.
    TRDFerguson, Bob_Wiley and Sumo91[OP] like this.
  14. Nov 19, 2020 at 11:45 AM
    ToyoFun
    ToyoFun New Member
    Ron
    Vancouver, WA
    16 MGM Tundra TRD Pro
    Definitely the next mod I'm doing. Since adding the Rigid LED fog lights the headlights are an embarrassment for brightness even though I currently run the PIAA Extreme White bulbs. Thanks for sharing!
    Mater and Sumo91[OP] like this.
  15. Nov 19, 2020 at 2:03 PM
    Sumo91
    TN
    With this harness its 100% plug and play, only thing different is the excess wiring from the harness adapter, I had to push the headlight into place while finessing the harness where I wanted it and zip tied it in places I felt were needed.
    Wish I woulda done this mod before my bilstein 6112/5160 set up, but I got those on sale and couldn't pass it up. I've been wanting to do this mod since I got the truck and I'm soooooo happy with it, even though my truck isn't a beauty queen with the dents and scratches, I get butterflies seeing these headlights on it! I'll give it another day or two before I get on my gfs nerves from saying how good they look :D
    BravoDeltaRomeo likes this.
  16. Nov 19, 2020 at 2:05 PM
    Sumo91
    TN
    I'm debating on the fog lights right now because I'm probably gonna pick up the Rough Country DIY pre runner bumper that you gotta weld up and then go from there. It doesn't take standard fog lights so I'm gonna wait till I get it to make a move on those. My fog lights now put out yellow lights and it looks terrible with my shiny new led headlights
  17. Nov 19, 2020 at 2:09 PM
    Sumo91
    TN
    Washed her today
  18. Nov 19, 2020 at 2:29 PM
    ToyoFun
    ToyoFun New Member
    Ron
    Vancouver, WA
    I know I'm partial but the MGM is such a great color! Obviously not in the NorthWet part of the country since you were able to wash her today...looks great:thumbsup:
  19. Nov 19, 2020 at 4:05 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Got my pro headlights last week. Just order the ihacker harness which should be here tomorrow. Can’t wait to tackle this project to go along with the oem led fogs I got.
  20. Nov 19, 2020 at 6:11 PM
    hkspwrsche
    hkspwrsche Old guy with lots of car toys
    Harold
    Richmond, VA
    2014 Tundra limited TRD CrewMax
    Working on it
    How long did it take you to install the harness? Photos with the lights on? My truck looks similar to yours so anxious to see the lamps on.
  21. Nov 19, 2020 at 8:03 PM
    Sumo91
    TN
    Harness takes only a couple minutes, I zip tied one connector together per the instructions. I'll get a photo tomorrow, I'm in for the night right now. Only took me about 35 min to remove the old lights and install the new ones, including height adjustment. I moved the washer fluid tank out of the way to get an 8mm wrench on the height adjustment, the driver side was easier to adjust. I changed the bulbs in my old lights earlier this year so I already knew the process to remove them and it really sped things up!
  22. Nov 20, 2020 at 5:01 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    if you do the "harder" method to make the DRL's dim it adds time. It took me a couple of hours, but I installed fog lights and a harness for the foglights and a switch on my dahsboard at the same time.
    I will send another post with a before and after...the "after" has the new black headlights (not the smoked chrome) fog lights and a new grill and wheels. I dont have one with the lights turned on, but I can if you need me to
  23. Nov 20, 2020 at 5:04 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Before and After. I can snap a pic with the lights on at lunch or something if you need
  24. Nov 20, 2020 at 5:36 AM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    Oh. Yeah!
    Sumo91[OP] and 9am53[QUOTED] like this.
  25. Nov 20, 2020 at 10:54 AM
    intr3nsic
    intr3nsic New Member
    What was the final bill on this? Did you get the lights second hand or ?
  26. Nov 20, 2020 at 1:10 PM
    Sumo91
    TN
    For the trd pro lights its was 303 a light, so 606 w/free shipping from sparks, harness was 100
  27. Nov 20, 2020 at 7:44 PM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    I assume you’re Canadian, I paid I think 400CAD or so each for the lights, and the harness was I think 110 plus 20 or something for shipping to Canada.
  28. Nov 20, 2020 at 11:07 PM
    Rkulp89
    Rkulp89 New Member
    2020 SR5 SX
    I recently bought a 2020 SR5 and the first time driving at night was miserable. I just ordered the TRD Pro headlights. Can’t wait to be able to drive and actually see!
    Bob_Wiley likes this.
  29. Nov 21, 2020 at 3:48 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    This was my experience with my 2019, couldn’t believe how crappy the OEM halogens were. I tried first to install LED bulbs and didn’t think it was much improvement. The TRD Pro LED headlights are awesome - one of the best mods I’ve done.
  30. Nov 21, 2020 at 4:40 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    My 2021 Limited that should be in soon, comes with led headlights and fog lights. Is there a difference between them and the pro headlights?
