Upgrading stock headlights
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by charge556, Jul 11, 2022.
  1. Jul 11, 2022 at 7:52 PM
    charge556
    charge556 [OP] New Member
    2017 Inferno 4x4
    From factory TRD off road package with 275/65/r18 TRD wheels;
    So, just came back from a road trip and discovered that the stock headlights are sorta crappy. ( It has less visibility then my old 95 nissan hardbody had with its xenon bulbs, and less visibility than my ford explorer work suv does) highbeams are ok, but when you turn them on they automatically turn off the running lights which creates sorta a weird field of vision (my wifes camry has after market running lights so when she turns on her brights both her foglights and running lights stay on which illuminates the road very well).
    So I have a 2 part question
    1) what aftermarket lights would work well and keep the factory headlight height adjustment knob functional?? Would simply changing the bulbs to xenon etc blubs do the trick?
    2) what would I have to do to allow the fog/running lights (small circular lights in the bumper) to remain on when the brights are turned on
  2. Jul 11, 2022 at 8:04 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Don't change the bulbs - get new housings. Most of them retain the adjustable functionality. I liked the morimoto xb lights but the oem pro led lights with the ihacker harness is also a popular choice.
    For the fog light thing search "anytime fog light mod"
  3. Jul 11, 2022 at 8:10 PM
    Morimoto XB's which are $1500 or you can go with the OEM leds which are around $650 or so.
    The Morimotos are projectors and the OEM are reflectors.
    bulldog93 likes this.
  4. Jul 11, 2022 at 8:12 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have profile retro fits and led bulbs in my fogs. I rarely use high beams with the combination of led fogs and Profile LEDs. Like the previous poster stated don't just upgrade the bulbs. I realized within days of buying my truck that the stock headlights had to go.
    mav7021234 likes this.
  5. Jul 11, 2022 at 8:19 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  6. Jul 11, 2022 at 8:49 PM
    charge556
    2017 Inferno 4x4
    Whats the difference between projectors and reflectors?? Dont know much about headlights
  7. Jul 11, 2022 at 8:58 PM
    Projectors will have a more controlled light pattern and cutoff line. A reflector is basically like a curved bowl that the light would reflect off of. The first pic is a projector. The other is a reflector.
  8. Jul 11, 2022 at 9:05 PM
    charge556
    2017 Inferno 4x4
    Gotcha thanks
  9. Jul 11, 2022 at 9:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ The best option..
    OEM LEDs with an @iHacker harness.
    @iHacker is GREAT to deal with..
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0] | Toyota Tundra Forum (tundras.com)
    Better brighter light than halogens with a very nice pattern and perfect cut off.
    Keeps the OEM headlight leveling.
    I got TRD Pro blacked-out LED headlights, I put it off for 2 years and should have done it sooner.
    LED hi beams will blow you away..
    cn1kwhbh_33a1cc89f379f63fdd4854b512b276b6027ccad0.jpg gk8itexz_05ccac5dc76dccb05e40b9a94650c436aaa00f0e.jpg
  10. Jul 11, 2022 at 10:15 PM
    Occidentalis
    North Florida
    I know the outer rim flashes for the oem lights but it is also sequential? I don't recall.
    icodeintx and PermaFrostTRD like this.
  11. Jul 17, 2022 at 1:19 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    You can buy my LED TRD Pro fog lights to match your new Led Headlights!!!
    I found that the pro led fogs give you a super nice cut off beam that illuminates a wide area about 30-40 feet of the truck, the Pro headlights then pick up right above that and illuminate further down the road. Toyota did a really good job with the headlights/fogs. If you run the fogs to a seperate switch you can power them on at any time. Maybe grab yourself a switch controller while youre at it and do all the wiring up at once?
  12. Jul 21, 2022 at 5:48 AM
    charge556
    2017 Inferno 4x4
    Id have to find somewhere to run the switch where it looks clean. I was looking around the other day trying to see where a switch mounting would look good
  13. Jul 21, 2022 at 6:05 AM
    PermaFrostTRD
    Northern NY
    Add another vote for OEM LED w/ @iHacker harness. Totally amazing upgrade.
    Luckydog likes this.
  14. Jul 21, 2022 at 7:42 AM
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    do you have a blank spot under the radio? You could always get a switch pro or spod ($$$ i know but then you’d be set up for the long haul)
  15. Jul 21, 2022 at 8:48 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Very happy with oem pros with ihacker harness. Huge difference. I also use the rigid DOT fog lights to provide excellent nighttime visibility .
  16. Jul 21, 2022 at 8:54 AM
    I run 2 sets of the Rigids. :D
  17. Jul 21, 2022 at 9:12 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    There are cheaper options. Trigger, Auxbeam, Cali Raised LED, Garmin PowerSwitch (not that much cheaper).
    Taco-Spike likes this.
  18. Jul 21, 2022 at 3:31 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    I have to say iHacker harness and OEM LEDs surpassed my expectations in lighting, and cosmetically they look really bitchen....glad I went this route.
  19. Aug 30, 2022 at 6:05 PM
    Michael J Bird
    Michael J Bird New Member
    Michael
    2017 Black Limited
    This set-up will not work on my 2017 will it ?
  20. Aug 30, 2022 at 6:09 PM
    Please be more specific on your question.......
  21. Aug 30, 2022 at 6:12 PM
    Michael J Bird
    Michael
    2017 Black Limited
    I have been reading as much as I can on the forum, and im seeing a lot for 2018- current for a lot of headlight replacements. I have a 2017 original headlamps. I would love to upgrade to something that would help me see better and if possible enhance the look of my truck. Thank you !
  22. Aug 30, 2022 at 6:21 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I have a 2014 that had stock halogens and upgraded to 2018 LED TRD PRO (blacked out) headlights.
    You'll just need an @iHacker harness.
    The TRD Pro would look awesome on your black truck.
    One of my best mods and investments.
    The LED light is much better with a better cut-off.
    The hi-beams will blow you away...
    I bought mine from Sparks..
    Search Results | Sparks Parts
    Welcome to the forum..
    Tundra234 likes this.
  23. Aug 30, 2022 at 6:23 PM
    You can get replacements for yours. There are the Toyota OEM leds, the more expensive
    Morimoto XB leds, etc. The Toyota leds are around $650 or so for the pair. You will need a conversion harness.. Here is a thread to look through.....
    https://www.tundras.com/threads/201...lay-harness-for-2014-2020-models-v-2-0.24416/
  24. Aug 30, 2022 at 6:49 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Trd pro led with ihacker harness and oem led fogs can't go wrong.
  25. Aug 30, 2022 at 6:54 PM
    Michael J Bird
    Michael
    2017 Black Limited
    Thanks gentlemen for the info ! I just bought the truck this last weekend. My only complaint so far is the headlights........Im 60, so that may be part of the problem.
  26. Aug 30, 2022 at 7:22 PM
    Nope.....it's definitely the headlights. The halogens have always been terrible on these trucks.
    MadMaxCanon likes this.
  27. Sep 11, 2022 at 7:27 PM
    Michael J Bird
    Michael
    2017 Black Limited
    Are the OEM LED and the OEM TRD Pro LED, the same light ? If not, Does one put out more light than the other ? Thank you !
  28. Sep 12, 2022 at 4:06 AM
    The output is the same. The Pro gives the option of the black interior housing I believe. Others that have them will clarify the difference.
    PermaFrostTRD likes this.
  29. Sep 12, 2022 at 4:07 AM
    PermaFrostTRD
    Northern NY
    This is accurate. TRD sport, TRD off road limited, platinum give you a chrome interior housing.
    Tundra234[QUOTED] likes this.
  30. Sep 13, 2022 at 3:35 PM
    Michael J Bird
    Michael
    2017 Black Limited
    I remember reading there is a discount code for Sparks parts. Free Shipping maybe...Do you know what it is ? Does Spark have the best price for these ? Thanks so much.
