Uplander - 2025 MGM Build for the North Maine Woods
Discussion in '3rd Gen Builds (2022+)' started by Volator, Mar 31, 2025.
  1. Mar 31, 2025 at 4:31 AM
    Volator
    Volator [OP] New Member
    Vassalboro, Maine
    2025 Tundra CrewMax TRD - MGM
    Decked Drawers - Gen 2 Rough Country HD2 Steps Custom 2nd row platform for Dog Kennels Bullet Point Rubigrid Weathertech HP Matts Ceramic Coated Chrome Delete (Vinyl wrapped) Spigen Tempered Glass Screen Protector JDMCAR Central Control Gear Shift Panel Trim Cover Cornfed 2nd Gen 1.5" Front Lift Cooper Discoverer Stronghold AT 295-70/r18
    We spend lots of time in the North Maine Woods bird hunting. My Silver 2008 Double Cab Gen 2 was my first Tundra. Only real updates for it were Cooper AT3's and an Extang bed cover.
    After seeing one in South Carolina in 2016, a Quicksand 2017 replaced the 2008. A matching color ARE cap with home built drawers helped carry gear and keep the dogs in the truck. A leveling kit and Coopers rounded out that truck.
    Having a little more fun with the 2025 MGM that I located & purchased in February. SR5 with TRD Off Road Premium package, Advanced Off-Road Technology Package, Premium Audio package, and a power tailgate.
    Here's how it started...
  2. Mar 31, 2025 at 4:36 AM
    Volator
    Vassalboro, Maine
    Added:
    Ceramic Coated
    JDMCAR Central Control Gear Shift Panel Trim Cover​
  3. Mar 31, 2025 at 4:41 AM
    Volator
    Vassalboro, Maine
    Build 60/40 split platform to hold 2 new Ruffland Backseat Rider kennels
    PXL_20250118_182542521.jpg PXL_20250327_124032336.jpg PXL_20250327_124048675.jpg
    MAC25Tundra likes this.
  4. Mar 31, 2025 at 4:44 AM
    Volator
    Vassalboro, Maine
    Cornfed 1.5 front leveling kit and Cooper Discoverer Stronghold AT in 295/70/r18
  5. Mar 31, 2025 at 1:48 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Nice mods. How did you build your split platform? I have been looking for something like that. Is it easy to remove or permanent?
  6. Mar 31, 2025 at 1:57 PM
    Volator
    Vassalboro, Maine
  7. Mar 31, 2025 at 2:58 PM
    PERRY1060
    Perry
    Indiana
    Awesome! Thanks. What is the diamond plate material on yours? Looks good.
  8. Apr 1, 2025 at 3:11 AM
    Volator
    Vassalboro, Maine
    I used this pad from Home Depot - https://www.homedepot.com/p/Traffic...or-Commercial-Door-Mat-6016909004x6/306932662
    I used this to glue it to the board... https://www.homedepot.com/p/Gorilla-12-2-oz-Contact-Adhesive-Ultimate-Spray-109852/322817576
    Stapled it around the edges underneath with a heavy duty staple gun.
    It was pretty hard to finish off the corners nicely with that material... carpeting/speaker covering would have been easier. Ended up finding some black foam corner protectors on Amazon to hide my mess...
    PERRY1060 likes this.
  9. Apr 1, 2025 at 5:05 AM
    Daedalus
    Daedalus New Member
    This looks nearly identical to where I'd like to end up.
    How did the spacers affect your ride quality?
    I had some on my F150 prior to getting the fox 2.0 coilovers, and they crashed and clunked over everything. Hit the upper control arm on full droop etc.
    I've got 285/75 18's on mine, slightly larger diameter, slightly smaller width.
  10. Apr 1, 2025 at 5:27 AM
    Volator
    Vassalboro, Maine
    I had a front leveling kit on my 2017 Tundra that sat on top of the shocks that squeaked and drove me crazy. The Cornfed Gen 1.5 spacer sits on the TRD Red Bilstein's bottom spring perch and just provides a perch a little higher up the shock. Simplest thing I've seen... You do need to compress the spring and take it off to put this on. And if you don't have the red Bilstein's this won't fit.
    It felt good for the 10 or so miles I drove it. But I don't have enough miles on it to provide ride quality differences... I work from home and only drive the truck on the weekends (unless it's hunting season). Plus I changed the tires at the same time so I'll likely never be able to attribute changes to one or the other.
  11. Apr 1, 2025 at 5:38 AM
    Daedalus
    Daedalus New Member
    Copy. So it wasn't just the top of strut spacer lift.
    I've got the TRD OR package so i do have the red Bilsteins.
    Good to know!
    Thanks,
  12. Apr 1, 2025 at 5:42 AM
    Volator
    Vassalboro, Maine
    @Daedalus with this design I really don't think it will make noises that the top of shock blocks do...
    Hopefully you'll like it! Plus it's only $50.
    I did have the shop I use do an alignment after install...
    Daedalus likes this.
  13. Apr 3, 2025 at 1:10 AM
    Volator
    Vassalboro, Maine
    My first 2 Tundras...
    2008 Double Cab
    2017 CrewMax
  14. Apr 13, 2025 at 12:12 PM
    Jigenax
    Jigenax New Member
    Ken
    Idaho
    2022 Blueprint Tundra DC TRD Sport
    Nice rig! I've debating between a leveling kit or a 3" lift kit for my 2022 TRD Sport. The Sport has a slightly lowered front for better road performance but not helpful for off-road use. When I paid my deposit in Dec 2021, it was the last one available. All of the TRD trims with factory lifts were sold out. Now I'm leaning towards a leveling kit after seeing yours.
    Volator[OP] likes this.
  15. Apr 14, 2025 at 9:22 AM
    Volator
    Vassalboro, Maine
    You might want a 2" lift with the sport setup. Make sure you have the red axles.
    Jigenax[QUOTED] likes this.
  16. Apr 17, 2025 at 11:24 AM
    Daedalus
    Daedalus New Member
    Going to give this a shot.
    Volator[QUOTED][OP] likes this.
  17. Apr 17, 2025 at 4:55 PM
    Volator
    Vassalboro, Maine
    I'm still liking them. No creaking like with my old shock toppers.
    Daedalus[QUOTED] likes this.
